Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
03-14-2014, 12:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | [MTK 65xx DEVICES] IMEI REPAIR TOOLS
【APP】 MAUI META 3G 【Software Information】 Software Name:MAUI META 3G Size:55 MB Source Link:No Link - Developed By MEDIATEK INC 【Software】 All MTK Devices Baseband Run On NVRAM - Path In Androids Phones "/dev/nvram" You Can Use 2 Ways To Reflash NVRAM. - One By Flashing BPLG Baseband (Modem) "MAUI_1XAMD_W1X_XX_SP_V1X" (Where X Is Some Number Depending On Device Specs)(Basic Functions Like Imei ,Etc Works With Most Alternative BPLG Files) - Once NVRAM Is Corrupted You Must Use Flash Tool Solution With Correcting Scatter From ''__NODL_NVRAM'' To ''NVRAM'' And Select Correct Working Phone NVRAM File For Same Baseband. MAUI META 3G Instructions:
【Software Downloads】 DOWNLOAD MAUI META 3G SOFTWARE DOWNLOAD CDC DRIVERS DOWNLOAD ALL MTK (BPLGU) MODEM (BASEBAND(NVRAM)) FILES 【APP】 IMEI & SN WRITER 【Software Information】 Software Name:IMEI & SN WRITER Size:33 MB Source Link:No Link - Developed By CKT Technology 【Software】 All MTK Devices Baseband Run On NVRAM - Path In Androids Phones "/dev/nvram" You Can Use 2 Ways To Reflash NVRAM. - One By Flashing BPLG Baseband (Modem) "MAUI_1XAMD_W1X_XX_SP_V1X" (Where X Is Some Number Depending On Device Specs)(Basic Functions Like Imei ,Etc Works With Most Alternative BPLG Files) - Once NVRAM Is Corrupted You Must Use Flash Tool Solution With Correcting Scatter From ''__NODL_NVRAM'' To ''NVRAM'' And Select Correct Working Phone NVRAM File For Same Baseband. IMEI & SN WRITER Instructions: - Check Video Instructions Bellow - 【Software screenshot】 【Software Downloads】 DOWNLOAD IMEI & SN WRITER SOFTWARE DOWNLOAD ALL MTK (BPLGU) MODEM (BASEBAND(NVRAM)) FILES 【APP】 SN WRITE STATION 【Software Information】 Software Name:SN WRITE STATION Size:37 MB Source Link:No Link - Developed By MEDIATEK INC 【Software】 All MTK Devices Baseband Run On NVRAM - Path In Androids Phones "/dev/nvram" You Can Use 2 Ways To Reflash NVRAM. - One By Flashing BPLG Baseband (Modem) "MAUI_1XAMD_W1X_XX_SP_V1X" (Where X Is Some Number Depending On Device Specs)(Basic Functions Like Imei ,Etc Works With Most Alternative BPLG Files) - Once NVRAM Is Corrupted You Must Use Flash Tool Solution With Correcting Scatter From ''__NODL_NVRAM'' To ''NVRAM'' And Select Correct Working Phone NVRAM File For Same Baseband. SN WRITE STATION Instructions: 1.Open SN Station IMEI Tool Switch AT Mode and adjust PowerON Delay Time(s):5 2.After adjust the Delay Time(s) and change switch to Meta Mode Select Write IMEI and Smart Phone Put the cable to the Mobile and select the COM PORT(Look In Windows Device Manager For Device Modem COM Port) Select the Dual IMEI 3.Then Select the Modem Database and select the BPLGU file Select which database file need ( ex :- Mtk6575 6516 etc ...) 4.Select the Modem Database and select the APDB file 5.Then Click on START and enter IMEI (IMEI - s) Numbers You Want To Write 6.IMEI Is Repaired - Reboot Mobile Device 【Software screenshot】 【Software Downloads】 DOWNLOAD SN WRITE STATION SOFTWARE DOWNLOAD ALL MTK (BPLGU) MODEM (BASEBAND(NVRAM)) FILES AND APDB FILES AND FOR THE END HERE YOU HAVE AN ANDROID APP MADED BY UNNAMED MTK EMPLOYER FOR REPAIRING IMEI DIRECTLY FROM ROOTED DEVICE. MTK65xx-imei_EN.apk |
The Following 5 Users Say Thank You to bishnuprasad884 For This Useful Post: |
