Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various
Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it......
Old 04-23-2009, 02:22   #1 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,656
HOW To ENTER NETWORK UNLOCK CODES (many new Brands/Phones updated)
HOW TO ENTER NETWORK UNLOCK CODES
many new phones added hope it will be help
Blackberry
5xxx, 6xxx, 7xxx Series (except for BB 7100 and 7130)
  1. Turn wireless mode off
  2. Go to "Options" menu
  3. Go to "SIM card"then press the jogdial to select it
  4. Type MEPD (not case sensitive). You will not see text appear on screen while typing
  5. It will say "Network active"
  6. Press and hold the ALT key (half moon looking key on the lower left side)
  7. While holding the ALT key type in MEPE (not case sensitive). You will not see text appear on screen while typing
  8. When prompted enter supplied unlock code
  9. After entering the code press the jog dial
  10. Your phone is unlocked
Blackberry 7100, 7130
  2. While on the home screen click the "Tools" icon
  3. Go to "Options" menu
  4. Select "Settings"
  5. Go to "SIM card" then press the jogdial to select it. You should see the phone number and the SIM ID number
  6. Type MEPP2 (not case sensitive). You will not see text appear on screen while typing.
    Press ALT and 2 simultaneously to get number 2.
  7. Enter supplied unlock code
  8. After entering the code press the jog dial
  9. Your phone is unlocked
Blackberry 8100 Pearl
  1. Unlocking can be done without SIM card inserted
  2. Turn wireless mode off
  3. While on the home screen click the "Settings" icon
  4. Go to "Options" menu
  5. Select "Advanced options"
  6. Go to "SIM card" then press the jogdial to select it
  7. Type MEPP2. You will not see text appear on screen while typing
  8. Enter supplied unlock code
  9. After entering the code press the trackball once
    If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10 seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will be permanently blocked.
alternative instructions
  1. Insert SIM card into the device
  2. Power on the phone and turn Wireless Off
  3. Go to "Settings" then "Options" menu and select "Advanced options"
  4. Go to "SIM card" then press the jogdial to select it
  5. Type MEPPD. Please note that you will not see what you type on the screen.
  6. Type MEPP2. You will not see text appear on screen while typing
  8. After entering the code press the trackball once
alternative instructions for some Vodafone Blackberry 8100
  1. Insert non original SIM card into the device
  3. Go to "Settings" then "Advanced options"
  5. Type MEPP2 while holding Alt, multitap enabled (hold [Alt], type [M] [ER] [OP] [OP] [TY]. Please note that you will not see what you type on the screen.
  6. When prompted with "Enter Network MEP code (255 left)" on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter
  7. Pull the battery out of the phone
  8. Switch the phone on and the phone will be automatically unlocked
    To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call is possible when the phone is blocked.
Blackberry Curve, 8800, 8300
  4. Go to "Options" menu and select "Advanced options"
  5. Select "SIM card"
  6. Hold the ALT key while typing MEPE. You will not see text appear on screen while typing
  7. You should be presented with a prompt "Enter Network MEP Code"
  2. While on the home screen click the "Settings" icon
  3. Go to "Options" menu and select "Advanced options"
  4. Select "SIM card"
  5. While holding the ALT key type MEPD. You will not see text appear on screen while typing
  6. While holding the ALT key type MEPE. You will not see text appear on screen while typing
Blackberry 8700, 8700c, 8707
  1. Unlocking of these models requires a SIM card inserted (active or inactive)
Blackberry 8230 Curve
  1. Press the "menu" key
  2. Scroll and select "Manage connections"
  3. Select "Turn all connections off"
  4. Press "Escape" to go back to the "Home" screen
  5. Go to "Options" menu and select "Advanced options"
  6. Select "SIM card"
  7. Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a personalization menu
  8. Hold the ALT key while typing MEP2. You will not see text appear on screen while typing
  9. You should be presented with a prompt "Enter Network MEP Code"
  10. Enter supplied unlock code
  11. After entering the code press the trackball once
  12. Restart your phone and restore connections by following the first two steps
  13. Your phone is unlocked
Blackberry 9000, 9500, 9530 Storm
  1. Insert any sim card
  7. Select "Show keyboard"
  8. Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a personalization menu
  9. Hold the ALT key while typing MEP2. You will not see text appear on screen while typing
  10. You should be presented with a prompt "Enter Network MEP Code"
  11. Enter supplied unlock code
  12. After entering the code press the trackball once
  13. Restart your phone and restore connections by following the first two steps
  14. Your phone is unlocked
Sidekick / Hiptop
All models
  1. Insert a non accepted SIM card and turn on the Sidekick
  2. A dialogue screen will prompt you to enter the code:
    Title: Special Code Required
    Dialog: Enter code to enable SIM
    Box for Code: 1-8 digits
    Options: Enable or Cancel
  3. On you having entered the code a dialogue box will come up saying Authenticating code
    In case you see the “Waiting for Activation Screen”, hit the Menu key and the letter L key at the same time. The menu key is the top left key. By doing this, the waiting screen will go away and you will be able to make calls. For best results, hold down Menu and the L key until the Waiting for Activation screen disappears.
