Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
07-25-2006, 23:36 | #1 (permalink) |
Banned Join Date: Jun 2006 Location: Z-LanD
Member: 294953 Status: Offline Sonork: 100.1576570 Thanks Meter: 230 | Here *** ALL THE SECRET CODES *** 4 all gsm *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*289# : Change Alarm Buzzer Frequency *#9998*324# : Debug screens *#9998*364# : Watchdog *#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok. *#9998*427# : Trace Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*544# : Jig detect *#9998*636# : Memory status *#9998*746# : SIM File Size *#9998*778# : SIM Service Table *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# : Run, Last UP, Last DOWN *#9998*837# : Software Version *#9998*842# : Test Vibrator - Flash the screenligth during 10 seconds and vibration activated. *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*872# : Diag *#9998*947# : Reset On Fatal Error *#9998*999# : Last/Chk *#9998*9266# : Yann debug screen (=Debug Screens?) *#9998*9999# : Software version If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0002*?# : unknown *0003*?# : unknown SP-unlock SGH-600 (and also SGH-Sgh-600) *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 for d500 *#11[QUOTE]11# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error Menu *#8999*327# EEP Menu *#8999*3825523# Don't Know. *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version #*4773# Incremental Redundancy #*7752# 8 PSK uplink capability bit #*7785# Reset wakeup & RTK timer cariables/variables #*1200# ???? #*7200# Tone Generator Mute #*3888# BLUETOOTH Test mode #*#8999*324# ?? #*7828# Task screen #*5111# ?? #*#8377466# S/W Version & H/W Version #*2562# Restarts Phone #*2565# No Blocking? General Defense. #*3353# General Defense, Code Erased. #*3837# Phone Hangs on White screen #*3849# Restarts Phone #*3851# Restarts Phone #*3876# Restarts Phone #*7222# Operation Typ: (Class C GSM) #*7224# !!! ERROR !!! #*7252# Operation Typ: (Class B GPRS) #*7271# CMD: (Not Available) #*7274# CMD: (Not Available) #*7337# Restarts Phone (Resets Wap Settings) #*2787# CRTP ON/OFF #*2886# AutoAnswer ON/OFF #*3737# L1 AFC #*5133# L1 HO Data #*7288# GPRS Detached/Attached #*7287# GPRS Attached #*7666# White Screen #*7693# Sleep Deactivate/Activate #*7284# L1 HO Data #*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt) #*2286# Databattery #*2527# GPRS switching set to (Class 4, 8, 9, 10) #*2679# Copycat feature Activa/Deactivate #*3940# External looptest 9600 bps #*4263# Handsfree mode Activate/Deactivate #*4700# Please use function 2637 #*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF) #*2558# Time ON #*3370# Same as 4700 #*3941# External looptest 115200 bps #*5176# L1 Sleep #*7462# SIM Phase #*7983# Voltage/Freq #*7986# Voltage #*8466# Old Time #*2255# Call Failed #*5187# L1C2G trace Activate/Deactivate #*5376# DELETE ALL SMS!!!! #*6837# Official Software Version: (0003000016000702) #*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07) #*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01) #*2337# Permanent Registration Beep #*2474# Charging Duration #*2834# Audio Path (Handsfree) #*3270# DCS Support Activate/Deactivate #*3282# Data Activate/Deactivate #*3476# EGSM Activate/Deactivate #*3676# FORMAT FLASH VOLUME!!! #*4760# GSM Activate/Deactivate #*4864# White Screen #*5171# L1P1 #*5172# L1P2 #*5173# L1P3 #*7326# Accessory #*7683# Sleep variable #*8465# Time in L1 #*2252# Current CAL #*2836# AVDDSS Management Activate/Deactivate #*3877# Dump of SPY trace #*7728# RSAV #*2677# Same as 4700 #*3797# Blinks 3D030300 in RED #*3728# Time 2 Decod #*3725# B4 last off #*7372# Resetting the time to DPB variables #*7732# Packet flow context bit Activate/Deactivate #*6833# New uplink establishment Activate/Deactivate #*3273# EGPRS multislot (Class 4, 8, 9, 10) #*7722# RLC bitmap compression Activate/Deactivate #*2351# Blinks 1347E201 in RED #*4472# Hysteresis of serving cell: 3 dB #*2775# Switch to 2 inner speaker #*9270# Force WBS #*7878# FirstStartup (0=NO, 1=YES) #*3757# DSL UART speed set to (LOW, HIGH) #*8726# Switches USBACM to Normal #*8724# Switches USBACM to Generator mode #*8727# Switches USBACM to Slink mode #*8725# Switches USBACM to Loop-back mode #*3838# Blinks 3D030300 in RED #*2077# GPRS Switch #*2027# GPRS Switch #*0227# GPRS Switch #*0277# GPRS Switch #*22671# AMR REC START #*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr) #*22673# Pause REC #*22674# Resume REC #*22675# AMR Playback #*22676# AMR Stop Play #*22677# Pause Play #*22678# Resume Play #*77261# PCM Rec Req #*77262# Stop PCM Rec #*77263# PCM Playback #*77264# PCM Stop Play #*2872# CNT *#8999*283# ??? #*22679# AMR Get Time *288666# ??? *2886633# ??? *#8999*364# Watchdog nokia cdma *3001#12345# LG CDMA SECRETS CODES Field Test MENU > 0 > 000000 > Field Test Other Programming Secrets: LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user. A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LG1010, LG4NE1, TP2200, TP2100, Touchpoint, SB/DB, TP1100 and TP5200 Press ## Enter the OTKSL Scroll to SAVE and press OK Scroll to MIN and press OK Enter 10 digit MIN scroll to SAVE and press OK Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete) Enter SID (4654) and scroll to SAVE and press OK Programming is complete LG5350 Enter ## and enter the OTKSL and press the left soft key under the word “Save” At the Service Program display select Mobile Phone # and press the OK in the center of the 4 way navigation key Enter the 10 digit MIN and press OK Scroll down to 4. Advanced and press OK Scroll to NMSI and press OK Enter the MSID and press OK Scroll down to 9. Amps Phone # and press OK Enter the MSID and press OK Press the END key MOTOROLA PROGRAMING CODES Analog Models Changing the Banner: #PROGRAM# or [Fcn] 0000000000000 (13 0's) Field Test: [Fcn] 0 0 * * TESTMODE [Sto] Reset Timers: Follow the Field Test procedure above and then #32# Alternative Programming Menu: #55# (Not sure): # [SID code]#* SEND Programming of various other models: V60c Programming Mode: 74663 # [Menu] [Menu] (you will need the programming code) Field Test: [Menu] 073887 * (you will need the security code -- try 000000) To deactivate field test: Power phone up, hit MENU and the left button (should bring up the menu). There's a menu option for test-mode and at this point you can turn the menu off and return the phone to normal. Alternatively press menu and then the nearest button to the left (Phone book button) quickly and it will take you back to the main screen and your phone will look normal. StarTac 7790 Field Test: [Fcn] 0 0 * * TESTMODE [Sto] StarTac 7760, 7860 Field Test: [Fcn] 0 0 * * TESTMODE [Sto] Service Menu: [Fcn] 0 000000 000000 RCL Complete system test (most models): (Phone OFF), Hold down any row of keys (1+2+3, 4+5+6, etc) and turn the phone ON To access the diagnostic mode on the I30: #, *, MENU, JOYSTICK-RIGHT (Do these keystrokes fast) To access the diagnostic mode on any of the older iDEN phones (pre-i1000): VOLUME DOWN, MENU, MENU, MENU, LEFT, MENU, MENU, LEFT (this is the reverse of the test menu routine) To access the diagnostic mode on any of the new models (i1000+, i700+, i550+, etc): Hold down any three keys in a row across. The unit will enter the test mode and can be stepped through the various functions with the keys and buttons. At the end of the test, power cycle the unit to return to normal function. This test will check various phone functions, including LCD display, speaker, earphone, microphone, LEDs, vibrator, backlight and all of the buttons and keys for the newer models SAMSUNG CDMA SECET CODES Older Models: NAM Programming: 47*869#08#9 Test mode: *759#813580 OR 5809540*45680 Exit Test Mode: 02 A-Key: menu + 0, code 25## Samsung SPH-T100 MENU 820 > 810325 Samsung SCH-3500 MENU 820 > 295184 Programming of