2600 dead after failed flash Hello I was flashing my 2600 when about half through there was an error and the procedure was stopped. now the phone will not power up & is completly dead. any ideas what to do? Thankx Rob. |
Put charger in and reflash again ! |
tryed but because the pevious flash erased some stuff from the phone before it failed i get this message when i try to flash again: 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia Algorithm Ok, MSID: 84DE82BB94D351D65AFCDF62D6 Decoded MSID: 3E4EBAE9-00405B84-A8000000 Encoded FAID: AA307459-FBDFA797-919B3F39 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, FFFFFF, Time: 00:06 Process Failed, Repowering Mobile any ideas what to to? Thankx Rob. |
Try this: Skip Erase from Area 3 or 2 ant flash Manual. Regards Dewolden |
You have phooked imei now. Best Regards, karwos |
yeah my imei is ????????etc why is my imei f*ucked? i just wanted to flash my goddam firmware i tryed putting back the original firmware but no sucess what should i do? |
anybody? what should i do, my imei is ????????etc after i try to upgrade firmware. Thankx Rob. |
Use griffin server and rebuild flash IMEI. It will cost you one credit. And next time be carefull BR Mike |
This situation happens often with 2600 handsets and not only with 3-rd party flasher, also original equipment kill it in same way. Doctormike is right, you have to rebuild imei. |
real way :only with ufs3 box select model on the DTE-1 (D211) press the erase flash key ok and erase full flash second :write full flash and cnt with (select the 2600) ver 4.42 1000000000000000000 % ok |
i tryed with "erase flash memory" with DTE-1 (D211) and pressed ok on "adjust start adress" & "adjust end adress" and after that i flash the phone normally with Rh-59(2600) but still the same, "sim invalid". what am i doing wrong? Thankx Rob. |
you write the pm 1100 (rh18) to phone and full unlock 10000000000000% ok |