  4. Your Sidekick/Hiptop cell phone is now unlocked
Sierra wireless aircard
Windows XP and 2000 via Communication Manager
  1. Insert a non accepted SIM into PC Card and insert card into computer
  2. Launch the Communication Manager program. The prompt will display "Incorrect SIM"
    Note that you must have a generic Communication manager to be able to enter the code. If you you are using communication software from your provider you have to uninstall it and download the one from Sierra website directly.
  3. In the "Please enter special code" field, enter the 8 digit unlock code.
    If the message does not appear or "No SIM" is displayed, proceed to the HyperTerminal instructions.
  4. Press Send
  5. Your Sierra PC card is unlocked
Windows XP and 2000 via HyperTerminal
Use these instructions if the Communication Manager software is not installed on the computer or if the Communication Manager instructions did not work the first time.
  1. Identify COM Port:
  2. With PC card inserted in computer, go to the Start menu>Settings>Control Panel
  3. In the Control Panel, double-click on Phone and Modem Options
  4. Click the Modems tab and the modems installed on the laptop will be listed
  5. Locate the Sierra Wireless AirCard modem, and make note of the COM port in the "Attached To" column
  6. Close all Windows and return to the desktop
    1. Enter Unlock Code:
    2. With PC card inserted in computer, go to the Start menu>Programs>Accessories>Communications>HyperTerm inal Program
    3. In the Connection Description window, enter a name into the Name field and click OK. - Selection of an Icon is not required.
    4. In the Connect To window, leave the Phone Number blank.
    5. In the Connect Using field, select the COM port where the PC card (modem) is connected. Click OK. - Generally COM 1 is selected.
    6. Under Port Settings, select the "Bits per second" field to display 115200. Leave the default values in all of the other fields and click OK.
    7. Type ATE1 and press Enter. - An OK response will return
    8. Type AT+CLCK="PN",0,<8 digit unlock code> and press Enter. - An OK response will return
    9. The PC card is now unlocked.
Option Data Cards
  5. Locate the Option modem, and make note of the COM port in the "Attached To" column
  1. Verify that the card is unlocked:
  2. To verify card is unlocked, type 'ati'+clck="pn",2' and press Enter.
  3. If the command returns '0', then the card is unlocked.
Samsung
If you received two unlock codes the first one is Unfreeze code. The second code is Network Unlock Code (NCK). If you received only one code from us it's a Network Unlock Code (NCK).
How to remove Phone freeze
A frequent reason for Freeze Code to be enabled is when user enters several erroneous NCK codes.
If your cell phone shows a "Phone Freeze" message use the first code to unfreeze it. Enter the 8-digit code with SIM card in the phone when the "Phone Freeze" message is displayed, then press OK button (middle buttom, depending on phone branding can be called differently).
You can now proceede to entering Network Unlock Code.
How to enter Network Unlock Code
Samsung Z510, Z650, Z320i
  1. Power on without SIM card
  2. Type in **CODE# where CODE is the unlock code you received from XXXXXXXX
Samsung Z105 and Z107
  1. Power on with a non accepted SIM card
  2. Type in #7465625*638*CODE# (or *#7465625*638*CODE#) where CODE is the unlock code you received from XXXXXXXX
  3. Press the SEND key, display should read, "Personalization Cancelled"
Samsung 3G series, D, Z-series, some A-, C-, E-, T-, X-series, other models
Other Samsung models
  2. Phone will ask for "Password"
  3. Enter the unlock code you received from XXXXXXXX
    Note: In some instances the phone won't ask for "Password" - enter the unlock code anyway
OR if phone shows "Insert Correct SIM card"
