Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
06-22-2010, 07:49 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Online
Member: 1024090 Status: Offline Thanks Meter: 1,175 | Mobile Phone Secret Codes Tips and Tricks Tutorials and Procedures(anowar_virus) *#06# Serial Number/IMEI indicates *#0000# SW version (e.g. V3.42.1, 16-10-03, NHL-10) *#2820# Bluetooth (BT) device address xx# Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #) On/Off key -short pressing for menu for switching between profiles Menu key - Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.) Menu quick access - Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon). No Autostart - When switching the phone on up to the pin inquiry press the whole time the "ABC" key (pen) - this is to ignore the autoinitialization programs (and the MMC programs) - "safeboot". 12345 ... is according to be the standard Nokia nokia-securitycode. 0000 ... is according to be standard PIN2 at Vodafone (germany) ---------------------------------------- Caution - starting from here the codes are "dangerous" *#7370925538# *#Res0Wallet# ... is to delete the code around the "wallet" Input like normal telephone number (not in wallet code inquiry windows). NOTE! Afterwards the "wallet" is empty, can again be put on however with new code. *#7780# - Reset to original settings NOTE! Afterwards various "attitudes" are away - among other things these: Points of entrance (Provider dependent points of entrance and attitudes) Bluetooth attitudes Favorite Allocation of the two keys (beside Navi keys) in the main menue Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are... SMS/MMS/E Mail attitudes Logos and spielstaende (allegedly) also deleted... Programs, calendars and contacts, etc. not changed... *#7370# - Soft format - resets all the telefone Memory (like Formatting a disk NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4) Green, * 3 - Hard format: If the Mobile (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET. NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4) Proceeding: Equipment switch off, keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears... Tip 1 : Do u know how to use the edit button (abc or pencil button)? Heres how... in the inbox for example; u wanna delete multiple sms, simply hold the edit button, scroll down, and then, press c to delete the marked sms. The edit button can also b used to copy and past text in sms, simply hold it and scroll across, choose copy. pretty good for placing song names in ngages Tip 2 : **** happens, on a smartphone, its inevitable u do something wrong, and this calls for a format of fone. to format the fone, press *#7370#, then enter the lock code, which is the sec code of the fone. NOTE : batt must b full, else if format is disrupted by low batt, consequences will b disatrous I heard the code *#7780# works too, pretty much the same i tink. for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345. There are two kinds of formatting: hard formatting and soft formatting SOFT formatting: This does not realy format your phone (c-drive). It restores ini files from rom but preserves user data (photos, 3rd party apps etc). This is just a normal reset!! HOW? There are two ways to do a normal reset: 1) *#7780# (this seems to work only on S60 v6.1 and 7.0) 2) Go to Settings, General and scroll down to factorysettings (works on all S60 phones) -------------------------------------------------------------------- HARD formatting: This reformats completely the C-drive. All applications and files stored on this drive will be lost and clean but default files will be rewritten. This is a deep reset. HOW? Again there are two ways: 1) *#7370# 2) When unable to startup your phone: press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone on. This trick works on every S60 v7.0 and it works fine on my 6630 too but without formatting screen... Tip 3 : TO NGAGE USERS; Did u know u can install .sis files simply using the cable given? Juz plug it in, place the .sis file anywhere on e: (the mmc), not in any folders, root of e:, disconnect, then look for it in manager. Tip 4: Save on battery and system memory being used by regulary checking the task manager which can be accessed by holding down the menu button!! Tip 5: Type *#06# to display your IMEI serial number, very valuable for the unlocking your phone to other sim cards... Tip 6: Save memory when installing apps, by installing over bluetooth. This can be done using the nokia phone suite and a bluetooth serial connection. Only works with .SIS files, so java still has to be sent to the phone, but will save space when using .SIS files. Tip 7: Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels Tip 8: BlueJacking First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone. Tip 9: While you are viewing a picture in your phone's gallery, press one of these shortcut keys (definitely works on 6600, not sure about other symbians) 1 - turn image anticlockwise 3 - turn image clockwise * - toggle