02-06-2007, 16:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | ufs is now USB <-> Dual serial |
02-06-2007, 23:33 | #2 (permalink) |
Freak Poster Join Date: Jan 2005 Location: portugal
Member: 109096 Status: Offline Sonork: najem272 Thanks Meter: 49 | Usb <-> all you need an Mprogram and good ept file and promer it Mprogram you can get it from www.ftdichip.com |
02-07-2007, 00:09 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | hi mate u can find the real solution only on www.actgsm.com problem sloved there with pic in tornado section br |
02-07-2007, 00:16 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MATRIX.REAL
Member: 202333 Status: Offline Thanks Meter: 178 | yes you can solve this problem yes you can solve this problem it is so easy contatc me private |
The Following 3 Users Say Thank You to MATRIX.REAL For This Useful Post: |
02-25-2007, 20:34 | #6 (permalink) |
Insane Poster Join Date: Jul 2003 Location: crivitz city - germany
Member: 35533 Status: Offline Sonork: 100.111990 Thanks Meter: 58 | Problem solved Problem solved. I had same problem. Solution. 1. usb-serial driver installation take this ftdi driver http://www.ftdichip.com/Drivers/D2XX.htm 2. after installation ,box is usb - serial device 3. use mprog http://www.ftdichip.com/Resources/Ut...g3.0_Setup.exe 4. start mprog, scan device , load good eep 5. programm device 6. box is sarasbox 7. use ufs3tools.exe flash firmware 2.6 8. reconnect flash firmware 2.5 9. start UFS_DCTxBB5 and update box 10. box is fine and ready regards bassmc |
The Following 15 Users Say Thank You to bassmc For This Useful Post: |
11-08-2008, 08:52 | #7 (permalink) |
No Life Poster Join Date: May 2008 Location: PAKISTAN Age: 34
Member: 772820 Status: Offline Sonork: BE MASTERMIND Thanks Meter: 124 | I have make my ufs that was in mode usb to duel drivers now its a very easy to me any body want solution contact me [email protected] |
11-08-2008, 08:55 | #8 (permalink) |
Member: 772820 Status: Offline Sonork: BE MASTERMIND Thanks Meter: 124 | There is no any idea i have read all post every body send links but only drivers or mprog or any others but its after steps |
The Following 3 Users Say Thank You to saifali For This Useful Post: |
05-09-2009, 21:59 | #10 (permalink) |
Junior Member Join Date: May 2008
Member: 766461 Status: Offline Sonork: 2010 Thanks Meter: 0 | plz help me "USB <-> Dual serial" i upgrad this box i use one bad softwer and i put in usb it saying found new USB Dual serial help [email protected] |
05-13-2009, 09:49 | #11 (permalink) |
Freak Poster Join Date: May 2007 Location: South Africa Age: 44
Member: 505446 Status: Offline Thanks Meter: 45 | i have same problem i have downloaded the ftdi drivers from the ftdichip site.my box showed usb<.>dual serial device fonud.but still it is not picking up the ftdi drivers.what to do now? |
05-22-2009, 14:24 | #15 (permalink) | |
Temporary banned !! Join Date: Mar 2008 Location: Infront in my PC
Member: 716001 Status: Offline Sonork: 100.1597485 Thanks Meter: 46 | Quote:
1]-replace this ATMEGA8-16PI 2)-use mprog and good eeprom 3)-Reconnect your box and install orig ufs driver To use MPROG 1. I download it from ftdi site MPROG utility 2. I try to connect UFS again but UFS not recognize original drivers - install drivers from \Program Files\MPROG\Drivers and connect UFS 3. Start MPROG and "Scan" system - MPROG found one device ... I (UFS comes with VID:0888 and PID:5508 .... SEE INI FILE INTO UFS DRIVERS DIRECTORY) 4. Into MPROG -> File/New - Device Type -> FT232BM - USB VID/PID -> Own VID & PID - Vendor ID -> 0888 - Product ID -> 5508 - USB Version number -> USB 1.1 - Check "Use Fixed Serial Number" - Enter into EDIT BOX your serial number located on UFS cover - Manifacturer -> UFS2 - Product description -> UFS2 SarasSoft - Uncheck "Only Program Blank Devices" 5. Into MPROG - File/Save ... to save template for future use and for unlock function "Device/Program" 6. Into Mprog - Device/Program ... to program eeprom 7. Close Mprog and disconnect UFS from cable 8. Connect UFS to cable and now UFS recognize OWN driver 100/% work | |
The Following 4 Users Say Thank You to musmyl For This Useful Post: |
Ufs Micro usb <--> Serial | masterunlock | UFS2 + UFS3-Tornadoflasher | 2 | 06-14-2008 15:46 |
usb <-> serial? Why | kasalapi | HWK | 1 | 04-02-2007 15:49 |