  2. Type in #0111*CODE# where CODE is the unlock code you received from XXXXXXXX
i607 Blackjack
  1. Power on with incorrect (non accepted) SIM card, when asked to enter network pin enter provided unlock code.
    No need to hold other keys while entering code
    If you are unable to connect to the service provider or unable to make out-going calls or receive messages, this has nothing to do with your phone being locked. You need to force the Blackjack to change to GSM mode:
    1. Power on the phone
    2. Enter *#1546792*#
    3. Select Option 3 Network & Call Settings
    4. Select Option 5 Network Mode
    5. Select GSM
Quickfire
  1. Power off device and remove AT&T SIM card
  2. Insert SIM Card from another wireless carrier
  3. Power on the handset
  4. With the device in Portrait mode, tap the phone icon
  5. Dial *#865625# to enter the unlock code menu
  6. Display now says "TO UNLOCK SIM ENTER UNLOCK CODE CORRECTLY. FIVE (5) TIMES WILL RESULT IN THE PERMANENT LOCK OF YOUR PHONE CONTINUE?"
  7. Enter the 15-digit code given to you by, then tap DONE. If you entered an incorrect code, you will see the following message: "INCORRECT LOCK CODE" "INCORRECT UNLOCK CODE TRY AGAIN"
  8. If the code is correct, tap on DONE. The handset is now successfully unlocked
HP iPAQ
iPAQ 6320, 6325, 6510, 6515
  1. Power on phone with a non-original SIM card inserted
  2. Wait approximately 30 seconds until the SimLock application appears (the delay may be longer if the user has previously attempted to unlock with the wrong code)
  3. Enter your unlock code when prompted by the phone
  4. Press OK
  5. If the unlock code is correct, a success dialog will appear. Press OK
    If the unlock code is incorrect, an error dialog will appear. After pressing OK, the user has to re-enter the unlock code after a delay (see above in Device Specific Information)
iPAQ 6315
  1. On the Today screen, tap Start > Settings
  2. Tap the Phone band icon and choose " North America" or "Europe" or "Asia" phone band depending on where you are
  3. Tap the keyboard icon to open the virtual keyboard
  4. Tap Shift and then Ctl key to enable the keys
  5. Tap the blank area below the band selection box to open the unlock tool
  6. Tap Shift and then Ctl to disable the keys
  7. Enter the unlock code you received from XXXXXXXX, and tap OK when done
  8. Wait for the device to validate the unlock code (about five seconds). You will see one of the following screens:
    "Unlock successful"
    The device is now unlocked and should continue booting.
    "Unlock failed due to incorrect code"
    The user has three attempts to unlock. After three attempts, the device will refuse any more unlocking attempts. Perform a soft reset to reset the counter to perform additional unlocking attempts.
    "Your phone is not ready for unlocking"
    This error message displays when the user tries to unlock when the phone application (not the device) is not in a steady state. It takes 30 seconds after powering on the phone for it to reach a steady state.
Palm One
Treo 650, 680
  2. Turn wireless off
  3. It will then say "Your phone cannot be used with this SIM card" ("SIM not allowed" in case of Treo 650). Click OK
  4. Click dialpad tab, bottom of the screen far left
  5. Using stylus enter *#*#unlock code# and press the green button
  6. It will say "The sim lock has been removed from your phone"
  7. Your phone is unlocked
Treo 750
  3. Using onscreen keyboard enter the supplied unlock code
Sony Ericsson
All models
  1. Power on your phone without SIM card or with Original one
  2. Press joystick left once
  3. Press * twice
  4. Press joystick left once
  5. Phone will say "Personalize with MNC2" or "Personalized with MNC3"
  6. Wait approximately 5 seconds
  7. The display will indicate "Network" and a picture of a closed padlock
  8. Press Select
  9. The display will indicate "Unlock (Net) 5" and "NCK:"
  10. You can now enter the supplied unlock code
  11. Phone will display "Network unlocked" and then "Insert SIM" message
  12. Your phone is unlocked
    If your phone has a jogdial press it down instead of joystick left.
