Ufs3 Repair Soft HELLO , SOMEBODY IN DIFFERENT FORUM HAS REPAIRED HIS UFS BOX WITH THIS SOFT , HAS SOMEBODY KNOW WHAT THIS SOFT IS AND HOW IT WORKS FOR REPAIR THE BOX AND THE LINK IS ATTACHED |
It's just SW by FTDI for programming internal eeprom. |
Anyway Out To Repair The Boxes , Any Method Can Someone Prescribe |
No Devices Found when i try to programing ufs with MProg and when i scan it show me No Devices Found |
it work for ufs dead,not work with usf normal,you can trying remove driver for your box....trying test.. |
Don't talk $hit when you don't know anything. B/r |
hi, could u educate us about Mprog- multi device eeprom programmer v2.3 best regards |
conecting when I conect the box show me USB<-> serial cable and the drive not instaled so is somthing wrong with my box when I conect an other box show me USB saras soft and the driver run ok????? |
try this 1.Connect ufs3 box 2.Open MProg>>>>go to Device>>>>Scan Device 3.Open File>>>>fing the (ufs_good.ept)eeprom program templates>>>>select 4.File>> Edit>>>uncheck Disable USB SerialNumber 5.check Fixed Serial Number>>>>enter sn of your box 6.edit Manufacturer ex.(UFS3)>>>Product Description ex.(UFS3 tolski316) then save. 7.Device>>>Erase... 8 Device>>>>.Program.... 9.unplug box and connect again...thats it... |
ufs 3 usb <-> serial problems |
Everything is here Quote:
http://www.ditsonline.com/poster/161...ongle-blue.jpg All box eeprom http://forum.gsmhosting.com/vbb/atta...6&d=1237736921 MProg 3.5 http://www.ftdichip.com/Support/Utilities/MProg3.5.zip If some thing is missing pm me.. I will post here.. Regards Zeesshan Haider |
i done same process but after erase box , the pc shows single RS232-HS drivers, and then box is not detecting ,, plz help me .. |
sir plz hellp box_ supd_error;00000080 |
