02-18-2006, 17:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2002 Location: GSM-FORUM
Member: 13726 Status: Offline Thanks Meter: 1 | (272)debugger detected-please disable it and restart the application I have problems like this after i connected USF3 around 1 to 2 hours. it happens to my 3 pc with XP pro. This can only solved by restart PC. Any help??? |
02-21-2006, 14:36 | #6 (permalink) | |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | no way reinstall your windows br <= The_Gorr => Quote:
03-19-2006, 14:10 | #10 (permalink) |
Insane Poster Join Date: May 2002 Age: 46
Member: 12356 Status: Offline Thanks Meter: 7 | Try installing an antispyware software like webroot spysweeper (not intended as an advertisement), your system might have some monitoring softwares installed without your knowledge |
03-20-2006, 10:29 | #12 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | maybe in your situation you solved the problem because Script Debuging is enabled but it's not the final solution for this problem good luck br <= The_Gorr => Quote:
10-27-2006, 23:34 | #15 (permalink) |
Junior Member Join Date: Sep 2006
Member: 346085 Status: Offline Thanks Meter: 0 | mimmy228, I followed your directions below, however, the option for 'Disable Script Debugging' was checked again. No matter how many times I unchecked it and closed out the browser, it came back checked again. How can I make the change permanent? Thanks |
[272] Debugger detected | Fuffteruffter | VygisToolbox | 0 | 08-04-2009 16:12 |
Debugger detected.please close it and restart the application...??????? | SicilianBoy | VygisToolbox | 5 | 01-27-2009 22:42 |
UFS Error - Please disable it and restart the aplication? | ConnectBrasil | HWK | 3 | 12-17-2008 09:58 |
error 272 debugger detected | toptro | VygisToolbox | 3 | 10-27-2007 12:36 |
272 - Debugger detected | radiodepilhas | SonyEricsson (USB-Smart) | 15 | 05-23-2006 14:54 |