various other models: Samsung A500 Enter ## and the 6 digitOTKSL SERVICE MENU will appear and 1.Basic will be highlighted Press OK Device will display NAM CDMA/ Phone Number Enter 10 digit MIN Press OK (3 times) Display will return to Service Menu. Press END. Programming is complete Samsung N240 and N400 Enter ## and type in the 6 digit OTKSL The display will show SVC MENU and 1. Phone Number Press OK Enter the 10 digit MIN and press OK The display will show NAM with Home SID on the second line (Note: SID is no longer used) Press OK The display will return to the SVC MENU Press END to complete the programming Samsung N300 Press ## followed by the OTKSL SVC menu will be displayed Press 1 for Phone # Enter the 10 digit MIN and press OK MIN that was entered will be displayed press OK SVC Menu will display press 3 for NAM Enter the 4 digit Home SID press OK Press END and handset will power cycle Samsung i300 Tap on the Phone Icon with stylus Press #907*9#0 ENTER LOCK should appear on screen ENTER OTKSL SVC MENU will appear press 1 Enter 10 digit MIN and then press SAVE Press SAVE again Press 3 and then press SAVE 6 times Enter the HOME SID and press SAVE once Press END key twice Samsung A400 and A460 Enter ## and OTKSL Press 1 for Basic at MENU (1 of Phone # when using the MSL) Enter 10 digit MIN and press OK At 1.Basic Menu press the END key Handset will power cycle Samsung 3500, 8500, 6100, and N200 Press MENU Press 6 0 (3500) 8 2 0 (8500/6100/N200) Enter OTKSL Press 1 at SVC MENU Screen Enter MIN and press OK Press OK 4 times Enter SID (4654) and press OK Press END key Programming is complete gsm NOKIA SECRET CODES Nokia CodesThese Nokia codes will work on most Nokia mobile phones, however we accept no responsibility of any kind for damage done to your phone whilst trying these Nokia secret codes. Nokia code Code function *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# With this Nokia code you can deactivate the Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) GSM SAMSUNG SECRET CODES *#06# -> Show IMEI *#9999# -> Show Software version *#0837# -> Show Software Version (instructions) *#0001# -> Show Serial Parameters *#9125# -> Activates the smiley when charging. *#9998*228# -> Battery status (capacity, voltage, temperature) *#9998*246# -> Program status *#9998*289# -> Change Alarm Buzzer Frequency *#9998*324# -> Debug screenslect values. Cancel and ok. *#9998*427# -> Trace Watchdog *#9998*523# -> Change LCD contrast - Only with version G60RL01W *#9998*544# -> Jig detectService Table *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put inmemory error. *#9998*786# -> Run, Last UP, Last DOWN *#9998*837# -> Software Version *#9998*842# -> Test Vibrator - Flash the screenligth during 10 seconds and vibrationactivated. *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*872# -> Diag *#9998*947# -> Reset On Fatal Error *#9998*999# -> Last/Chk *#9998*9266# -> Yann debug screen (=Debug Screens?) *#9998*9999# -> Software version *0001*s*f*t# -> Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0002*?# -> unknown *0003*?# -> unknown SP-unlock SGH-600 and SGH 2100 *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0 *2767*2878# -> Custom EEEPROM Reset These codes has been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 type 8889 instead of 9998. GSM MOTOROLA SECRET MOBILE CODES Motorola IMEI number: * # 0 6# Net Monitor ON: * * * 1 1 3 * 1 * [OK] Net Monitor OFF: * * * 1 1 3 * 1 * [OK] * - press this until box shown up To activate RBS: (pause means the * key held in until box appears) [pause] [pause] [pause] 1 1 3 [pause] 1 [pause] [ok] You now have to press the [MENU] and scroll to the 'Eng Field Options' function with the keys, and enable it. To de-activate RBS, [pause] [pause] [pause] 1 1 3 [pause] 0 [pause] [ok] This only works with some versions of software. Please report what works and doesn't for you. Reported working, by country: d460: IT 