on/off of full screen 5 - zoom in 0 - zoom out Tip 10: Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels Tip 11: Check if the recepients phone is on Delivery reports or Type *0# your message in the message composer window space then write your message, the recipient will not see the star zero hash bit - just the message When they read it it will relay a message back to your fone showing the time they recieved it. (haven't yet tried it myself though) A soft and Hard reset A Soft-reset - the process of resetting all the settings of the phone to the factory default! No applications are deleted! A Hard-reset is like formatting a drive! It does format the memory. Everything that has been installed after the first use of the phone is deleted! It will recover the memory of the phone to the state you purchased it! It is done by inputing the following code: *#7370# NOTE: The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable Start up in Safe Mode so no 'auto start' apps will be running: To make sure that no memory-resident programs start when you reboot your phone, hold down the pencil key when you turn on the phone and hold it on untill you have to enter your PIN code. (When you have trouble booting up the phone with the MMC in it because it got corrupted for some reason, this trick will almost always let you boot up the phone so you can remove the latest installed app which might have caused the problem or if your phone is "unrepairable" you can still back up your important data before you do a format.) NOKIA Nokia Code function *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# With this Nokia code you can deactivate the Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) *#147# This lets you know who called you last (Only vodofone) *#1471# Last call (Only vodofone) *#21# This phone code allows you to check the number that "All Calls" are diverted to *#2640# Displays phone security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your cell phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Phone code that removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines The Operating Systems Symb OS v6.1 Nokia 7650 Nokia 3650 Nokia 3660 Nokia N-Gage Nokia N-Gage QD Siemens SX-1 Sendo X Symb OS v7.0 Nokia 3230 Nokia 6600 Nokia 6620 Nokia 6260 Nokia 6670 Nokia 7610 Panasonic X700 Panasonic X800 Symb OS v8.0 Nokia 6630 Nokia 6680 Nokia 6681 Symb OS v8.1 Nokia N70 Nokia N90 Symb OS v9.1 Nokia N91 Nokia 3250 Nokia E60 Nokia E61 Nokia E70 Nokia N71 Nokia N80 Nokia N92 Nokia phones service codes *#0000# - SW version *#06# - IMEI *#war0anty# - SIMLOCK info *3370# - Enhanced Full Rate ON #3370# - OFF *4720# - alternative sound quality codec ON #4720# - OFF *#7780# - default factory settings *#7760# - production serial no. *#2820# - Bluetooth info. *#73# - reset phone timers and game scores. *#7370925538# - delete all the content of the wallet and the wallet code. *#7370# - soft format — erases all telephone memory. [Green]*3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots *#delset# - MMS/GPRS settings removal NOKIA SYMBIANS *#06# Serial Number/IMEI indicates *#0000# SW version (e.g. V3.42.1, 16-10-03, NHL-10) *#2820# Bluetooth (BT) device address xx# Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #) On/Off key -short pressing for menu for switching between profiles Menu key - Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.) Menu quick access - Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon). No Autostart - When switching the phone on up to the pin inquiry press the whole time the "ABC" key (pen) - this is to ignore the autoinitialization programs (and the MMC programs) - "safeboot". 12345 ... is according to be the standard Nokia nokia-securitycode. 0000 ... is according to be standard PIN2 at Vodafone (germany) ---------------------------------------- Caution - starting from here the codes are "dangerous" *#7370925538# *#Res0Wallet# ... is to delete the code around the "wallet" Input like normal telephone number (not in wallet code inquiry windows). NOTE! Afterwards the "wallet" is empty, can again be put on however with new code. *#7780# - Reset to original settings NOTE! Afterwards various "attitudes" are away - among other things these: Points of entrance (Provider dependent points of entrance and attitudes) Bluetooth attitudes Favorite Allocation of the two keys (beside Navi keys) in the main menue Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are... SMS/MMS/E Mail attitudes Logos and spielstaende (allegedly) also deleted... Programs, calendars and contacts, etc. not changed... *#7370# - Soft format - resets all the telefone Memory (like Formatting a disk NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4) Green, * 3 - Hard format: If the Mobile (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET. NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4) Proceeding: Equipment switch off, keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears... Tip 1 : Do u know how to use the