Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 07-30-2013, 13:51   #1 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
UFS Update 2.3.0
UFS 2.3.0 Released now u can flash morethen last time modals
1 : Scan Box
2 : Check Box
3 : then go to Software and check server
4 : Install
http://img542.imageshack.us/img542/5706/tcm9.jpg
UFS_PANEL_OK - Download - 4shared
GSM.SOLVE
The Following 48 Users Say Thank You to GSM.solve For This Useful Post:
Old 07-30-2013, 16:09   #2 (permalink)
jorj_saha's Avatar
Member: 1649620
Sonork: 100.1603891
Thanks Meter: 177
thanks good seare UFS tem.....
The Following 4 Users Say Thank You to jorj_saha For This Useful Post:
Old 07-30-2013, 18:23   #3 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
Thanks man you are a life saver...
The Following 5 Users Say Thank You to zishhaider For This Useful Post:
Old 07-30-2013, 18:36   #4 (permalink)
RATHISH.TR_ALUVA's Avatar
Member: 439555
Sonork: 100.1603756
Thanks Meter: 139
shani..
i think new update,will work only with new box.
cant use new features with old box.
have you tested.
pls post whats news in new software with old BOX ?
The Following 4 Users Say Thank You to RATHISH.TR_ALUVA For This Useful Post:
Old 07-30-2013, 18:46   #5 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
Yes it is working with old box.. Here i have x2-02 rm 694 checking .. Major changes are in nokia and samsung.. Nokia=New models are added.... SAMs=Android and new models are added for flahing unlock and imei option....
The Following 2 Users Say Thank You to zishhaider For This Useful Post:
Old 07-30-2013, 18:56   #6 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
DCTxBB5
V 2.3.0.0
1. BB5 RAPU Based Products USB Flashing / UI support added:
RM-754 (801T)
2. DCT4 INFINEON Based Products USB Flashing / UI support added:
RM-694,RM-761,RM-799,RM-800 (X2-02,200,201,201.1)
SAms
V 2.3.0.0
SWIFT
T456-FIDO,T456-ROGERS added (UNL,SECT,IM,FL)
SWIFT-AEROFONE
[Patch MSL] fixed for DUOS Products.
E1086W,E1153i,E1182-CHN,E1195L,E1200,E1200M,E1200M-CHN,
E1200T,E1202,E1205,E1205L,E1205M-CHN,E1205T,E1207,E1207T-IND,
E1207-MEA,E1220T,E1230T,E1232B,E1232D added (PUNL,PIM,FL)
C3520,C3780,C3782,E2250,E2252 added (UNL,SECT,IM,FL)
E2220,E2222L (UNL,SECT,IM)
SWIFT-3G
C3630,C5190,C5530,E3217B,E3217L,S5270K,S5270L,S568 0
added (UNL,SECT,FL)
C5010,E3210,E3213,S5610 Direct Unlock Fixed.
IMEI Repair Added for Almost All Models:
C3630,E2310,E2313,S3710,S5270,S5610,..
INFINEON
C3310,C3310R,C3312,C3312R,C3313K,C3330,C3332,C3350 ,C3350M,
E2230L,E2350B,E2600,E2600M,S3800,S3802,S3802W,S522 0,S5220R,
S5222,S5222R,S5229,S5292,S5296 added (CUNL,PUNL,PIM,FL,UFL)
E1151 Missing boot fixed.
E1151 IMEI Rebuild and Direct Unlock added (AT Mode)
Note: Need make Boot Mode Info before use of AT Mode.
QUALCOMM
M210S,T356 Added.
BROADCOM
S5380B,S5380D,S5380F,S5380G,S5780D,S7250,S7250D added (UFL)
SeDBx
v2.0.9.0
1. Updated Drivers Support.
v2.0.8.0
DB2010
1. Added Support for: 36Brown, 49Brown
DB2012
1. Added Support for: 50Brown, 51Brown, 51Red, 53Red.
2. Added CID Upgrade.
DB2020
1. Added Support for: 49Brown.
2. Loaders Updated.
PNX5230
1. Added Support for: 49Brown, 52Brown.
2. Loaders Updated.
LG_GSM
v 2.3.0.0
1. Infineon Egold Boot Fixed (was broken in v 2.2.0.3)
2. Infineon E500,KM553,KM555,KM555e,KM555g,KM555R added (FL,CUL)
3. Infineon GT370,GU230GO,S367 added (FL,CUL,DUL,IM)
4. Infineon T370,T375,T385,T385b,T395,T500GO,T505GO,T565,
T565b,T575 added (FL,DUL)
5. MTK: A290 added (FL,3xIM)
6. MTK: USB Support for UI Functions (Select COM on Phone)
7. WiFi MAC Address Write Added for Infineon and MTK platforms.
The Following 10 Users Say Thank You to zishhaider For This Useful Post:
Old 07-30-2013, 19:02   #7 (permalink)
Member: 1517419
Thanks Meter: 7
thanks for usf teem
all is ok
thanks
Old 07-30-2013, 19:24   #8 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
Originally Posted by RATHISH.TR_ALUVA View Post
shani..
have you tested.
No, This Work old box u can try and post result if face any problem contact me PM sonork or yahoo or skype or u can call me anytime +923234741515
GSM.SOLVE
The Following User Says Thank You to GSM.solve For This Useful Post:
Old 07-30-2013, 21:20   #9 (permalink)
Member: 1500825
Thanks Meter: 21
dont work for me here is log
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 76239
LIC5: True
BOXK: 0
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 76239
HID: , HWK:
HWK: NOT AUTHORISED, Update Box
Bad IX: ABCD
Failed: -6
The Following 4 Users Say Thank You to iiandry For This Useful Post:
Old 07-30-2013, 21:48   #10 (permalink)
Member: 202306
Thanks Meter: 13
detect virus by avast
The Following 2 Users Say Thank You to nacino For This Useful Post:
Old 07-31-2013, 07:57   #11 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
Do Not use antvirus for flashing
Old 07-31-2013, 08:02   #12 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
SERN: 76239
LIC5: True
BOXK: 0
HID: , HWK:
Bad IX: ABCD
Failed: -6
Try again and intall drivers again.
The Following 3 Users Say Thank You to GSM.solve For This Useful Post:
Old 07-31-2013, 08:04   #13 (permalink)
Member: 1403596
its not working in old box for me pls help
The Following User Says Thank You to flyingarrow78 For This Useful Post:
Old 07-31-2013, 08:19   #14 (permalink)
bijayprusti's Avatar
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
i am updating but its showing you have 148 items to update
The Following User Says Thank You to bijayprusti For This Useful Post:
Old 07-31-2013, 08:35   #15 (permalink)
Member: 1770085
Sonork: 100.1639467
Thanks Meter: 43
Thank you so much [IMG][/IMG]
The Following 5 Users Say Thank You to bijayprusti For This Useful Post:
Page generated in 0.24618 seconds with 9 queries