LG
LG F2250
  1. Power on phone with Orange SIM card inserted
  2. While in the Start menu type 2945#*3311#
  3. Return to the startup screen
  4. Press Menu key
  5. Select Settings > Security > Sim Lock > Network > Deactivate
  6. Enter supplied unlock code
LG U400
  1. Power on phone with an original (from the locked carrier) SIM card inserted
  2. Type 2945#*9636#
  3. The phone will then prompt "Unlock sim". Press "OK"
  4. The phone will then prompt "Network Unlock". Press "OK"
  5. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
  6. he phone will give you message "Succeess"
  7. Go back to the main screen and enter 2945#*88110#
  8. The phone will then prompt "Unlock sim". Press "OK"
  9. The phone will then prompt "Network Unlock/Lock" but if you scroll down you will see a message Enter SP Lock. Enter SP Code
  10. Then press "OK"
  11. Your phone is unlocked
LG U8110
  2. Type 277634#*#
  3. Select "Sim Unlock"
  4. Enter supplied unlock code
  5. Your phone is unlocked
LG U8150, other UMTS models
  2. Type 277634#*#
  3. Go to menu "SIM Lock"
LG U8210
  2. Type 277634#*#
  3. Go to "Sim Test" and type 2945#*#
  4. Select "Sim Unlock"
  5. Enter supplied unlock code
  6. Your phone is unlocked
LG CU400, CU500 Cingular AT&T
  2. Phone will display "Invalid SmartChip" If the phone doesn't display "Invalid SmartChip" power off and on, then try again
  3. Type 159753#*#
  4. Select "1 Unlock USIM", then "1 network lock"
  5. Phone will display "Enter NCK, Remaining 5"
  6. Enter the 8 digit unlock code
  7. Select "OK"
  8. Your phone is unlocked
LG CU575, CU515 Trax Cingular AT&T
  3. Type *#865625#
  4. Select option 1 and then again select 1
  5. Enter the supplied unlock code
LG CU720, TU720, other SHINE series
  2. Type *#865625#CODE where CODE is the unlock code provided by XXXXXXXX
  3. Select "OK"
    If this didn't work you can also try to repeat the above steps with a non-original SIM card inserted
LG CE110
  1. Prior to unlocking reset the phone to "Factory Default"
  2. Power on phone with a non-accepted SIM card
  3. Select "Cancel" - phone will displays "Phone restriction code"
  5. Select "OK"
LG CE500
  1. Power on phone with Cingular SIM card
  2. Type 2945#*7101#
  3. Select Settings > Security > Sim Lock > Network > Deactivate
LG KG275
  1. Power on phone with non original SIM card
  2. Type in the code you received from XXXXXXXX
  3. Press "Send" key
    If this didn't work append #*# to the end of the entered code
LG C3310
  2. Type 2945#*3311#
  3. Go to "Menu" and then to "Settings"
  4. Select "Security"
  5. Select "Network Provider" and then "Deactivate"
LG KE970 SHINE
  2. Press telephone icon at bottom of screen to bring up the phone keypad
  3. Type 2945#*990#
  4. A menu will pop up. Select "Sim unlock"
  5. Enter supplied unlock code and press "OK"
  6. The phone will then reboot
  7. Your phone is now unlocked
    or
  8. Power on phone with an original (from the locked carrier) SIM card inserted
  9. Type 2945#*9701#
  10. Press "Call"
  11. Enter the supplied unlock code when prompted
LG KE990, KU990 VIEWTY
  3. Type 2945#*990#
LG KF700 aka LG VIRGO
  2. Type 2945#*700#
  3. A menu will pop up. Select "Sim unlock"
  4. Enter supplied unlock code and press "OK"
  5. The phone will then reboot
  6. Your phone is now unlocked
LG KF750 aka LG SECRET
  2. Type 2945#*750#
LG KC550
  2. Type 2945#*71001#
LG KS360 aka QWERTY
LG KF755
  2. Type 2945#*755#
LG KF390
  2. Type 2945#*390#
LG KF600
  2. Type 2945#*600#
LG KS20
  2. Type 2945#*20# and 2945#*990#
LG KG245 Vodafone Australia
  1. Insert an original (from the locked carrier) SIM card and power on the phone
  2. Type 2945#*7101#. This will activate the extra menu
  3. Select "Settings" -> "Security" -> "Sim lock" -> "Network"
  4. Select "Deactivate"
  5. Enter the 8-digit unlock code and press "OK"
  6. Phone will display "Done"
LG KG800 CHOCOLATE, TG800 CHOCOLATE
  2. While in standby enter 2945#*5301#. This will activate the extra menu
LG T5100
  2. Type 2945#*5301#
LG C2200
  2. Type 2945#*2201#
LG G7020
  2. Type 2945#*70001#
