Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 07-31-2013, 08:36   #16 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
Originally Posted by bijayprusti View Post
i am updating but its showing you have 148 items to update
try after 24 hours. ur probelm will b solve
The Following User Says Thank You to GSM.solve For This Useful Post:
Old 07-31-2013, 08:54   #17 (permalink)
bijayprusti's Avatar
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
if i reupdate this then any problem bcoz already finish update
The Following 2 Users Say Thank You to bijayprusti For This Useful Post:
Old 07-31-2013, 09:14   #18 (permalink)
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
no need to update when i go for reupdate
Old 07-31-2013, 09:17   #19 (permalink)
Member: 508157
Sonork: 0100.1627392
Thanks Meter: 54
i try to use this procedure and now i get this error message.."hwk not authorized,use update tool
Old 07-31-2013, 09:20   #20 (permalink)
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
remove old driver and install new one and reconnect
i also suffer but mine box working fine right now
The Following User Says Thank You to bijayprusti For This Useful Post:
Old 07-31-2013, 09:30   #21 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
dont worry after check box do update box
Old 07-31-2013, 11:13   #22 (permalink)
Member: 946678
Thanks Meter: 69
thanks Saras team. Hwk is the best.
Old 07-31-2013, 13:58   #23 (permalink)
Member: 1710210
Thanks Meter: 35
Originally Posted by GSM.solve View Post
UFS 2.3.0 Released now u can flash morethen last time modals
1 : Scan Box
2 : Check Box
3 : then go to Software and check server
4 : Install
http://img542.imageshack.us/img542/5706/tcm9.jpg
UFS_PANEL_OK - Download - 4shared
GSM.SOLVE
how to get 2.3.0 suite and support setup
The Following User Says Thank You to smarty89 For This Useful Post:
Old 07-31-2013, 14:10   #24 (permalink)
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
ufs panel download karo wahin pe diya hua hai
Old 07-31-2013, 15:16   #25 (permalink)
Member: 614128
Thanks Meter: 2
LIC5: True
BOXK: 0
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 73218
HID: A8ACFEDB4160001B, HWK: A1.04-PRO1
LIC: True
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: 2
Authentication stage error: Connection Closed Gracefully.
Old 07-31-2013, 15:27   #26 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
no need to download just follow this instructions after do it HWK 2.3.0 Fully installed in ur PC
GSM.SOLVE
Old 07-31-2013, 17:36   #27 (permalink)
Member: 1989901
thanks for the information now I can try to update ufs box
Old 08-01-2013, 06:37   #28 (permalink)
Member: 1623940
Thanks Meter: 22
GSM.SOLVE
box update is fail
BOX_AUTH_ERROR: 1111
BOX: CORRUPTED or MANIPULATED
Bad IX: ABCD
Failed: -5
pls help me sir
Old 08-01-2013, 06:52   #29 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
Hwk box error 0000080 while updating in 2.3.0
Old 08-01-2013, 07:39   #30 (permalink)
speed infotech's Avatar
Member: 449060
Sonork: 100.1670591
Thanks Meter: 260
work with hwk or only ufs box ?
Page generated in 0.22790 seconds with 9 queries
