Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 08-06-2013, 11:48   #91 (permalink)
Member: 1654764
Sonork: jayalath
try after about 24-48 hours.
Old 08-06-2013, 11:50   #92 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
Originally Posted by kvivek View Post
fUpgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:8/4/2013 3:18:52 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 85246
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: UFS3
-- HWK ID : A1.04-PRO1-F69712E342600045
-- HWK Status : 1, DL: 13
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Connection Closed Gracefully.
help me plz
Install new windows and try after 24hours
Old 08-06-2013, 12:48   #93 (permalink)
Member: 1806692
Sonork: 1655937
Thanks Meter: 5
I had an error after installation kindly gave me an solution sir pls
ImageShack® - Online Photo and Video Hosting
Old 08-06-2013, 14:11   #94 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
Install again all files
1 go to Control panal - add/remove uninstall all kinds of ufs
2 remove sarasfot folder that will be C\program files\sarasaoft
3 restart Pc
4 again run UFS Panal and follw my instructions
GSM.SOLVE
Old 08-06-2013, 15:28   #95 (permalink)
Member: 1995460
Sonork: 100.1645047
thanks my problem is solved
Old 08-06-2013, 15:41   #96 (permalink)
Member: 1995460
Sonork: 100.1645047
my ufs is now work fine thanks to ufsx panel 2.3.0.1 and thanks to mushahidlove to great help
Old 08-06-2013, 19:30   #97 (permalink)
Hussain_Mobile's Avatar
Member: 681758
Sonork: 100.1676160
Thanks Meter: 337
Originally Posted by GSM.solve View Post
UFS 2.3.0 Released now u can flash morethen last time modals
1 : Scan Box
2 : Check Box
3 : then go to Software and check server
4 : Install
http://img542.imageshack.us/img542/5706/tcm9.jpg
UFS_PANEL_OK - Download - 4shared
GSM.SOLVE
Thanks Shanoo bhai you Help me alot , now my box working fine
Bro Hussain
Old 08-07-2013, 03:01   #98 (permalink)
rajdeepsaw's Avatar
Member: 723195
Thanks Meter: 57
CPU: GenuineIntel, Sp: 5
Platform: Windows NT 6.1 (Build 7600 )
Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14
Executive Path:
C:\Program Files\Nokia\Phoenix
Warning, folder: C:\Wintesla\ not exist !
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007. Sn: 71969
HID: 1B8BC084426000A8, HWK: A1.04-PRO1
HWK: NOT AUTHORISED, USE UPDATE TOOL
pls help..............
Old 08-07-2013, 08:05   #99 (permalink)
Member: 1143499
Thanks Meter: 19
actualize to version 2.3.0.0 and it does not stop flashar the s3350 does not do full factory reset the Nokia 100 in the previous update the s3350 full flashaba I've tried re ala previous version and did not leave the server this is the error that goes Locating HWK Upgrade server ...
Preparing connection to server ...
HWKUpgrade Connecting to server ...
Authenticating on server ...
Authentication stage error: Error: Server returned unrecognized reply
Old 08-07-2013, 08:31   #100 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
Executive Path:
Just open ufs panal scanbox and do update then close it.
check ur software
br
GSM.SOLVE
The Following User Says Thank You to GSM.solve For This Useful Post:
Old 08-07-2013, 08:32   #101 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
old severs are cloes now 2.3.0 working
and try again after 24 hours
GSM.SOLVE
Old 08-07-2013, 09:27   #102 (permalink)
Member: 764418
Sonork: 100.1593578
Thanks Meter: 43
Red face
hi anyone can help me buy this box GsmServer but only for a limited time I use it with Windows XP ... then with windows7 32bit impossible I went there a way that can do this is the error function gives me .. thanks
http://www.4shared.com/download/wcaG...82537-87a75303
http://www.4shared.com/download/wcaGJntG/error_ufs_new_.jpg?tsid=20130807-082537-87a75303
log:
pp: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft
CPU: GenuineIntel
C:\Program Files
C:\Program Files\Common Files
C:\Program Files\Nokia\Phoenix\
C:\Users\phantomas\Desktop
C:\Users\phantomas\AppData\Roaming\Microsoft\Windo ws\Start Menu\Programs
Box: 1 Location: 530 Serial: 79108
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 79108
LIC: True
Your IP: 190.231.37.225
Support: Bad HID, Cannot Access Suport
REST: Ok
UFSx: UFS3 Sarasoft, USB S/N: 79108
NVML: OK
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 79108
LIC5: True
BOXK: 0
LIC: True
Old 08-07-2013, 09:53   #103 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
i told its not working on Win Vista , 7 32 or 64 bit
br
GSM.SOLVE
Old 08-07-2013, 10:53   #104 (permalink)
Member: 1181277
Thanks Meter: 13
sir help me.
update ufs ufs panel then box connect show please reinstall hwk support suite.
Old 08-07-2013, 15:41   #105 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 361
Originally Posted by myzoneramu View Post
sir help me.
Contact me at Pm ill solve ur problem
GSM.SOLVE
Page generated in 0.37627 seconds with 8 queries
