Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > Twisterflasher
Old 08-14-2004, 12:14   #1 (permalink)
Member: 76005
Unhappy 3650 Dead
hi all, I had 3650 mobile was killed when I flash it.
The UI options all was failed. And I tried to flash it more than one time, it still the same problem.
what can I do??!!
regards
snowhite
Old 08-14-2004, 12:17   #2 (permalink)
Insight's Avatar
Member: 31243
Just flash MCU with "CCSErasePMM25.03" - file and all is back to normal :-)
Insight
Old 08-14-2004, 12:35   #3 (permalink)
Member: 76005
I will try.
thanks Insight.
Old 08-14-2004, 13:52   #4 (permalink)
Member: 63385
Hi!...
Maybe u flashed it with v4.57 (N3660) same as with mine... Flash it back to v 4.13 first then if still no power do the ff:
1. Flash with "CCSErasePMM25.03" at your PPM Selection
2. Click check "Flash PPM Only", then click Flash...
3. Then after Flashing, Nokia Logo will appear. Click Write PM then select PM file for 3650 (ex. 3650.pm)
4. Then do Init Simlocks and Full Factory Settings...
5. Format User Area...
That's how i solved it!...
best Regards!
nokia 3650 dead and not dead tsarkh Nokia Hardware & Hardware-Repair Area 4 03-17-2006 02:49
My 3650 Dead No display hamidtele WD2 & APE (Symbian Phones) 3 12-04-2004 15:23
3650 dead apadana Nokia Hardware & Hardware-Repair Area 0 11-13-2003 06:26
3650 dead - almost DamTin WD2 & APE (Symbian Phones) 0 10-24-2003 17:27
NOKIA 3650 DEAD error FFFF9000 mobilemafia WD2 & APE (Symbian Phones) 3 10-04-2003 07:22
Page generated in 1.84314 seconds with 11 queries