edit button (abc or pencil button)? Heres how... in the inbox for example; u wanna delete multiple sms, simply hold the edit button, scroll down, and then, press c to delete the marked sms. The edit button can also b used to copy and past text in sms, simply hold it and scroll across, choose copy. pretty good for placing song names in ngages Tip 2 : **** happens, on a smartphone, its inevitable u do something wrong, and this calls for a format of fone. to format the fone, press *#7370#, then enter the lock code, which is the sec code of the fone. NOTE : batt must b full, else if format is disrupted by low batt, consequences will b disatrous I heard the code *#7780# works too, pretty much the same i tink. for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345. There are two kinds of formatting: hard formatting and soft formatting SOFT formatting: This does not realy format your phone (c-drive). It restores ini files from rom but preserves user data (photos, 3rd party apps etc). This is just a normal reset!! HOW? There are two ways to do a normal reset: 1) *#7780# (this seems to work only on S60 v6.1 and 7.0) 2) Go to Settings, General and scroll down to factorysettings (works on all S60 phones) ------------------------------------------------------------------------------------------------------------------------------------------------------------ HARD formatting: This reformats completely the C-drive. All applications and files stored on this drive will be lost and clean but default files will be rewritten. This is a deep reset. HOW? Again there are two ways: 1) *#7370# 2) When unable to startup your phone: press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone on. This trick works on every S60 v7.0 and it works fine on my 6630 too but without formatting screen... Tip 3 : TO NGAGE USERS; Did u know u can install .sis files simply using the cable given? Juz plug it in, place the .sis file anywhere on e: (the mmc), not in any folders, root of e:, disconnect, then look for it in manager. Tip 4: Save on battery and system memory being used by regulary checking the task manager which can be accessed by holding down the menu button!! Tip 5: Type *#06# to display your IMEI serial number, very valuable for the unlocking your phone to other sim cards... Tip 6: Save memory when installing apps, by installing over bluetooth. This can be done using the nokia phone suite and a bluetooth serial connection. Only works with .SIS files, so java still has to be sent to the phone, but will save space when using .SIS files. Tip 7: Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels Tip 8: BlueJacking First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone. Tip 9: While you are viewing a picture in your phone's gallery, press one of these shortcut keys (definitely works on 6600, not sure about other symbians) 1 - turn image anticlockwise 3 - turn image clockwise * - toggle on/off of full screen 5 - zoom in 0 - zoom out Tip 10: Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels Tip 11: Check if the recepients phone is on Delivery reports or Type *0# your message in the message composer window space then write your message, the recipient will not see the star zero hash bit - just the message When they read it it will relay a message back to your fone showing the time they recieved it. (haven't yet tried it myself though) A soft and Hard reset A Soft-reset - the process of resetting all the settings of the phone to the factory default! No applications are deleted! A Hard-reset is like formatting a drive! It does format the memory. Everything that has been installed after the first use of the phone is deleted! It will recover the memory of the phone to the state you purchased it! It is done by inputing the following code: *#7370# NOTE: The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable Start up in Safe Mode so no 'auto start' apps will be running: To make sure that no memory-resident programs start when you reboot your phone, hold down the pencil key when you turn on the phone and hold it on untill you have to enter your PIN code. (When you have trouble booting up the phone with the MMC in it because it got corrupted for some reason, this trick will almost always let you boot up the phone so you can remove the latest installed app which might have caused the problem or if your phone is "unrepairable" you can still back up your important data before you do a format.) NOKIA Nokia Code function *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# With this Nokia code you can deactivate the Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) *#147# This lets you know who called you last (Only vodofone) *#1471# Last call (Only vodofone) *#21# This phone code allows you to check the number that "All Calls" are diverted to *#2640# Displays phone security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your cell phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Phone code that removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines The Operating Systems Symb OS v6.1 Nokia 7650 Nokia 3650 Nokia 3660 Nokia N-Gage Nokia N-Gage QD Siemens SX-1 Sendo X Symb OS v7.0 Nokia 3230 Nokia 6600 Nokia 6620 Nokia 6260 Nokia 6670 Nokia 7610 Panasonic X700 Panasonic X800 Symb OS v8.0 Nokia 6630 Nokia 6680 Nokia 6681 Symb OS v8.1 Nokia N70 Nokia N90 Symb OS v9.1 Nokia N91 Nokia 3250 Nokia E60 Nokia E61 Nokia E70 Nokia N71 Nokia N80 Nokia N92 Nokia phones service codes *#0000# - SW version *#06# - IMEI *#war0anty# - SIMLOCK info *3370# - Enhanced Full Rate ON #3370# - OFF *4720# - alternative sound quality codec ON #4720# - OFF *#7780# - default factory settings *#7760# - production serial no. *#2820# - Bluetooth info. Samsung T309 and T809 100% No need to use BOX 1st Make Full Eprom Reset *2767*3855# After Rebooting Mobile then enter... *7465625*638*00000000*00000000# (to change NCK code to 00000000) then enter... #7465625*638*00000000# (to permanently unlock the phone) check the lock status... *#7465625# *#73# - reset phone timers and game scores. *#7370925538# - delete all the content of the wallet and the wallet code. *#7370# - soft format — erases all telephone memory. [Green]*3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots *#delset# - MMS/GPRS settings removal NOTE: code depends on phone model. Samsung D500 openline *7465625*638*00000000*00000000# NEXT ENTER #7465625*638*00000000# :#7465625*638*KEY2# Sanyo 200 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##33284# - Debug Menu Sanyo VI-2300 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu Known Issues The Sanyo VI-2300 cannot be used as a modem. Sanyo made minor modifications to this phone's modem protocol, and have refused to publish the drivers for the device to be used with a computer. Sanyo VI-2400 Sanyo 4700 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Hacks Sanyo 4900 > 7200 Hack The Sanyo 4900 and 7200 use almost identical hardware, if not exactly identical on the inside. Because of this, the firmware is interchangeable. This will even enable ReadyLink on the 4900. To do this you pretty much need to be a Sprint Store technician, as most TSRs will refuse to do the firmware swap. Sanyo RL-4920 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu Sanyo 5150 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Sanyo 5400/RL2500 Codes To enter codes dial the code (just like any other phone number) then press the OK key | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Change the in-phone data rate cap to full speed (144/230) Sanyo 5500/VM4500 Codes To enter codes dial the code (just like any other phone number) then press the OK key | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Change the in-phone data rate cap to full speed (144/230) Recall Info Sprint is aware of a hardware issue affecting a significant number of Sanyo 5500/VM4500 units. These units have trouble placing outgoing calls, causing the phone to go into a redialing loop. In addition, some affected units may have trouble receiving incoming calls or text messages. Units suffering from this problem will pass the HP Test diagnostic used in Sprint Stores to diagnose problems usually associated with these symptoms. Hardware revision 201 was released to solve these problems. If under the Phone Info menu you have a revision earlier than 201, and are suffering from these problems, take your phone to the nearest Sprint Store and request a replacement. It may also be helpful to print this page out and take it with you to the store, as not all Sprint employees and affiliate stores are fully informed in regards to this service bulletin. [edit] Sanyo MM-5600 Codes To enter codes dial the code (just like any other phone number) | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu (##DEBUG#) Known Issues The Sanyo MM-5600 cannot be used as a modem. Sanyo made minor modifications to this phone's modem protocol, and have refused to publish the drivers for the device to be used with a computer. Sanyo 6200 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Known Issues When web browser is open you can't cancel an incoming call (you can cancel the ringer, but the phone locks up until the caller hangs up) [edit] Sanyo 7200/RL2000 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Change the in-phone data rate cap to full speed (144/230) Sanyo RL-7300 Codes To enter codes dial the code (just like any other phone number) then press the OK key | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Change the in-phone data rate cap to full speed (144/230) Sanyo MM-7400 Codes To enter codes dial the code (just like any other phone number) | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu (##DEBUG#) Sanyo 8100 Codes To enter codes dial the code (just like any other phone number) then press the OK key and select "Save Phone #" from the menu | ##786 - Phone Usage & Master Reset (##RTN) | ##3282 - Data Provisioning (##DATA) | ##040793 - Modify phone's data speed, the built-in cap. Changing the phone to 144/230 mode can improve