03-15-2005, 01:20 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | 6310i and 7110 ! 1st Boot Error! Help I've 2 different problem during flash of one 6310i and an 7110: 1) With 6310i I've make full erase and then when I try to make full flash, procedure stop everytime at 2% of MCU writing ! "Process Failed" I've try with Manual action and others solutions but this Error is the same! 2) With 7110 "Contat Service" I can't make full erase or full flash because everytime Twister says: 1st Boot Error UFS... 1st Boot Error... Pls help me to resolve these problems! What I can do? Thanks in advance! |
03-15-2005, 06:59 | #2 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | Quote:
Are you using 2 different cables for the phones ? If you are not then atleast you might solve one of your problems.. 6310i should be flashed using 6310 cable and 7110 should be flashed using 5110/6110 cable.. Twisterfan | |
03-15-2005, 09:40 | #3 (permalink) |
No Life Poster Join Date: Dec 1999 Location: Sweden Age: 45
Member: 739 Status: Offline Thanks Meter: 0 | For 6310i look so the pins on the phone is not dirty, use 6310 cable and rub connector so you know you get good connection and try. For 7110 do the same but use 6110/5110 cable for that one instead. Br Gsmhq |
03-15-2005, 09:44 | #4 (permalink) | |
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
but I've try the cables that you say without results! What I can do now? | |
03-15-2005, 16:54 | #6 (permalink) | |
03-16-2005, 01:35 | #8 (permalink) | |
I've resolve the problem with 7110 ! Same contacts of phone were not good! Now all is ok, after full flash! But about 6310i the problem is the same! When Twister Start Writing MCU at 2% there is an Error and flash procedure stop! What I can do? Cable work fine! I'm sure! Thanks again! | |
03-16-2005, 06:53 | #9 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
B.R., Raskal | |
06-11-2005, 02:23 | #10 (permalink) | |
I've now a 7110 that when I try to flash it or full erase with twister, don't go over 50%, everytime ! Why? What I can do? Thanks in advance for your help! | |
E50 1st boot ok 1st boot error | rajtelecom | HWK | 0 | 09-19-2008 12:05 |
3610 1st Ok.. 1st boot error | ansari_nazeel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 10-22-2006 16:24 |
Twister problems 1st boot error. Please help | simmo_67 | Twisterflasher | 11 | 07-22-2005 01:10 |
1st Boot Error on ALL 1100, 6800, 3650 | dannyogolo | Twisterflasher | 8 | 08-16-2004 11:42 |
1st boot error on UFS-3 | sloper | UFS2 + UFS3-Tornadoflasher | 8 | 05-05-2004 01:57 |
