08-11-2005, 09:24 | #166 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Denmark Age: 55
Member: 18805 Status: Offline Thanks Meter: 27 | Quote:
WBR Falck | |
08-11-2005, 09:26 | #167 (permalink) | |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | YES YES YES n also for 000001 feature this is the correct procedure Quote:
08-11-2005, 09:27 | #169 (permalink) |
Banned Join Date: Jul 2003
Member: 34760 Status: Offline Thanks Meter: 2 | @PaWaa: You are mixing things. In 1.3k there is a internal update server that updates the firmware of your box from 2.5 to 2.6. But it does not have anything to do at all with the activation of the box. Why 1.3k does not accept "free" .FBIs that is a totally different story |
08-11-2005, 09:32 | #170 (permalink) |
Member: 34760 Status: Offline Thanks Meter: 2 | @All: Believe me I am not that good blindly. The thing is that this generator was written by me some 2 years ago. But it seems that the guy who managed to release it, did not get the updated version that works with the latest 1.3 series :P |
08-11-2005, 09:38 | #171 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
so all is okay and the fbi generated in my thread there will be also accepted by 1.3K | |
08-11-2005, 09:47 | #174 (permalink) |
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | @sir RASKAL ur services are great no doubt but its all bout knowing things properly after all SHARING IS FORUM but yes we all need ready made PAASTA.Once again thanx for all the things u hav arranged |
08-11-2005, 09:56 | #175 (permalink) | |
Member: 34760 Status: Offline Thanks Meter: 2 | Quote:
time coded, too (since they are generated from REQs) | |
08-11-2005, 10:02 | #176 (permalink) |
Freak Poster Join Date: Oct 2003 Location: MaxCom♥ Age: 45
Member: 41067 Status: Offline Thanks Meter: 4 | No, I mean even the size. Try downloading from raskals site a requested xxxxxx.req and the corresponding xxxxxx.fbi. And then calculate your own xxxxxx.fbi from the same xxxxxx.req. when you compare the two .fbi files, they are very different. |
08-11-2005, 10:43 | #177 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
- Download the attached Req2Fbi.part1.rar & Req2Fbi.part2.rar and unpack them to root directory of your C: drive, it has the following files in it. 1. Req2Fbi.exe 2. Req2Fbi.bat 3. Req.fbi 4. Dctx_Ufs_12m Usage of Req2Fbi is as follows. Syntax: Req2Fbi <Req Filename> Example: on C:\> type Req2Fbi 12345.req And 00012345.fbi will be generated Under root directory of your C: drive, a Req2Fbi.bat is also included for dummies so after placing 12345.req in the same folder they can simply edit this .bat in notepad and they can replace the text "12345.req" with their own ?????.req filename and double click (Execute) this .bat file and 000?????.fbi will be generated in the same folder. - Now place Dctx_Ufs_12m in your default phoenix folder and execute it and connect. - Cancel string asking text box and click ok on next error messages. - click on Update Firmware & locate the 00012345.fbi file you generated earlier. (Result: BOX_KEY updated) - Now close it and run dctx_1.3k and connect. (Update Firmware If Asked) - It's done and you are ready to go with Feature 0000001 enabled. [PaWaa] | |
08-11-2005, 11:00 | #179 (permalink) | |
Here You Go. [PaWaa] | |
What About HWK Team. | nazrul islam | The Market Feed Back | 12 | 03-01-2010 16:03 |
pls help about p910 unlock and its error during unlockig.... | nhoy'sbarage | UST Pro II | 2 | 04-25-2009 14:29 |
Woman's Day passed, send HWK support team and Admin ... | whiteclouds | The Market Feed Back | 0 | 03-10-2008 05:06 |
what about boot-box team and MT-2 box | guo_xiaoguang | Motorola P2k | 0 | 08-27-2006 09:08 |
Darn... its new again, and its support my phone | iMsam146 | Nokia Multimedia | 0 | 05-24-2005 05:26 |
