ufs is now USB <-> Dual serial i upgrad this box i use one bad softwer and i put in usb it saying found new USB <-> Dual serial help :confused: |
Usb <-> all you need an Mprogram and good ept file and promer it Mprogram you can get it from www.ftdichip.com |
hi mate u can find the real solution only on www.actgsm.com problem sloved there with pic in tornado section br |
yes you can solve this problem yes you can solve this problem it is so easy contatc me private |
Mprogram Quote:
Mprogram and good ept file all you need |
Problem solved 1 Attachment(s) Problem solved. I had same problem. Solution. 1. usb-serial driver installation take this ftdi driver http://www.ftdichip.com/Drivers/D2XX.htm 2. after installation ,box is usb - serial device 3. use mprog http://www.ftdichip.com/Resources/Ut...g3.0_Setup.exe 4. start mprog, scan device , load good eep 5. programm device 6. box is sarasbox 7. use ufs3tools.exe flash firmware 2.6 8. reconnect flash firmware 2.5 9. start UFS_DCTxBB5 and update box 10. box is fine and ready regards bassmc |
I have make my ufs that was in mode usb to duel drivers now its a very easy to me any body want solution contact me [email protected] |
There is no any idea i have read all post every body send links but only drivers or mprog or any others but its after steps |
saifali , please help me my ufs gone into dual serial please upload the softwares and steps thanking u from the bottom of my heart |
plz help me "USB <-> Dual serial" i upgrad this box i use one bad softwer and i put in usb it saying found new USB Dual serial help [email protected] |
i have same problem i have downloaded the ftdi drivers from the ftdichip site.my box showed usb<.>dual serial device fonud.but still it is not picking up the ftdi drivers.what to do now? |
use solution use mprog and good eeprom, solution works 100% |
Mr. Saifali apne experience dosron se share kar lia karo .Dosron se alag rehne ki koshish kion karte ho ? |
ho sakta hai ke saif ali apne ap ko kuch or he samjhte hon!!!!!!!!!!! |
1]-replace this ATMEGA8-16PI 2)-use mprog and good eeprom 3)-Reconnect your box and install orig ufs driver To use MPROG 1. I download it from ftdi site MPROG utility 2. I try to connect UFS again but UFS not recognize original drivers - install drivers from \Program Files\MPROG\Drivers and connect UFS 3. Start MPROG and "Scan" system - MPROG found one device ... I (UFS comes with VID:0888 and PID:5508 .... SEE INI FILE INTO UFS DRIVERS DIRECTORY) 4. Into MPROG -> File/New - Device Type -> FT232BM - USB VID/PID -> Own VID & PID - Vendor ID -> 0888 - Product ID -> 5508 - USB Version number -> USB 1.1 - Check "Use Fixed Serial Number" - Enter into EDIT BOX your serial number located on UFS cover - Manifacturer -> UFS2 - Product description -> UFS2 SarasSoft - Uncheck "Only Program Blank Devices" 5. Into MPROG - File/Save ... to save template for future use and for unlock function "Device/Program" 6. Into Mprog - Device/Program ... to program eeprom 7. Close Mprog and disconnect UFS from cable 8. Connect UFS to cable and now UFS recognize OWN driver 100/% work |
