Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 06-28-2005, 19:28   #1 (permalink)
Member: 11125
UFS problem with 7610
look the attachment image.
the message appearence then I try to flashing the 7610
Any solution?
thanks a lot.
Old 06-28-2005, 20:34   #2 (permalink)
07heaven's Avatar
Member: 57937
Use Shorter USB cable, and Shorter 7610 service cable.
Cause its USB powered, some power is lost through long cables.
Or using on a powered hub may help too
Is it the first one you've done?
If not, then it maybe a hardware fault on the phone.
Old 06-28-2005, 21:02   #3 (permalink)
Member: 11125
thanks, but I don't think that there is problem with cable.
My cable is normal size.
Old 06-28-2005, 23:39   #4 (permalink)
GamalyGsM's Avatar
Member: 154404
try to Erase flash first and try to flash it again ....
Old 06-29-2005, 08:28   #5 (permalink)
hamzaa's Avatar
Member: 84694
try to flash mcu.then flash ppm.i had a7650 that had a similar problem and i flash it one at time and it worked.try it.
Old 06-29-2005, 10:32   #6 (permalink)
ANoNYMoUS_1's Avatar
Member: 153299
erase flash file, flash mcu+ppm..
you better sure that your cable is good.
Old 06-29-2005, 10:34   #7 (permalink)
systemworm's Avatar
Member: 68498
erase flash afterwards reflash mcu+ppm write a good pm.Format user area and do full defaults.
very big problem with 7610 nofear197979 WD2 & APE (Symbian Phones) 25 08-14-2008 22:14
problem with 7610 daydy1801 Nokia Digital Core Technology 4 ( DCT-4 ) 5 11-24-2007 06:28
very interesting problem with 7610 keypad! KUBAT1 Nokia Hardware & Hardware-Repair Area 2 11-01-2006 10:19
More problem with 7610 nishaon WD2 & APE (Symbian Phones) 6 09-19-2006 19:42
Unlock problem with 7610 burraq WD2 & APE (Symbian Phones) 3 08-01-2006 14:20
Page generated in 0.26863 seconds with 12 queries
