Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
01-03-2016, 13:57 | #1 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | How to Reset Google ID in Lollipop Handset (YU5010A & YU5010) Yuphoria (YU510A & YU5010 ) After Flashing lolipop Software Pls Follow below Step to do the reset,the same i have tested and its working find.. 1. Keep the ADB file in desktop ( The same file is used to solve the boot mode issues in A109 , A310 , A311 ) 2. Press and hold Vol + key and then connect the handset. 3. Handset will enter in to boot mode 4. Once entered, release the Vol + key. 5. Now run below commands in CMD window cd desktop\adb Adb devices Fastboot -1 0x2a96 erase config Fastboot -1 0x2a96 reboot 6.After executing this command the handset will reboot automatically… 7. Now the handset will not ask for google ID when boot up. Pls Note that the same procedure can be tried out in all lolipop OS Handset Should Be in Boot Mode. Note-To make the handset to boot mode "usb debugging" to Be enabled Regard. |
The Following 11 Users Say Thank You to VC_INDIA For This Useful Post: |
01-29-2016, 06:51 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | cd desktop\adb Adb devices Fastboot -i 0x2a96 erase config Fastboot -i 0x2a96 reboot thanks bro i got success with above commands |
The Following 2 Users Say Thank You to cellcare prasad For This Useful Post: |
02-01-2016, 08:08 | #5 (permalink) |
Freak Poster Join Date: Sep 2011 Location: INDIA Age: 37
Member: 1649620 Status: Offline Sonork: 100.1603891 Thanks Meter: 177 | Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\TUSER TELECOM>cd desktop\adb The system cannot find the path specified. C:\Documents and Settings\TUSER TELECOM>Adb devices 'Adb' is not recognized as an internal or external command, operable program or batch file. C:\Documents and Settings\TUSER TELECOM>Fastboot -1 0x2a96 erase confi 'Fastboot' is not recognized as an internal or external command, operable program or batch file. C:\Documents and Settings\TUSER TELECOM>Fastboot -1 0x2a96 reboot 'Fastboot' is not recognized as an internal or external command, plz help me |
03-22-2016, 07:14 | #9 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | no need to usb debugg on . just put set in fastboot . and apply commands. hansets in volume up+insert usb cabel...phone in fastmoode open adb command type this .. fastboot -i 0x2A96 erase config fastboot -i 0x2A96 reboot enjoy frp done |
The Following User Says Thank You to sunnny For This Useful Post: |
05-13-2016, 17:57 | #13 (permalink) |
Junior Member Join Date: May 2016 Location: india
Member: 2570667 Status: Offline Thanks Meter: 0 | Best... Solution ... Download custom recovery and flash it in fastboot mode.. Now go to custom recovery and go to advance wipe... erase cache,delvik-cache and data and reboot device... that's it.. |
