Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 515506 Status: Offline Thanks: 11
| UFS problem Dear Friend you just uninstall all exe. and all drivers, resatart pc, then you reinstall uspate exe and driver, don't use same USB port, your problem will solved. thanks piyush |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: Jodhpur
Member: 48238 Status: Offline Sonork: 100.54361 Thanks: 78
| Use the rascal tool for repairing it. Just flash your UFS with 2.5 and after connect in with any Nokia Ufs EXE and update your box. And you will become happy. If any doubt SMS +91928512342 WBR Jyoti Prakash India |
| | #8 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Age: 28
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks: 554
| REQ->FBI Process - Box Auth Error 20 -------------------------------------------------------------------------------- DO NOT, perform this process unless you have Box Auth Error 20, or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your reseller. 8. When you receive xxxxxx.fbi from your reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Pls. post different msgs.to detect Hardware Faults in UFS.. | amit123 | Nokia Hardware & Hardware-Repair Area | 3 | 08-22-2008 04:05 |
| 3650 fault on UI setting ( UFS Only ) | gepenx_fausta | WD2 & APE (Symbian Phones) | 2 | 08-08-2007 17:18 |