LG C3100, C3380, F2300, KE260, KE970, KG120, KG220, KG240, KG280, KG290, KG800 CHOCOLATE, KU250, KU380, TG800 CHOCOLATE
    • LG C3100 press 2945#*3101#
    • LG C3380 press 2945#*7101#
    • LG F2300 press 2945#*7101#
    • LG KE260 press 2945#*2601#
    • LG KE970 press 2945#*9701#
    • LG KG120 press 2945#*1201#
    • LG KG220 press 2945#*1201#
    • LG KG240 press 2945#*3311#
    • LG KG280 press 2945#*7101#
    • LG KG290 press 2945#*7101#
    • LG KG800 press 2945#*7101#
    • LG KU250 press 2945#*250#
    • LG KU380 press 2945#*380#
  2. A Secret menu will appear
  3. Select "Settings", "Security" and then "Sim lock"
LG KU311, KU800, L600V, U8150, U8210, U8500
  1. Insert a non-original SIM card and power on the phone
    • LG KU311 press 815118#*#
    • LG KU800 press 82652#*#
    • LG L600v press 815118#*#
    • LG U8150 press 277634#*#
    • LG U8210 press 277634#*#
    • LG U8500 press 277634#*#
  2. Enter supplied unlock code and press "OK"
Motorola
  2. Enter unlock code when prompted
Warning!
If one of the followings messages appear
"Contact Service Provider"
"Tampert Alter"
"Wait before enter special Code"
"Contact Service"
Power on the phone and leave it for 40 minitues to 5 hours until you see the message "Enter Special Code"
Motorola 3G
  1. If your phone is on a 3G network enter **057*
  2. Then enter the unlock code into the window
Motorola CDMA & TDMA
  1. Press 74663 # [Menu] [Menu] and you will be asked for a subsidy code
  2. Enter the code you received from XXXXXXXX
  3. Your phone is now unlocked
Motorola MPX
  1. Switch ON your phone with a not allowed SIM card
  2. If phone is asking for NETWORK PIN enter the NETWORK PIN we sent you
  3. If phone is asking for SERVICE PROVIDER PIN. Enter the SERVICE PROVIDER PIN we sent you
  4. Your phone is now unlocked
If phone is asking for NETWORK PUK
  1. Power on the phone with the original card in and wait till phone is fully powered on and you have access to menu
  2. Type * # * * 3 6 4 # and press green button
  3. You will get a error message and after it your will see Engineering menu
  4. Click Options
  5. Click GSM Test
  6. Select Send AT command
  7. Now you will see a new window Saying "Send AT Command"
  8. Type AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]" and press send
  9. If you get Response "0 []" phone is unlocked
  10. If you get 1 error, then make sure you have typed the code correct and try the other code
Switch your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minitues to 5 hours until the message "Enter NETWORK PUK" is gone. Now enter the code received from us and 00000000 (eight zero's) as a new password.
If phone is asking for SERVICE PROVIDER PUK
  4. Click Options
  5. Click GSM Test
  8. Type AT+CLCK="PP",0,"[SERVICE PROVIDER PIN or NETWORK PIN]" and press send
If you do not have the original card or if the original card is not accepted because you flashed the phone with other firmware, then we can not help you
NEC
NEC N342i
  1. Power on phone without a SIM card
  2. Compose **00012*CODE# where "CODE" is the unlock code you received from XXXXXXXX
  3. Your cell phone is now unlocked
Other NEC models
  2. Compose #7320*CODE# where "CODE" is the unlock code you received from XXXXXXXX
Older NEC models
  2. Compose #3210*CODE# where "CODE" is the unlock code you received from XXXXXXXX
Nokia
All Nokia Models
  2. Compose #PW+CODE+1# where "CODE" is the unlock code you received from XXXXXXXX To get letter P quickly press 3 times the star button ( * )
    To get letter W quickly press 4 times the star button ( * )
    To get sign + quickly press 2 times the star button ( * )
  3. You will see a message "SIM Restriction Off"
  4. Your cell phone is now unlocked
HTC, Pocket PC, XDA, Qtek, Dopod, i-Mate, XDA, etc
  2. When prompted, enter unlock code you received from XXXXXXXX Attention! Use the onscreen keyboard and make sure that wireless mode is OFF.
    If you see a message Sim lock. You can still make emergency calls your phone has a blocked counter due to several previous incorrectly entered unlock codes. The only solution in this case is to upgrade phone's ROM which will reset the counter and allow to enter the code.
