02-03-2005, 15:10 | #1 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Poland / Germany
Member: 5076 Status: Offline Thanks Meter: 3 | 6210 Pmm flash error.(Securitycode) i have a problem , i want to remove on a 6210 security code it is totaly blocked i try to flash the pmm security code remove files from the support FTP but still code. So i want to flash virgin eeprom and rebulite imei but if i want flash i get this eroor message. Does any one can help me.I dont want to search my old Dejan device Detected: V 05.27 01-08-01 NPE-3 (c) NMP. 1st Boot Ok 2nd Boot Ok, DCT3, MAD: A1 G-01, ROM: 6, BUS: 8 FLID: 00898896,Int 28F320B3-T, I28f160.tia Software: V 05.27 01-08-01 NPE-3 (c) NMP. Algorithm Ok, [1764] Erasing: 0x005FA000-0x005FFFFF Erasing Error: 10,at: 0x005FA000-005FFFFF, 910206 Process Failed, Repowering Mobile bye *AnToS* |
02-04-2005, 18:09 | #4 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | @cyklops Hey man thank now it works. But still asking for Securitycode ohh i cant belive that i cant manage it with Twister . I rally have to use Dejan flasher ?? Best Regards *AnToS* |
02-04-2005, 19:57 | #5 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | @Antos If you have reset user lock and done UI reset it should not do this but if it does just enter 12345 as the code and go to phone security and select "security level" NONE... Then it should not do it.. Twisterfan |
02-06-2005, 09:24 | #8 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Bosnia and Herzegovina RS Age: 53
Member: 94109 Status: Offline Thanks Meter: 0 | Flash phone with some old DCT-3 flasher... use full flash 4Mb... correct CRC with e.g. Nokia_Tool_By_Rolis_1.8... reset phone/set factory with e.g. Eeprom_Tool_By_B-Phreaks_v3.1 ... Regards, ECS. |
02-07-2005, 08:37 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: P A K I S T A N Age: 49
Member: 75644 Status: Offline Thanks Meter: 5 | use old ucables flasher Quote:
hi try to use old ucables flasher if u need then search it on forum some where u l fined it and then flash with this file which is used to remove security lock. | |
02-11-2005, 20:35 | #10 (permalink) |
Banned Join Date: Apr 2004 Age: 43
Member: 63279 Status: Offline Thanks Meter: 8 | pls can somebody help explain how this virgin eeprom PMM works and how to use them perfactly. i recenty flash a Nokia 3310 with virgin eeprom PMM i download from twistersupport site but after the flash then is not displaying properly and imei is reading ?????????????/4. pls somebody should urgently!!!! Thanx in advance |
02-12-2005, 07:55 | #12 (permalink) | |
Member: 75644 Status: Offline Thanks Meter: 5 | try to rebuilt imei with nok Quote:
try rebuilt imei with noktool18, 1.change imei 2.clear sp locks 3.update faid. ur problm ll be solved. thnx | |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
6210 PMM needed | doktortelecom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-27-2005 13:31 |
3310-virgin pmm flashed-error- erase flash-phone ded-- help | badil | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-03-2004 07:10 |
3310--pmm flash-error-erase flash-phone dead ...need help | badil | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-26-2004 11:25 |
6210 pmm flashing | cyklops | Twisterflasher | 3 | 03-13-2004 09:42 |