6200 Flare: UK (Orange), AU 7500: IT (model: F16 HW: 5.2 SW: 2.1) 8200: ES, AU, NL, BE 8400: IT, NL 8700: AU, IT, SG, DE, ES, ZA Uses of RBS: Distance From Base Station - Place a call, when it is answered, press [MENU] until 'Eng Field Option' is displayed, press [OK], select 'Active Cell', press [OK], press [MENU] until 'Time Adv xxx' appears, where xxx is a number. Multiply this number by 550, and the result is the distance from the RBS (Radio Base Station), in meters. Signal Quality - press [MENU] until 'Eng Field Option' is displayed, press [OK], select 'Active Cell', press [OK], press [MENU] until 'C1' appears. This is the signal quality. If it becomes negative for longer than 5 seconds, a new cell is selected. SONY ERICSSON SECRET CODE General Secrets IMEI (International Mobile Equipment Identity): *#06# Firmware Version: >*<<*<* Programming Checks: >*<<*<*> or >*<<*<*> Accessing the phone without a SIM card: **04*0000*0000*0000# then on 'Wrong Pin' No Reset English Menu: *#0000# 300, 600, 700 Series Programming Menu (Short): 987 + > Programming Menu (Long): 923885 + > Field Test: 904090 + > (to exit 904090 + >) Phone Test: 904059 + > (to exit 3 + <) Phone Reset: 904060 + > CDMA Mode: 904093 + menu Analog Mode: 904095 + menu DM mode 904959 + menu GSM PHILIPS SECRET CODES Philips GENIE To view IMEI number *#06# *#2254*# is the statusregister: C, BS, RR, MMI, CREAT. *#2255*# will activate and deactivate the "DEBUG CALL"-Mode *#2558*# will display the time in days,hours and minutes you are connected to the GSM network To force a reconnection to the network, type : *#2562*# To view and modify the Security Code of the phone, type: *#7489*# To view some info about your SIM card like the phase level, the name, type: *#7378*# To obtain information on SIM lock, Init and Flags, press: *#3377*# To activate or deactivate Sleep Mode: *#7693*# To get info about Sleep Mode: *#8463*# Philips FIZZ IMEI: *#06# Lock Code: *#1234# Software Version To find software version, enter *#8377*# The output will look something like: Version : 0916 - EEPROM : 00000000-00 - TDA : 2445 - KISS : 0502 SIM-LCK ..or extended software version *#5644*# output: Version : 09162205 - EEPROM : 00000000-00 - TDA : 2445 - KISS : 0502 SIM-LCK SM ALCATEL SECRET MOBILE CODES ALCATEL * # 0 6 # : IMEI number * # 0 6 # : Software version 0 0 0 0 0 0 * : Net Monitor PINOUTS AND CODES FOR PANASONIC MOBILES Panasonic G500 IEMI: To view IMEI number *#06# -------------------------------------------------------------------------------- PINOUTS 1 - Ground 2 - TX_Audio 3 - Audio_Ground 4 - HF_ON (L=ON) -> L=H/F ON 5 - AOP_Sense <- Data Adaptor Select 6 - Serial_Up <- UART up (9600,33.8kbps) 7 - Serial_Down -> UART down 8 - External_Power <- POWER FOR CHARGING 9 - Ground 10 - RX_Audio 11 - Radio_Mute -> L=MUTE 12 - HF_Sense <- L=H/F MODE 13 - Reserved L=FLASH WRITE ENABLE 14 - Ignition <- H=ON 15 - Logic_Power -> H=HANDSET ON 16 - PAON -> Power Amplifier Control Signal. ************************************************** ** Nokia 3310 Secret codes Jul, 08 2003 - 06:20 contributed by: mef *#06# To find IMEI (International Mobile Equipment Identity) *#7780# Restores Factory Settings..(Memory, language, counters not included) *#3110# For checking the phone's software (SW) - called firmware revision information. *#746025625# [*#sim0clock#] To check if the Sim-Clock can be Stopped (Sim-clock-stop is a kind of standby mode which will save battery time) *#92702689# [*#war0anty#] Phone asks 'warranty code:' 6232 (OK) Displays the Month and Year of Manufacture 9268 (OK) Displays Serial Number 7332 (OK) Displays the date of the last repairment - if found 7832 (OK) Displays (if found) the date where the phone was purchased 37832 (OK) Set the Purchasing Date MMYY (This date can be set only once!) 87267 (OK) Transfers ALL phone numbers, Logo's, and ringtones from other gsm phones Nokia 101 cell phone lockcode Jul, 10 2000 - 02:35 