Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
03-30-2001, 12:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Latvia Age: 50
Member: 3459 Status: Offline Thanks Meter: 5 | toshiba help!!! |
03-30-2001, 17:13 | #2 (permalink) |
No Life Poster Join Date: Jan 2000
Member: 860 Status: Offline Thanks Meter: 1 | Have you opend it and checked it for eeproms? Maybe you can use the old toshiba parallell plug (just alot of cables connected to each others).... Just plug this in when you boot your computer... Build it from a db25; You should connect these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25 Good luck! [ 30 March 2001 18:18: Message edited by: dito ] |
03-30-2001, 18:38 | #3 (permalink) |
Insane Poster Join Date: Mar 2001 Location: Lithuania
Member: 3552 Status: Offline Thanks Meter: 0 | Try this.... The one and only way to bypass the Power On BIOS password of a Toshiba Notebook. This method works on all models. This is what you need: 1. Your notebook 2. An empty formatted diskette (720 kb or 1,44 mb) 3. A second computer (e.g. a DOS desktop PC) 4. A hex-editor (e.g. Norton DiskEdit or HexWorks) This is what you have to do: 1. Start the desktop PC and start the hex-editor 2. Put the disk in drive A: 3. Change the first five bytes of sector 2 (boot sector is sector 1) to: 4B 45 59 00 00 4. Save it! Now you have a KEYDISK 5. Remove the disk from drive A: 6. Put the disk in the notebook drive 7. Start the notebook in Boot Mode (push the reset button) 8. Press Enter when asked for Password: 9. You will be asked to Set Password again. Press Y and Enter. 10. You now see the BIOS configuration where you can set a new password. And that's all! |
toshiba g910 hang to aram toshiba | amin1999 | HTC & PDA WM( With Touchscreen) | 3 | 12-24-2009 07:42 |
help help pinout or cable toshiba ts608 plaise | nejm | FuriousGold | 2 | 06-19-2009 23:12 |
How Could We Unlock Toshiba Ts705......no Support For Toshiba Ts705 By Infinity | sairat | Infinity-Box | 0 | 06-07-2008 06:39 |
Unlock Toshiba 904T ask Toshiba DL driver. | Tubansel | FuriousGold | 2 | 07-15-2006 04:06 |
You want Updates for Toshiba 803T and Toshiba 902T ? We need to buy this phones | Gobi | VygisToolbox | 17 | 03-20-2006 18:33 |
