Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
01-03-2000, 13:43 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: France Age: 46
Member: 570 Status: Offline Thanks Meter: 18 | Please i need BOSCH 908/909 pin outs.. Is there any one who got this pin outs.... I have Bosch unlocker cracked so it gives ALL locks /not the Demo ver./ THANKS BYE |
05-27-2009, 09:04 | #4 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | i cant find exactly procedure for boot oc.c1, i tried to use procedure boot 6.36/6.71/6.81 but dont work for me info appear on screen please ensure that you have used appropriate smart testpoint and its connected properly. using smart tp AT163 smart tp 2. phone now shows on screen PH Sig Err: 35:02: |
05-28-2009, 15:25 | #5 (permalink) |
Freak Poster Join Date: Oct 2006 Location: INDIA TAMILNADU SALEM
Member: 369539 Status: Offline Sonork: 1584109 Thanks Meter: 32 | Bottom Pin Name Direction Description 1GND Ground, for all Bosch 9xx 2 DCD -?- Data Carrier Detect 3 DTR -?- Data Terminal Ready 4 RTS -?- Ready To Send 5 CTS -?- Clear To Send 6 DSR -?- Data Set Ready 7 IGN -?- Outside Device Present, if so put not more then 2,7 Volt in 8 GND Ground 9 SPK -?- Speaker, needs to be amplified 10 GND ANA -?- Ground analog 11 MIC -?- Microphone Elektret 12 PHP -?- Phone Present, puts out a LOW, it"s not ground 13 HEADSET -?- HeadSet Present, put a LOW in Sounds switched to HeadSet 14 TXD -?- Transmit Data 15 -?- that we dont know, but used by Bosch-Applications 16 BATT -?- Battery +, max. 10mAmps 17 -?- that we dont know, but used by Bosch-Applications 18 RXD -?- Receive Data 19 CBUS -?- CBUS for programing the phone - applicable to all Bosch 9xx 20 CHARGE -?- Charge + not more than 7 Volts Pins other than GND, CBUS may be different in other than 909Dual models! here is the full pinout of bosch 909 |
Need Nokia 5310 China Pin out | Sahil2007 | Infinity-Box | 8 | 05-09-2008 17:38 |
need sed ak 606 pin out pls helh me | ferdi__can | Infinity-Box | 8 | 01-09-2008 13:56 |
Need Sony Ericssom W810i pin out | Ramzan | Infinity-Box | 2 | 08-19-2007 13:45 |
need spv usb cable pin outs | falak | HTC & PDA WM( With Touchscreen) | 2 | 09-22-2005 07:17 |
Need Samsung E-810 Pin Out Require | taimu | SYSOL Platform | 0 | 03-17-2005 17:59 |
