01-27-2005, 16:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Germany , Bavaria Age: 45
Member: 37125 Status: Offline Thanks Meter: 19 | 3310 Problems have anybody the FAID Set Problems on Nokia 3310 Phones solved ? I have flashed a few Nokia 3310 Phones , but every Nokia 3310 I've flashed had the problem that the Phone goes on for a few seconds and the it shut up. I've Set the Faid more the 10x , but it doesn't work . If I that the Faid with a Serial Cable , the Problem ist solved. But why it doesn't work with the Twister ? Thank you |
01-27-2005, 19:26 | #4 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | THE PROBLEM IS THAT THE TWISTER CAN'T SET THE FAID CORRECT. Flashing is possible and makes no Problems ! By a serial Cable an Noktools it works fine . But why not with the Twister ??? MFG |
01-27-2005, 19:53 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | @MisterX I dont understand why it wont work for you, i have flashed alot of 3310's, i even flashed one today with new 6.39 and it worked first time... Only problem i ever had is that sometimes it does not work the first time so you need to check if it gives full signal and if not do FAID again..I know you did it many times and i dont understand why it wont work.. Have you tried taking a good working 3310 and done a complete readout and programmed this into the phone and done FAID and unlock...If this does not work it must be something with either your computer, your box or your cable because the program works fine here.. Twisterfan |
01-27-2005, 22:44 | #6 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | I don't no why it dont't work. I have only Problems on DCT3 Phone . I have one of the first Twisters with the Plastic Adapter , could it be that this is the Problem ? Thank you |
01-27-2005, 22:51 | #7 (permalink) |
Member: 53791 Status: Offline Thanks Meter: 17 | @MisterX Dont know i have one as well but i have modified it to not need the plastic adaptor Is it all DCT 3 phones or only 3310 ? If it is only 3310 i would suggest getting another cable for 3310, if it is all DCT3 but not DCT4 i would think more of hardware problems, maybe your computer or the USB port of it is not good.. Try the box on another computer to eliminate the box and if it is only 3310 cable get another one, if it is all DCT3 but not DCT4 and it is on all computers then the box must be at fault. Twisterfan |
01-28-2005, 22:30 | #11 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Romania Age: 42
Member: 81232 Status: Offline Thanks Meter: 196 | Brother the problem can be in software instalation and i think this is the most problem for all dct 3 phones . Other problem can be the pc .Try on other pc and see what it hapens . Br Ionel. |
3310 Problem... | [MoOkIe] | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-10-2002 15:03 |
3310 problems after instaling Blue leds!! | Me@n | Nokia Hardware & Hardware Repair | 7 | 12-18-2001 23:48 |
Nokia 3310 Problems - Turns Off By It Self | TheEckoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-14-2001 10:19 |
Nokia 3310 Problem | IrdetoMaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-08-2001 15:54 |
3310 problem wiht the leds | -FRILLE- | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-25-2001 12:52 |
