08-17-2008, 09:14 | #21 (permalink) |
Junior Member Join Date: Jan 2007
Member: 439184 Status: Offline Thanks Meter: 2 | Please Help when i open the main tainess software first display Bad environment 200 when i press ok then program open but cannot connect box it shows access violation at 00000000 |
08-21-2008, 14:16 | #23 (permalink) |
Junior Member Join Date: Dec 2006
Member: 413096 Status: Offline Thanks Meter: 3 | To: smart user install this driver for UFS_Maintenance_v20, when finish with him remove them and install new drivers and suite http://www.filefactory.com/file/d9c3...B_Driver_1_rar http://www.filefactory.com/file/5b28...ool_Manual_rar To: malikasim 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called ******.req. (where ****** is your UFS serial number) 7. Send this file to your UFS reseller or calculate with -----> Twister Activator & Req 2 Fbi 8. When you receive ******.fbi, perform steps 1-4 above. 9. Select ******.fbi 10. After a few seconds your box will be authorised. http://www.filefactory.com/file/a9a1..._Activator_rar I had to put external links, here we did not work upload |
The Following User Says Thank You to ZoranG For This Useful Post: |
09-04-2008, 16:50 | #24 (permalink) | |
Major Poster Join Date: Dec 2007
Member: 644230 Status: Offline Thanks Meter: 6 | help me pls Quote:
file in the above location i colud not understand can u explain thanks in advance | |
Blackberry 8320 (NEW) DEAD plz suggest what to do | riskyboi | BlackBerry (RIM) | 2 | 07-18-2009 12:33 |
Please help me to do Zxxx cable adapter ? Need picture | gsmnice | NSPRO | 8 | 02-26-2007 00:33 |
Dead E1 Rokr!!! What To Do?? | fabulous801 | Smart-Clip | 24 | 05-12-2006 14:55 |
B1300 isn't unlocking :( plz help what to do ? | the_frightener | LG | 9 | 06-03-2004 18:01 |
