02-21-2005, 17:50 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 41
Member: 93842 Status: Offline Thanks Meter: 0 | Activation problem on 90xxx I got a new Twister 90xxx from my reseller. I have installed the 1.30 come with the box but no luck... All four programs refuse to work What's more is, as shown in the attachment, my s/n shown in the text area is DIFFERENT from the one shown in the status bar below~! What's wrong??? Please help.... Thanks.... |
02-21-2005, 18:08 | #2 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Download the Test versions of RTP and ATRz from www.twisterflasher.com/files, to cure the issues with these software. Dont worry about the serials being different this is just a display issue with the older softyware versions which cannot handle the new serials above 65536. Odia. | |
02-21-2005, 18:12 | #3 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
Nr: 90643 EriN: 01279FD3BD69AA85FB DctN: 05A47B7F0EFE2EA30F SamN: 0CF1EFCA3B36DBE809 MoaN: 06F4BCAE78F553121A | |
02-21-2005, 18:28 | #4 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Jerez de la Frontera , Cadiz , SPAIN Age: 48
Member: 115106 Status: Offline Thanks Meter: 4 | Hello Raskal Today arrived my twister from Movilcom , I have the same problem . Nr: 90643 EriN: 01279FD3BD69AA85FB DctN: 05A47B7F0EFE2EA30F SamN: 0CF1EFCA3B36DBE809 MoaN: 06F4BCAE78F553121A that you writte is for all twister? or each serial number have different one . Thank and regard |
02-21-2005, 18:43 | #5 (permalink) |
Product Supporter Join Date: Dec 2002 Location: Germany Age: 46
Member: 18701 Status: Offline Thanks Meter: 52 | Each Twister have own Serial Number and for this Serial Number you need own Activation Strings. This Strings can give your Reseller. regards, Benny |
02-21-2005, 18:53 | #6 (permalink) | |
Freak Poster Join Date: Jan 2002 Age: 52
Member: 8959 Status: Offline Thanks Meter: 8 | Quote:
Best Regards Tomas - MovilCom | |
02-22-2005, 02:10 | #8 (permalink) | |
Member: 115106 Status: Offline Thanks Meter: 4 | Quote:
thank you very much Tomas Best Regard | |
02-22-2005, 13:18 | #9 (permalink) |
Member: 8959 Status: Offline Thanks Meter: 8 | Remember if serial number of your twister is 90xxx usually you dont need any activation string, please download latest software 1.30.01 and ATR & RTP software Please dont run any older software and dont put any activation string Best Regards Tomas - MovilCom |
02-22-2005, 15:11 | #10 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | Dear Tomas I think , the 1st one that buy I have problem , because when I try to conect in Nokia softyware itīs said BOX_AUTH_ERROR:32 , and i cant flash anything . I have talk to many friend , itīs could be activation problem ? The 2nd one works great , Twister is fantastic ( I only need LOGGIN & PASSWORD of the support area ) .ī Thank you for your support Best Regard Carlos |
02-22-2005, 16:11 | #11 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bios security area Age: 37
Member: 73387 Status: Offline Thanks Meter: 18 | hello, i have my activation code .but when i enter i get this message UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 UFS_USB V2.6 (c) SarasSoft 2005.S/n: 25099 Licence: False Licence Updated, Please Reconnect if i reconnect then i get the same message again!!! For nokia it is working!! please any help?? thanks |
02-22-2005, 17:49 | #12 (permalink) | |
I WROTE WITH BIG LETTERS on the paper INSIDE PLASTIC BOX NEVER PRESS UPDATE BOX without previous(before) notice. Do not press on the button "update firmware" - you will deactivate the box. Spanish Version: No actualizar la box, sin previo aviso. Esto es, no pulsar sobre el boton "update firmware" en la pestaņa UFSx del modulo de Nokia DCTx o descactivareis la caja. PLEASE READ MANUAL BEFORE START TO PLAY WITH YOUR BOX !!!!!!!!!!!!!! Best Regards Tomas - MovilCom P.S. For repair your first box : 1. Go to Archivos de programa/Nokia/Phoenix 2. Delete File 90026.req 3. Connect "bad" box. Run Software "DCTX 1.3i" 4. Press "Update BOX" 5. Select REQ.FBI file 6. When Software ask you "you are sure" press "YES" 7. WHen Software terminates you will see message "req file saved in ......" 8. Disconnect box, from cable. 9. PUT IT in the booth (DONT TOUCH IT BEFORE RECEIVE NEW FILE) 10. Go to Archivos de programa/Nokia/Phoenix 11. Compress file 90026.req 12. Send this file to [email protected] 13. Will send you "NEW FILE" when we receive it from SARAS | |
02-25-2005, 02:25 | #14 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | Now I have problem with XYY34 box , when I use Eric_ATR_Ufs_16i_test2.exe and Eic_RTP_Ufs_26i_Tst_2.exe , When I conecct it , the box ask me for the activation string . UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 0 UFS_USB V2.6 (c) SarasSoft 2005.S/n: Licence: False Licence Update Failed thank you very much & regard Carlos |
02-25-2005, 08:24 | #15 (permalink) | |
No Life Poster Join Date: Dec 1999 Location: Sweden Age: 45
Member: 739 Status: Offline Thanks Meter: 0 | Quote:
And for the problem you have now you need to update the license and need a activation string key. Ask your reseller he will help you to give you those strings. /Gsmhq | |
activation problem on lg | azeezat | Xpresscodes.com | 2 | 06-28-2009 10:33 |
activation problem on lg | azeezat | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 06-28-2009 00:14 |
problem on activation bb5king | azeezat | BB5KING for (BB5BOX) | 2 | 11-04-2008 21:52 |
problem getting activation email on gsmserver.com | theonlyallan | Smart-Clip | 3 | 10-18-2006 17:09 |
Problem on Activating phone... | jacsha | Cruiser Suite | 9 | 05-10-2004 19:21 |