Nokia 101 cell phones set up by Bell Mobility in Toronto can have their lock code circumvented by the following method: Type: * 3001 # 12345 [STO] 00 Wait for: NOT DONE Type: [RCL] 01 Clear old lock code (the last four digits) and enter a new lock code. Be very careful not to delete other characters. Type: [STO] 01 [STO] Turn power off. Nokia 9000/9000i Nov, 25 2000 - 22:41 To view IMEI number *#06# To view Software Version enter *#8110# Latest Version is under Phone Info. To view Week and Year of manufacture enter *#3283# Samsung SGH-600 / SGH-2100 Secret Codes *#06# -> Show IMEI *#9999# -> Show Software Version *#0837# -> Show Software Version (instructions) *#0001# -> Show Serial Parameters *#9125# -> Activates the smiley when charging. *#9998*228# -> Battery status (capacity, voltage, temperature) *#9998*246# -> Program status *#9998*289# -> Change Alarm Buzzer Frequency *#9998*324# -> Debug screens *#9998*364# -> Watchdog *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok. *#9998*427# -> Trace Watchdog *#9998*523# -> Change LCD contrast - Only with version G60RL01W *#9998*544# -> Jig detect *#9998*636# -> Memory status *#9998*746# -> SIM File Size *#9998*778# -> SIM Service Table *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN *#9998*837# -> Software Version *#9998*842# -> Test Vibrator - Flash the screenligth during 10 seconds and vibration activated. *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*872# -> Diag *#9998*947# -> Reset On Fatal Error *#9998*999# -> Last/Chk *#9998*9266# -> Yann debug screen (=Debug Screens?) *#9998*9999# -> Software version *0001*s*f*t# -> Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0002*?# -> unknown *0003*?# -> unknown SP-unlock SGH-600 and SGH 2100 *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0, To restore your old IMEI use the IMEI program found on the software page. *2767*2878# -> Custom EEEPROM Reset These codes has been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung 811 Jul, 08 2000 - 01:24 47*869#08#9 - unlock code / change roaming code / ID SIEMENS S1 / S3 / S3 COM / S4 To view the software date and else with S3 com, S4, S4Power press with SIM removed *#06# and left softkey. To view some other stuff with S4Power press with SIM removed *#06# and left softkey twice. To view the software date with S3 com, S4, S4Power press with SIM installed menu 98 and left softkey twice. ACTIVATE MONITOR MODE Siemens S1/S3 Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, HangUp Button (Red HandSet key) Siemens S3 COM/S4 Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, HangUp Button (Red HandSet key) Note: Now Monitor should appear at the bottom of the Network Options menu. MONITOR MODE Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals. Test Mode Indicators: (* = only available when call in progress ) CH Channel Number RX Signal Strength (dB) N NCC (Colour Code) B BCC (Colour Code) CI Cell ID (in Hex) C1+ How long before phone does forced hand over.(see RX and RXAM) LAI Location Area Identity. Display Network ID code(42F010 = 240.01) and MSC TXPWR Transmit Power (dB) RXAM Receive signal strength cut-off point TS* Time Slot Number TA* Timing Advance. Distance from tower in Km X 2 PL* Power Level SIEMENS S1 Here's a trick to play Tetris, also known as Klotz on a Siemens S1. Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps. 1: Choose F 9 (function settings) 2: Choose send own number and push the right button for choose. 3: Push 9 USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4. I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparantly someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all. |
The Following 16 Users Say Thank You to Z-RocK For This Useful Post: |
07-25-2006, 23:41 | #2 (permalink) |
