03-27-2012, 01:39 | #40 (permalink) |
Junior Member Join Date: Oct 2008
Member: 874595 Status: Offline Thanks Meter: 0 | hi to all i have ufs micro box hang on the two front leds when trying to program with mprog says no devices found also tryed read and parse it displys this message ERROR - Read EEPROM failed Device 0 please need help urgently |
02-20-2013, 15:37 | #41 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1060650 Status: Offline Thanks Meter: 8 | I used Mprog and Removed USB Serial Error. Now it is detecting as UFS Sarasoft.But could Not Install UFS driver. I think there were occured wrong entry when writing etp file or EEPROM file with the Mprog. SO need to Delete it and rewrite. NOW Mprog only shows as Number Of Blank Devices = 0 Number Of Programmed Devices = 0 when try to scan or Reprogram it. I would like to get a solution to Rewrite the Program. |
07-06-2013, 14:08 | #43 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1887334 Status: Offline Sonork: 100.1627153 Thanks Meter: 6 | i have same work, i am major wrong? please this video: http://www.4shared.com/file/bzayOIWF/video.html? Pls help me now my device showing " usb <-> dual serial" |
07-07-2013, 11:32 | #44 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | donwload mprog (2.8 for me work great), then install drivers from mprog folder(manualy from device menager), then you can work with mprog, now set mprog with http://images40.fotosik.pl/962/5e465edd4697da8dgen.jpg that, hit scan then program, (program works if you save project in mprog), now your box should be fine |
Ufs Micro usb <--> Serial | masterunlock | UFS2 + UFS3-Tornadoflasher | 2 | 06-14-2008 15:46 |
usb <-> serial? Why | kasalapi | HWK | 1 | 04-02-2007 15:49 |
