Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
05-14-2007, 06:52 | #8 (permalink) |
Insane Poster Join Date: Jul 2004 Location: bauda.city
Member: 72853 Status: Offline Thanks Meter: 5 | infor : HSDPA quicken up for 3G Speed is the passport when entering into the 3G magic world. Brand-new HUAWEI E620 data card, not only supports HSDPA packet data service with a maximum transmission rate of 1.8MBPS, but also supports EDGE packet data service with a maximum transmission rate of 236.8kbps. The functions of wireless surfing, SMS, Voice service and Email can be instantly achieved as you wish. Meanwhile, supporting multi-band with HSDPA/WCDMA/EDGE/GPRS/GSM, HUAWEI E620 bridges the communications and enables the share of enjoymen 1.Main Features Supporting HSDPA/UMTS 2100MHz and GSM/GPRS/EDGE 900/1800/1900MHz ; Supporting HSDPA packet data service with a maximum transmission rate of 1.8Mbps ; Supporting UMTS packet domain data service with a maximum transmission rate of 384kbps ; Supporting EDGE packet data service with a maximum transmission rate of 236.8kbps ; High-quality voice service based on UMTS or GSM ; Supporting circuit switched (CS) data service based on UMTS or GSM ; Stable and reliable voice & data concurrent service over UMTS ; Supporting SMS service based on GSM, EGPRS or UMTS, supporting group transmission of SMS ; The client E620 Manager program supports a high-capacity phone book, SMS box and call record function ; ▲TOP 2.Specifications Protocol HSDPA/UMTS: 3GPP R5 2004/06 GSM/GPRS/EDGE: 3GPP R99 2003/12 Working frequency HSDPA/UMTS 2100MHz: 1920MHz~1980 MHz/ 2110MHz~2170MHz (Uplink/Downlink) GSM/GPRS/EDGE 900MHz: 880MHz~915MHz/ 925MHz~960MHz (Uplink/Downlink) GSM/GPRS/EDGE 1800MHz: 1710MHz~1785MHz/ 1805MHz~1880MHz (Uplink/Downlink) GSM/GPRS/EDGE 1900MHz: 1850MHz~1910MHz/ 1930MHz~1990MHz (Uplink/Downlink) External interface PCMCIA: Type II, complying with PC Card Release 8.1 CardBus LED: Green, indicating HSDPA/UMTS operating status of the data card Blue, indicating GPRS/EDGE operating status of the data card Antenna: Internal antenna. Provide one antenna interface that can be connected to the outer antenna Earphone jack: three-wire earphone, supporting wire control mode SIM/USIM card: standard 6 PIN SIM card interface System requirement Supporting Windows 98SE, Windows 2000 and Windows XP operating systems A Type II PCMCIA slot, supporting CARDBUS Recommended: Pentium 500MHz CPU or above 128MB RAM or above Computer resolution of 800*600 pixels or above; however, resolution of 1024*768 is recommended Dimensions 120 mm (D) x 54 mm (W) x 10 mm (H) Weight About 55g |
Huawei E620 modem unlock faild !???!Pls solution | dominik1 | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 3 | 03-10-2010 12:57 |
huawei e620 | tonetty | KULANKENDI Server | 3 | 02-10-2009 20:16 |
Huawei E620 Simlock status | Cvanas | KULANKENDI Server | 2 | 01-07-2009 16:20 |
Huawei e620 when??? | pcosta93 | KULANKENDI Server | 2 | 04-12-2008 00:24 |
Huawei E620 | bigstu44 | KULANKENDI Server | 3 | 01-24-2008 16:51 |
