Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 01-11-2012, 02:11   #16 (permalink)
Member: 1711273
I have locked and unlocked the mobile many times with various firmwares except the original no one has worked even with adequate dashboard apps. I had unlocked and always used in ubuntu very well. The problem is that it just connects and *no data transfer or very very less -~1kbps when it happens*. Dashboard shows up wcdma and gsm network only. connects as both wcdma and edge but never seen or connected in HSDPA. I wonder why and this may be (one) of my problem. Sim in mobile s*****s around 6.8mbps but datacard is unusable sadly. my primary mobile shifted to a 1000 Rupee mobile when my smartphone uses data only sim !!! Did reset in huawei modem tools locked and unlocked many times, tried various dashboards . Its is very unlikely that my carrier does some trick with data card (for ~1kbps) with all firmwares (except the default came with). It's unlocked at present. I had flashed once with e173 firmware by mistake.
I was getting above mentioned speeds on datacad which even now i am getting on my handset. Datacard connects and mostly no transfer sometimes ~1kbps or so.
tested under linux and windows.
Old 01-11-2012, 10:34   #17 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1615688
Thanks Meter: 206
thaankssssssssssss a lottttttttttttttttt
Old 01-11-2012, 11:15   #18 (permalink)
Member: 1501765
thanks dear this is 10000000000000000% work i am tested
Old 01-11-2012, 11:17   #19 (permalink)
Member: 1501765
sir maine mobile patner dashboard update kar diya hai kya wo default airtel dashboard ho sakta hai
Old 01-11-2012, 12:52   #20 (permalink)
buntymurarka's Avatar
Member: 503911
Thanks Meter: 141
yes ho sakta hai
check this
http://forum.gsmhosting.com/vbb/f25/...3/#post7966075
Old 01-12-2012, 10:53   #21 (permalink)
Member: 1711273
I did another stupidity by updating some 1732 firmware which denies further firmware updates (message: The wireless terminal inserted is not Firmware).
A solution which i found is to run ubuntu in virtualbox and changing product id using modeswitch or so.
If there is another easier solution ?
whats the product id of E1731 (E173Bu-1)
please let me know the lsusb output.
Old 01-12-2012, 14:17   #22 (permalink)
Member: 1711273
my lsusb output is below
Bus 001 Device 006: ID 12d1:1003 Huawei Technologies Co., Ltd. E220 HSDPA Modem / E230/E270 HSDPA/HSUPA Modem
I want it back to e1731 ( i think product id is 140c)
usb modeswitch(1,1,9) fails to do so
Any suggestions!!!!
Old 02-03-2012, 17:53   #23 (permalink)
Member: 1293240
Thanks Meter: 11
thankssssssssssss sir
Old 02-11-2012, 21:45   #24 (permalink)
cellexpert's Avatar
Member: 857876
Sonork: cellexpert-33
Thanks Meter: 63
forum means a platform that connect all kind of mobile technetion, so should not money making thinking 4 all ever, give or ever take a solution.......................................... .................................
Old 02-14-2012, 16:33   #25 (permalink)
Member: 536212
zte dashboard
Originally Posted by buntymurarka View Post
Airtel E1731 with new firmware unlock solution 1st on net by me
Screen shots........
1) The modem with firmware 11.126.16.04.284 which is not supported with any tool
2) After Writing firmware E1731Update_11.126.15.00.00.B416 the modem is unlocked
3) Running any gsm sim.........
the modem is successfully unlocked
Procedure:
Generate flash code (if needed) and flash the modem with the firmware provided by me and no need to do anything else.......the modem is unlocked.
Download:
Firmware
If you like my post then press thanks
Add me on facebook
Facebook
bunty bhai can you have tata docomo zte mf 631 dashboard with all indian apn nirav has posted the dashboard but he not edit apn in dashboard he edit only his name
please send the post if you have
thank's
shailu soni
Old 03-11-2012, 23:33   #26 (permalink)
Member: 1732642
tks i will try / now download already
Old 04-07-2012, 22:33   #27 (permalink)
Member: 1732642
i can unlock and update the airtel modem as per this forum instruction.
tks alot bro. i bought airtel modem from tuticorin without sim pay 25 usd and now at spore
firstly i can not use here. this topic help me to unlock and working 100 percent.
good .
tks x 1000000000
Old 04-08-2012, 10:40   #28 (permalink)
Member: 481878
Talking it's worked ...thanx bro thank u so much........
Procedure:
Download:
Firmware
Add me on facebook
Facebook
Old 04-18-2012, 07:48   #29 (permalink)
Member: 1684169
Sonork: 940036562
Thanks Meter: 9
Procedure:
Download:
Firmware
Add me on facebook
Facebook
the source version isn't compatible with the target version, before updating, please input the passwor
password pls
huawei e1731
imei : 354369044370493
s\n : 8CA4CA11C2415266
Old 04-18-2012, 10:43   #30 (permalink)
Member: 1729065
Thanks Meter: 3
password pls
huawei e1731
put the imei in calculator then u will get the pass
huawei calculator.rar - 4shared.com - online file sharing and storage - download
The Following User Says Thank You to mob.mobile For This Useful Post:
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-05-2014 11:33
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-13-2014 15:30
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-25-2009 16:29
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.36955 seconds with 8 queries
