Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
09-04-2004, 15:35 | #1 (permalink) |
Junior Member Join Date: Sep 2004
Member: 80571 Status: Offline Thanks Meter: 0 | Sendo M550 Blocked Is There Any Software? I Dont Have A Cable. Can 1 Of U Guy Plz Put Exactly What I Would Need Cheers Zack |
09-05-2004, 10:10 | #3 (permalink) |
Junior Member Join Date: Aug 2004 Age: 45
Member: 78807 Status: Offline Thanks Meter: 0 | If you use Angel Soft, Imei of your phone will be changed. If you (or somebody else) tried to enter NCK code, several times it is immposibile to unlock phone useing for Example Griffin Crd, wich one is reading Log, and calculating codes. But still there is: DELOK ALL SENDO... You can unlock, flash and do anything you want to do with your sendo... Best Regards Isakovic |
09-07-2004, 12:14 | #8 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | if you need free soft fpr M550 see her you find good soft worked bt me tested il all M550 http://www.gsm-solution.com.vn/forum...?p=348#post348 |
09-11-2004, 19:38 | #10 (permalink) |
No Life Poster Join Date: Nov 2001 Location: morocco larache Age: 51
Member: 7334 Status: Offline Sonork: 100.112291 Thanks Meter: 47 | go to my yahoogroup and you got the solution...http://groups.yahoo.com/group/keyb_king29/files/sendo/ and the cable is :gd 35 data cable tested by me.... |
Sendo M550 Blocked | AbdulKadir | Multi-Box | 7 | 06-08-2007 16:42 |
have a prob with attaching Sendo m550 with sendo module. | monsterpassword | ThunderStorm Box | 3 | 03-06-2007 22:09 |
Sendo M550 (SFR) Blocked !!!! | GSM SNIPER | Various | 7 | 03-25-2005 14:14 |
sendo m550 blocked | SilentKiller | Various | 3 | 01-25-2004 13:44 |
How unlock sendo m550. I buy solution | JAMLU | Various | 0 | 07-30-2003 10:27 |
