01-21-2005, 18:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: anywhere Age: 40
Member: 76005 Status: Offline Thanks Meter: 0 | 6600 problem Ihave nokia 6600, when I turn the phone on it show me : (( phone start-up failed. Contact the retailer )) can I fix this problem by twister ??!!! best regards snowhite |
01-21-2005, 19:35 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: @Work
Member: 56215 Status: Offline Thanks Meter: 67 | Hi, if format userarea not help then Step 1: Click ERASE Flash start address: 02000000 end address: 027FFFFF * if you get an "Erase Flash Error" message in a specific address in the flash ic, this means that you have a damaged flash IC. You will need to replace flash IC number 2 inside the phone. (The 6600 has 4 flash ICs inside). Step 2: If you are successfull in erasing flash IC number 2, make a full flash of the phone... MCU + PPM + Bluetooth if necessary. Step 3. If you are successfull in full flashing the phone, put battery inside phone and you SHOULD GET "Contact Retailer" message again. Now remove the battery, put it back and hold buttons "call(green button on the left)" + "*" + "3" then press the power button while still holding the 3 buttons above... |
6600 problem with Oxygen phone manager! | pedjulino | Nokia Multimedia | 6 | 05-06-2004 20:57 |
Nokia 6600 problem | Unlocker AL | Griffin | 2 | 05-06-2004 18:19 |
6600 problem | gsm-decode | Twisterflasher | 2 | 05-04-2004 09:19 |
PC suite for Nokia 6600 problem,Heeeelpe me | tareg2001 | WD2 & APE (Symbian Phones) | 0 | 03-21-2004 17:49 |
6600 problem... reminds me of 3650 fading :( | Burnt Cobba | WD2 & APE (Symbian Phones) | 2 | 12-16-2003 16:07 |