Member: 294953 Status: Offline Sonork: 100.1576570 Thanks Meter: 230 | Siemens C 25 Secret Codes SP unlock *#0003*(secret code 8 digits)# *#06# for checking the IMEI (International Mobile Equipment Identity) Resets language to automatic selection : * # 0000 # then Green button Pin Out 1- GND 2- SB 3- POWER 4- NC 5- TX 6- RX 7- CLOCK 8- DATA 9- GND MIC 10- HF MIC 11- AUDIO 12- GND AUDIO Sagem MC959 Secret Codes MC959 in main menu press * for hot-menu: lcd, led, vibra, tests, imei, software versions, battery voltage Type MENU - 5 - 1 - 1 - # to enter Engineering menu on SAGEM (RC-712, 721, 815 and 815 plus) phones. Panasonic G500 IEMI: To view IMEI number *#06# -------------------------------------------------------------------------------- PINOUTS 1 - Ground 2 - TX_Audio 3 - Audio_Ground 4 - HF_ON (L=ON) -> L=H/F ON 5 - AOP_Sense <- Data Adaptor Select 6 - Serial_Up <- UART up (9600,33.8kbps) 7 - Serial_Down -> UART down 8 - External_Power <- POWER FOR CHARGING 9 - Ground 10 - RX_Audio 11 - Radio_Mute -> L=MUTE 12 - HF_Sense <- L=H/F MODE 13 - Reserved L=FLASH WRITE ENABLE 14 - Ignition <- H=ON 15 - Logic_Power -> H=HANDSET ON 16 - PAON -> Power Amplifier Control Signal. Mitsubishi MT- D30 Secret Codes Monitor mode: Hold C and press 379 Secret menu: Hold C and press 987 Version number: Hold C and press 597 Phase1 and 2 : Hold C and press 499 Warm start : Hold C and press 179 Instant turn off: Hold C and press 999 Unlock menu: Hold C and press 787090 Mitsubishi Trium *#0000# to reset the phones menu-language to natural language, set initially by the distributor. *#06# for checking the IMEI (International Mobile Equipment Identity) hold * then 5806 - show software version hold * then 5807 - a littel bit diffrent hold * then 5472 - Testmode for datacable (it seems so) hold * then 4329 - Activate and deactivate NETMONITOR hold * then 621342 - Activate and deactivate another NETMONITOR hold * then 3926 - shutdown SP lock You can turn around the lock routin by entering **04*PIN*PIN*PIN# now the secretcode change was applied and the software turns back to main menue. It works not on all triums, only on thos with older sofware versions. SIEMENS S1 / S3 / S3 COM / S4 To view the software date and else with S3 com, S4, S4Power press with SIM removed *#06# and left softkey. To view some other stuff with S4Power press with SIM removed *#06# and left softkey twice. To view the software date with S3 com, S4, S4Power press with SIM installed menu 98 and left softkey twice. ACTIVATE MONITOR MODE Siemens S1/S3 Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, HangUp Button (Red HandSet key) Siemens S3 COM/S4 Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, HangUp Button (Red HandSet key) Note: Now Monitor should appear at the bottom of the Network Options menu. MONITOR MODE Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals. Test Mode Indicators: (* = only available when call in progress ) CH Channel Number RX Signal Strength (dB) N NCC (Colour Code) B BCC (Colour Code) CI Cell ID (in Hex) C1+ How long before phone does forced hand over.(see RX and RXAM) LAI Location Area Identity. Display Network ID code(42F010 = 240.01) and MSC TXPWR Transmit Power (dB) RXAM Receive signal strength cut-off point TS* Time Slot Number TA* Timing Advance. Distance from tower in Km X 2 PL* Power Level SIEMENS S1 Here's a trick to play Tetris, also known as Klotz on a Siemens S1. Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps. 1: Choose F 9 (function settings) 2: Choose send own number and push the right button for choose. 3: Push 9 USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4. |
The Following 18 Users Say Thank You to Z-RocK For This Useful Post: |
All Mobile Secret Codes Gift For All Mamber | kabul | Phone Unlocking Codes & Maps | 0 | 11-27-2008 21:24 |
all cdma secret codes | sainesh | Nokia CDMA | 9 | 08-07-2007 04:21 |
All FREE secrets codes in 1 sw. | micmac | Various | 53 | 01-16-2005 01:12 |
pleaseeee secret codes for telit g40 gsm phone | mailhassan | Phone Unlocking Codes & Maps | 0 | 03-10-2004 21:22 |
