05-20-2006, 05:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Rawalpindi,Pakistan Age: 45
Member: 133099 Status: Offline Sonork: 100.1582860 Thanks Meter: 18 | UFS is detected as USB<Serial> device After erase i was mad to disconnect the ufs from PC. Now whenever i connect it to PC it is detected as USB <Serial> device not ufs3 or ufs2. Now no drivers for ufs3 are installed i cant use any repair and maintenance software for ufs3. Is there any way to reprogram it? I know only one solution is left which is ponyprog or similar eeprom programming devices but i dont know how to use. Waiting for quick reply from masters... |
05-20-2006, 07:17 | #4 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | Quote:
Its no. like this ATMEL 416 93046 S127 A Change this is 100% ur problem solve..(not sure but after this u have to rewrite ur firmware to recover ur sr. no.) best regards Last edited by muksforu; 05-20-2006 at 17:08. | |
05-20-2006, 08:02 | #8 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
if u wanna use pony prog, u must desolder to eeprom..then u must programmed to eeprom chip with programmator.. check here.... http://www.lancos.com/siprogsch.html u will see the two schema...one of them is base board.... at second schma is for microwire eeprom adapter... first..." Base board " second.... " Microwire eeprom adapter " | |
05-20-2006, 11:47 | #11 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
AS I SEE YOU JUST ERASED EEPROM...YOU CAN REPROAM EASYLLY ITS 2MINITE JOB....NO NEED TO REMOVE IT.... @just_learn NEVER NEED TO PROGRAM 93C46....PLACE NEW IC AND ITS WORK I DONED SO MANY... | |
05-20-2006, 13:08 | #13 (permalink) |
Freak Poster Join Date: Jan 2005 Location: @CEYLON Age: 46
Member: 109882 Status: Offline Thanks Meter: 37 | my UFs box also detecting as a SERIAL USB Hi mates, I have a problem with my ufs3 i used Mprog to reprogram the ufs3 coz it was giving errors on Nokia DCT3 and DCT4 models. After erase i was mad to disconnect the ufs from PC. Now whenever i connect it to PC it is detected as USB <Serial> device not ufs3 or ufs2. Now no drivers for ufs3 are installed i cant use any repair and maintenance software for ufs3. Is there any way to reprogram it? I know only one solution is left which is ponyprog or similar eeprom programming devices but i dont know how to use. Waiting for quick reply from masters... |
05-20-2006, 13:24 | #14 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: AM
Member: 171307 Status: Offline Thanks Meter: 140 | Quote:
05-20-2006, 13:35 | #15 (permalink) | |
UFS TO SERIAL DREIVER IN YOUR PROGRAM FILE MPROG\DRIVER FOLDER GIVE THIS DRIVER TO UFS AND WRITE EEPROM OF UFS CHECK MY THREAD FOR STEP BY STEP INFO... | |
Infinity team the whole infinity is detected as virus by avira antivirus | dapinderjit | Infinity-Box | 5 | 03-21-2010 18:04 |
SpiderMan detected as Unknown Device (VIP/PID 0000) in Windows | FractalizeR | SpiderMan | 10 | 06-09-2009 19:21 |
Support.exe is detected as virus? | mentari | Nokia Fault Finder Box | 9 | 08-28-2008 04:06 |
Jaf 1.98.31.exe is detected as a virus by NOD32 | francis1986 | J.A.F. By Jafsupport.com | 12 | 09-18-2007 02:25 |
