Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
11-02-2011, 05:42 | #1 (permalink) |
Junior Member Join Date: May 2010
Member: 1303485 Status: Offline Thanks Meter: 5 | GSM Secret Codes GSM Secret Codes Type *#61# and press call - Check redirection status. Cancel all redirections: ##002# *43# to activate call waiting, to deactivate #43#. If your phone doesn't have incoming call barring and outgoing call barring, you can try this. For outgoing call barring dial *33*barcode*# and pres OK. To deactivate it dial #33#barcode*#. On any phone on any network type in **43# to enable conference calls. You can make up to 7 calls at once If you need to block SMS reception (if you are spammed by someone) just press this code: *35*xxxx*16# xxxx is your Call Barring code (default is 0000). To remove this barring type: #35*xxxx# If you want to hide/show your phone number when calling, put one of these codes below in front of the number that you are going to call. (*#30# / *#31# or *31# / #31# ) Works on some networks. Typing *0# or *nm# on the beginning of a txt message gives you detailed delivery report on some networks.. But turn off reports in message settings before. When the sim card-pin blocked type **042*pin2 old*newpin2*newpin2* Airtel Secret Codes Dial *123# to see your credit balance. Dial *110# and follow the options. Dial *109*9898631902# to display the call cost after each call. If you are in Indiausing IDEA Pre or Postpaid connection then dial *101# you will get a secret menu that will let you to activate or deactivate any supported Idea package for your mobile. Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: *#9998*324# - *#8999*324# LCD kontrast: *#9998*523# Vibration test: *#9998*842# - *#8999*842# Alarm beeper - Ringtone test : *#9998*289# - *#8999*289# Smiley: *#9125# Software version: *#0837# Display contrast: *#0523# - *#8999*523# Battery info: *#0228# or *#8999*228# Display storage capacity: *#8999*636# Display SIM card information: *#8999*778# Show date and alarm clock: *#8999*782# The display during warning: *#8999*786# Samsung hardware version: *#8999*837# Show network information: *#8999*638# Display received channel number and received intensity: *#8999*9266# *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error LOG Menu *#8999*327# EEP Menu *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version Type in *#0000# on a Samsung A300 to reset the language Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710) Samsung E700 type *#2255# to show secret call log (not tested) Samsung A300, A800 phone unlock enter this *2767*637# Samsung V200, S100, S300 phone unlock : *2767*782257378# http://premgsm.info/index.htm |
11-02-2011, 05:45 | #2 (permalink) |
Member: 1303485 Status: Offline Thanks Meter: 5 | LG all models test mode: Type 2945#*# on the main screen. LG all models test mode: Type 2945#*# on the main screen. 2945*#01*# Secret menu for LG IMEI (ALL): *#06# IMEI and SW (LG 510): *#07# Software version (LG B1200): *8375# Recount cheksum (LG B1200): *6861# Factory test (B1200): #PWR 668 Simlock menu (LG B1200): 1945#*5101# Simlock menu (LG 510W, 5200): 2945#*5101# Simlock menu (LG 7020, 7010): 2945#*70001# Simlock menu (LG 500, 600): 2947#* LG-U81XX SPECIAL CODES Code to read phone version : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'SW Ver.info' Code to reset phone : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'Factory Reset' Code to enter UNLOCK MENU : - Phone wit SIM inside - Enter 2945#*88110# Test Menu 8330 : 637664#*# Test Menu 8180 V10a: 49857465454# Test Menu 8180 V11a: 492662464663# Test Menu 8130-8138: 47328545454# Test Menu 8110-8120: 277634#*# |
11-02-2011, 05:46 | #3 (permalink) |
Member: 1303485 Status: Offline Thanks Meter: 5 | .:: NOKIA ::.Universal Codes .:: NOKIA ::.Universal Codes Code Description : These Nokia codes will work on most Nokia Mobile Phones (1) *3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced by approx. 5% (2) #3370# Deactivate Enhanced Full Rate Codec (EFR) OR *3370# ( Favourite ) (3) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time. (4) *#4720# Deactivate Half Rate Codec. 5) *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type. ( Favourite ) (6) *#9999# Phones software version if *#0000# does not work. (7) *#06# For checking the International Mobile Equipment Identity (IMEI Number). ( Favourite ) (8) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). (9) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). (10) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). (11) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). (12) *#147# (vodafone) this lets you know who called you last. (13) *#1471# Last call (Only vodofone). (14) *#21# Allows you to check the number that "All Calls" are diverted to (15) *#2640# Displays security code in use. (16) *#30# Lets you see the private number. (17) *#43# Allows you to check the "Call Waiting" status of your phone. (18) *#61# Allows you to check the number that "On No Reply" calls are diverted to. (19) *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to. (20) *#67# Allows you to check the number that "On Busy Calls" are diverted to. (21) *#67705646# Removes operator logo on 3310 & 3330. (22) *#73# Reset phone timers and game scores. (23) *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible. 24) *#7760# Manufactures code. (25) *#7780# Restore factory settings. 26) *#8110# Software version for the nokia 8110. (27) *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again. (Favourite ) (28) *#94870345123456789# Deactivate the PWM-Mem. (29) **21*number# Turn on "All Calls" diverting to the phone number entered. (30) **61*number# Turn on "No Reply" diverting to the phone number entered. (31) **67*number# Turn on "On Busy" diverting to the phone number entered. (32) 12345 This is the default security code. press and hold # Lets you switch between lines IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off] Half Rate: * 4 7 2 0 # Provider lock status: #pw+1234567890+1 Network lock status #pw+1234567890+2 Provider lock status: #pw+1234567890+3 SimCard lock status: #pw+1234567890+4 NOKIA 6110/6120/6130/6150/6190 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off] Half Rate: * 4 7 2 0 # NOKIA 3110 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # or * # 9 9 9 9 # or * # 3 1 1 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # NOKIA 3330 *#06# This will show your warranty details *#92702689# *3370# Basically increases the quality of calling sound, but decreases battery length. #3370# Deactivates the above *#0000# Shows your software version *#746025625#This shows if your phone will allow sim clock stoppage *4370# Half Rate Codec activation. It will automatically restart #4370# Half Rate Codec deactivation. It will automatically restart Restore Factory Settings To do this simply use this code |
The Following User Says Thank You to ataur.rahman123 For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
