Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
10-17-2017, 13:19 | #1 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Bangladesh Age: 34
Member: 2581716 Status: Offline Sonork: 30294069 Thanks Meter: 137 | Vivo X9 Hard Reset Unable to access your Vivo X9 device? Forgot your lock pattern or password? Try to enter the Android Recovery menu on your device, but please note that not all firmware supports it, and if there is no option to enter this recovery mode to "wipe data" or "Factory reset" your device, you won't be able to enter this menu. If these options will be available in a future ROM / Firmware release than you should try the following method to enter / get in the menu.
OR Resetting Your Vivo X9 Android tablet from the menu option factory reset With Clean Boot, you can reset your tablet to its factory defaults. When you reset your phone, the data stored in your tablet may be erased. 1. Tap Application > Settings > Backup & reset. 2. Tap Factory data reset > Reset phone > Erase everything to reset the phone |
The Following User Says Thank You to gsmanam For This Useful Post: |
10-17-2017, 15:27 | #2 (permalink) |
Member: 2581716 Status: Offline Sonork: 30294069 Thanks Meter: 137 | 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : A06E4B64 ID_BLOCK_I : 009900E1 ID_BLOCK_L : CD0833D25DC0114DC92349AD4974C89B ID_BLOCK_L : 276CE615EB175EE7EE6799AA058FA2F8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
11-21-2019, 13:18 | #5 (permalink) |
Insane Poster Join Date: Oct 2019 Location: southafrica
Member: 2931678 Status: Offline Thanks Meter: 28 | i have a problum plz friends help me i have a fone vivo x9 when i open in recover mood then the language is chinies and also when i press data formate obtion then also a passward how can i reset this fone any one friend plz help me |
11-21-2019, 15:39 | #8 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: Savar,Dhaka,Bangladesh.
Member: 2318480 Status: Offline Sonork: 100.1669259 Thanks Meter: 198 | vivo_X9X9iX9L_PD1616_D_1.27.1 bug fix file Quote:
vivoX9/X9i/X9L_6.0.1_PD1616_D_1.27.1 - ROM?? - URL88 ROM?? vivoX9/X9i/X9L_6.0.1_PD1616_D_1.27.1 - ROM?? - URL88 ROM?? | |
