Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
09-11-2002, 23:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Guadeloupe Age: 50
Member: 9955 Status: Offline Thanks Meter: 7 | nec DB2000 problem i have 13 pieces of nec db2000 wrong unlocked by eeprom and displayed Return to service centre code:003. i have tryed to put working eeprom in to the phone problem unsuccefull I don't have tryed to flash it because i haven't make the cable ye Is flashing solution must solve my prolem?? any solution to solve this problem? any help will be very apprecied |
09-13-2002, 08:42 | #5 (permalink) |
Member: 9955 Status: Offline Thanks Meter: 7 | @mr_x4you hello m8 if this solution will 100% work, so i can desold working flash from one nec and make a bacup and also for the eeprom in fact it is a sw clonning isn't it? |
09-15-2002, 21:09 | #10 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Honolulu
Member: 2176 Status: Offline Thanks Meter: 1 | i rewrite backup EEPROM-phone work(+) how correct unlock now? after unlock eeprom-need turn on with sim card or no? i turn on with out sim and enter #7320*12345678#,send button-phone say emergency call only and write Return to service centre code:003 AGAIN |
09-15-2002, 23:01 | #11 (permalink) |
Member: 9955 Status: Offline Thanks Meter: 7 | db2000 full unlocker try THIS soft Just put the phone ON with sim card who the phone is locked, and press *4960*00000000*00000000# + send button (green) Now the phone write u if the lock is opened or closed. after that, put OFF the phone (with the OFF button not by removing battery) , and desold eeprom, use u're programmer to read it save it in u're hard disk (bin format). Patch it with the soft it create you a file named U.bin. program u're eeprom with U.bin Resold the patched eeprom, put the same sim card and the phone will write u to the factory reset and search the network don't worry it never found it yet Now put #4960*00000000# + send button (green) the phone will write u the simlock is open, now power OFF it and reboot it with any sim card, the phone is full unlocked. This is the only one solution to full unlock u're phone cable solution coas 3000US$ . If u don't have the original sim card were the phone is locked, try to relock it with paderf soft for u're sim card and use this soft to full unlock it. |
09-16-2002, 13:36 | #12 (permalink) |
Member: 2176 Status: Offline Thanks Meter: 1 | i try you SW... patch eeprom and insert sim turn on phone search network enter code #4960*00000000# + send button phone say ...NON... -incorrect turn of\on phone locked why paderf recommend code #7320*12345678# send??? what correct data to enter??? |
09-16-2002, 14:23 | #13 (permalink) |
Member: 9955 Status: Offline Thanks Meter: 7 | @baza just put *4960*00000000*00000000# + send button before patch eeprom. it must work, if u forget to make this before patching the eeprom it can not work! |
09-16-2002, 14:29 | #14 (permalink) |
Member: 9955 Status: Offline Thanks Meter: 7 | OF COURSE AFTER EEPROM PATCHED AND RESOLDED PUT THE SAME SIM CARD AND ENTER enter code #4960*00000000# + send button good luck! this solution work 100% for me if u have some difficulty contact me by icq if i can help u regards |
NEC DB2000 PROBLEM!!! | Pandemonio100 | Various | 0 | 10-17-2001 17:19 |
help unlock NEC DB2000 | Disaster | Various | 2 | 05-30-2001 09:23 |
Need help with NEC DB2000 | Disaster | Various | 6 | 05-12-2001 00:50 |
NEC DB2000 | byteman | Various | 0 | 02-18-2001 22:12 |
NEC DB2000 | SLO/EU | Various | 0 | 01-19-2001 23:23 |