speed over the default setting of 144K, as it removes the phone's built-in cap Sanyo PM-8200 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu (##DEBUG#) Sanyo MM-8300 Codes To enter codes dial the code just like any other phone number | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu (##DEBUG#) Known Issues The Sanyo MM-8300 cannot be used as a modem. Sanyo made minor modifications to this phone's modem protocol, and have refused to publish the drivers for the device to be used with a computer. Sanyo MM-9000 Codes To enter codes dial the code (just like any other phone number) | ##786# - Phone Usage & Master Reset (##RTN#) | ##3282# - Data Provisioning (##DATA#) | ##33284# - Debug Menu (##DEBUG#) Sanyo 4900, 5150, 5300, 8100, etc Nam Programming : Nam Set: ##Spc+Ok+Key Down+Ok Advanced Setup: ##3282+Ok+Key Down+Ok+Msl A-key: ##2539+Ok+Key Down+Ok Version: ##**837+Ok+Key Down+Ok Debug Menu: ##FSC+Ok+Key Down+Ok Airtime menu: ##8463+Ok+Key Down+Ok Change CAI: ##7738+Ok+Key Down+Ok Vocoder: ##8626337+Ok+Key Down+Ok Reverse Logistic: ##786+Ok+Key Down+Ok Set IP Address: ##2769737+Ok+Key Down+Ok TTY On/Off: ##889+Ok+Key Down+Ok Ready Link: ##4636+Ok+Key Down+Ok Browser Init On/Off: ##4682+Ok+Key Down+Ok Picture Token: ##25327+Ok+Key Down+Ok Unknown Code: ##5282277+Ok+Key Down+Ok (SPC=000000, FSC=040793) -------------------------------------------------------------------------------- LG 2945#*# - service menu (code resetW3000 G5300 C1200 G7100...) 2945#- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# Panasonic code *01763*737381# ::Service Codes:: Alcatel Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# Samsung *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100) THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP) I TESTED IT OUT LAST NIGHT ON MY T509(PASSED),T809(PASSED) Quote: *7465625*638*00000000*00000000# NEXT ENTER #7465625*638*00000000# AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks... network lock - inactive subset lock - inactive sp lock - inactive cp lock - inactive sim lock - inactive activa lock - inactive phone lock - inactive auto network - inactive auto subset lock - inactive auto sp lock - inactive auto cp lock - inactive auto sim lock - inactive Philips #20021208# ok - 630 without SIM (erase flash) *#7728*# - RSAV DONE *#3849*# - ??? reboot *#3851*# - ??? reboot Philips 568 *01763*737381# - reset Pantech *01763*737381# - master reset (user data, user code) without SIM *01763*8371# - SW version *01763*6371# - UNLOCK *01763*3641# - Menu Panasonic *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369# - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) LG 2945#*# - service menu (code resetW3000 G5300 C1200 G7100...) 2945#- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# Sony-Ericsson > * < < * < * - Service menu < * * < - Lock menu VK Mobile *#79# - SW version *#85*364# - hold menu 855855# without SIM (VG107) 85558555#-hold 4268#-hold (VG207) Voxtel 0124 - master code 0718#- hold - menu (ST11, SC10, V100 without SIM) 4268#- hold - show code (ST11, SC10 without SIM) *789(#)- hold - menu (V50, V300, RX100 without SIM) Motorola (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on Nokia *#7370925538# (valet code reset) 6230 *#746025625# [*#sim0clock#] *#92702689# [*#war0anty#] Fly Bird S688 - #*301#02# send - with SIM menu: 7 - 10 - ok, #*8000#, #*3676# (reboot repair) V09, S1180 - *, 3 times down, 3 times up - service menu Enol *#987*00# - Service menu *#987*99# - Full reset *#900# - SW version Maxon *#9922# - menu, reset (without SIM) *#9900# - Software Version *#9901# - Software Version (PBatch) S60 Siries (SX1, 6600, N-Gage..) *#7780# - factory default *#7370# - full factory defaults (all user data reset) SX1 formating - * + # + power on 6600 formating - 3 + * + send + power on Sendo X1 formating - 5 + power on Mitsubishi *65512890 (*-hold) format FFS (Eclipse) * 3926 - (*-hold) test mode * 5806 - (*-hold) SW version *(hold) 787090 - trium 320 unlock menu Huawei (cdma) MASTER SECURITY CODE -309296 -3092 -9296 Pantech HX-550C (cdma) Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR, after reset - ##27732726 PWR and select "with uim" *#0000# Displays your phones software version: 1st Line : Software Version 2nd Line : Software Release Date 3rd Line : Compression Type *#06# For checking the International Mobile Equipment Identity (IMEI Number) *#2640# Displays security code in use *#0000# Display Software ver. and compresion type *#100# Shows the phones number *#639# Programming - min/sid *#67705646# Removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#7760# Manufactures code *#7780# Restore factory settings *#92702689# Displays: 1. Serial Number 2. Date Made 3. Purchase Date 4. Date of last repair (0000 for no repairs) 5. Transfer User Data. To exit this mode you need to switch your phone off then on again *#30# Lets you see the private number *#94870345123456789# Deactivate the PWM-Mem (not recommend) *#746025625# Displays the Sim Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered *3001#12345# Programming / Field Test *#21# Allows you to check the number that "All Calls" are diverted to *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#43# Allows you to check the "Call Waiting" status of your phone. #3370# Enable Enhanced Full Rate Codec (EFR) #4720# Disable Half Rate Codec (correct code) *#1345# Shows credit value *** to the P sign **** to get the W sign ***** to get the + sign *#147# This lets you know who called you last (Only vodofone) *#1471# Last call (Only vodofone) *#21# This phone code allows you to check the number that "All Calls" are diverted to *#2640# Displays phone security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your cell phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Phone code that removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines Software version *#2820# M aster reset *73738# SP lock *#3210# Cooprate lock *#8140# SIM lock *#4960# Net Lock *#7320# E616 get the P sign P sign will appear after the # is held pressed for 3 seconds Temp unlock solution working on older firmwares please only try once. To unlock using temp solution Use any 2G simcard and turn-on the phone pre feb 2004 1) #4960*xxxxxxxx# + Send 2)*4960*xxxxxxxx*xxxxxxxx# + Send 3) Turn-off the phone and turn-on again! xxxxxxxx = any numbers make sure you keep them the same *2767*JAVA# Java Reset and (Deletes all Java Midlets) *2767*MEDIA# Reset Media (Deletes All Sounds and Pics) *2767*WAP# Wap Reset *2767*CUST# Reset Custom EEPR0M *2767*FULL# Reset Full EEPR0M (Caution) For example : *2767*JAVA# would be keyed in as *2767*5282# *#06# IMEI code *#9998*4357# Help Menu *#9998*5282# Java menu (GRPS/CSD settings for JAVA server) *#9999#0# Monitor Mode *#9999# or *#9998*9999# Software Version *#8888# or *#9998*8888# Hardware Version *#9998*746# or *#9998*0746# or *#0746# Sim Infos *#9998*523# or *#9998*0523# or *#0523# Display Contrast *#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK) *#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK) *#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos *#9998*377# or *#9998*0377# Error log *#9998*778# or *#9998*0778# or *#0778# Sim Service table *#9998*782# show date and alarm clock *#8999*638# show network information *#9998*5646# change operator logo at startup *#9998*76# production number *#9998*968# view melody for alarm *#9998*585# Non-Volatile Memory (NVM) *#3243948# Digital Audio Interference Off Secret Games: Snake on the T68 - Go to Erix and then on the main screen press 123 and you will be taken to the game. Secret Message - On Tetris on the main screen when the blocks are falling press 397 and a message will appear. Service Menu: Press > * < < * < * tells you the phone's software version (good for checking your phone's "age" before buying it); press "Yes" repeatedly to see all the software data & press ">" to see all the texts available in your phone (hundreds of them!); some phones have "Flash?" option to reset the phone (I didn't see any difference after doing that) How to Press > * < < * < * ??? When T68 is on "Standby Mode", "Standby Mode" means when it is not receiving or making any calls,, and it is on the main page where it show your operator name, signal strengths, time and battery level. 1. push joy stick to RIGHT once (Screen will change to the menu and cursor land on PHONE BOOK icon) 2. press * 3. push joy stick to LEFT twice (cursor will land on CONNECT icon) 4. press * 5. push joy stick to LEFT once (cursor will land on ORGANISER icon) 6. press * The Service Menu will appears ! 1. Service Info a. Software Version b. SIMlock c. Configuration 2. Service Setting a. Contrast 3. Service Test a. Display b. LED/Illumination - *This test is very cool c. Keyboard d. Buzzer e. Vibrator f. Earphone g. Microphone h. Real Time Clock i. Joystick Counter* if you just bought your T68, the Joystick moves should be at a very low count, or else bring it back to shop (apparently been used before !) T610 A (P) will appear when the number 7 key is pressed and held. No need to use BOX 1st Make Full Eprom Reset *2767*3855# After Rebooting Mobile then enter... *7465625*638*00000000*00000000# (to change NCK code to 00000000) then enter... #7465625*638*00000000# (to permanently unlock the phone) check the lock status... *#7465625# ---SGH-600: *2767*3855# ---S100, S300, V200: *2767*7822573738# ---A300, A800 *2767*637# ---X100 *2767*688# |
The Following 5 Users Say Thank You to anowar_virus For This Useful Post: |
08-06-2010, 06:54 | #2 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1335644 Status: Offline Sonork: none Thanks Meter: 6 | nice sharing,this is a good source where someone can learn something about their mobile secret functions,meantime i would like to share something which i found last week this is a site where it has network unlock code for all mobiles find further ************.com : Unlock your mobile phone for free |
The Following User Says Thank You to suruthi For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