Pantech
  2. When prompted enter unlock code you received from XXXXXXXX Attention! Use the onscreen keyboard and make sure that wireless mode is OFF.
    Pantech C150
    1. Turn on phone with existing (original) SIM card
    2. At main menu screen, enter *#865625#
    3. When prompted, enter unlock code you received from XXXXXXXX
Ja\/\/aD
The Following 26 Users Say Thank You to Ja\/\/aD For This Useful Post:
Old 04-23-2009, 04:02   #2 (permalink)
tan2x81's Avatar
Member: 57103
Thanks Meter: 32
how to upgrade the htc rom?
Old 04-23-2009, 10:35   #3 (permalink)
ira balisi's Avatar
Member: 316429
Thanks Meter: 80
wanna ask if this is working?
The Following User Says Thank You to ira balisi For This Useful Post:
Old 10-19-2009, 00:37   #4 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 140
it is helpful...............
The Following User Says Thank You to akkay For This Useful Post:
Old 10-19-2009, 10:08   #5 (permalink)
sagg_4u's Avatar
Member: 884540
Thanks Meter: 684
yes its help full tips but i see y not given thnx????????????
Old 10-19-2009, 10:35   #6 (permalink)
Member: 253021
Sonork: 1585469
Thanks Meter: 74
many thx for very good info.
br
joy.
Old 10-19-2009, 16:48   #7 (permalink)
Member: 1144853
Sonork: 952753
hey can u help me unlock my blackberry 8220 flip network? i live in jamaica and i dont have paypal or credit card
Old 12-03-2009, 09:48   #8 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 167
can anyone tel me how to reset user code in blackberry 8300 ?thanks in advence
Old 12-04-2009, 03:56   #9 (permalink)
Crazy Poster
Member: 1129784
Thanks Meter: 15
thanx for sharing these useful tips brother
Old 01-31-2010, 13:15   #10 (permalink)
Member: 430155
Thanks Meter: 33
09:02:30 > check for software update: Start!
09:02:50 > get version from web: Ok!
09:02:50 > you use last version of software!
09:02:50 > check for software update: End!
09:06:37 > version micro-box a.i.o. V1.0.2.2
09:06:37 > alcatel e230 read codes: Start!
09:06:44 > press power: Ok!
09:06:46 > sending boot: Ok!
09:06:46 > reading flash id: Ok!
09:06:47 > reading imei: Ok!
09:06:47 > reading version: Ok!
09:06:47 > reading firmware: Ok!
09:06:47 > imei: 35231501106361-3
09:06:47 > version: E230x-2drggb1
09:06:47 > firmware: 92dae90114
09:06:47 > flash id: 0001:227e
09:06:47 > reading data: Ok!
09:06:48 > calculate codes: Ok!
09:06:48 > network: 010-01
09:06:48 > reset code: 5451321528
09:06:48 > nck code: 1294212551
09:06:48 > nsck code: 0000000000
09:06:48 > spck code: 0000000000
09:06:48 > user code: 0000000000
09:06:48 > cck code: 0000000000
09:06:48 > disconnecting phone: Ok!
09:06:48 > alcatel e230 read codes: End!
Old 11-13-2010, 10:35   #11 (permalink)
jeyasree.p's Avatar
Member: 1340995
Thanks Meter: 14
i have a bb 9500 display was blanck please its the fist blackberry any solution please help me
Old 05-26-2011, 20:42   #12 (permalink)
Member: 1584918
Please help me BB 9800
Orange Dominican Republic
imei 353490041587128
MEP-04598-005
thanks in advance!
Old 06-23-2011, 20:59   #13 (permalink)
Member: 1285970
Thanks Meter: 4
nice sharing this helpful tips.....
i try now it could be done.........
How to enter an unlocking code in a LG u300 on 3 network soudies LG 0 05-01-2008 15:41
how to enter the unlock code in sendo M550 prabue Various 3 12-12-2004 10:25
how to enter the unlock code into a alcatel JOHN_BOY_06 Alcatel & TCL Old Models 2 09-20-2004 23:20
how to enter the unlocking codes oldsindbad VLSI, Conexant, Skyworks and Old Models 2 07-14-2003 16:21
How to enter S55 unlock code psych0 E-Gold Based Phones 1 07-10-2003 22:27
Page generated in 0.67462 seconds with 8 queries
