Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > Twisterflasher
Old 06-15-2004, 22:04   #1 (permalink)
Moderator
Chris02's Avatar
Member: 41076
Angry can't flash 7650 BT!
I can't flash BT!
If i try 5.06 twister starts to flash and stopps by 1% and says: Write Error: 25_8
I tried all 3 BT options! Evertime the same! If i disable BT flashing all is fine (of coz no BT).
I tried 3.16 too! But the same .....
I tried a new PM...no result too!
What else can i do? Maybe something is damaged?
Old 06-15-2004, 22:57   #2 (permalink)
vilibrook's Avatar
Member: 35101
Hello.
Try This Solution:
Tested By Me.work 100%.
If Not,this Problem Is Hardware Problem.
Old 06-16-2004, 10:41   #3 (permalink)
DonaldDuck69's Avatar
Member: 5641
Nokia 1.2_p have bug.
Same with 6310i und 8910i, always flash error when flashing BT.
Phone is dead or no BT
Old 06-16-2004, 12:32   #4 (permalink)
SJS
SJS's Avatar
Member: 14684
Try with vers. 1.3! working sure!
Old 06-16-2004, 16:28   #5 (permalink)
Moderator
Chris02's Avatar
Member: 41076
Originally Posted by vilibrook
Hello.
Try This Solution:
That is not working 4 me!
Old 06-16-2004, 16:28   #6 (permalink)
Moderator
Chris02's Avatar
Member: 41076
I already use ver. 1.3_a!
Old 06-16-2004, 17:06   #7 (permalink)
nlogomaster's Avatar
Member: 16816
Sonork: 100.42691
using usfxx soft tick old blue tooth option and flash any version,it works on me.
griffin has having problem at old bluetooth versions
Old 06-16-2004, 17:23   #8 (permalink)
Moderator
Chris02's Avatar
Member: 41076
and where to get usf SW? Works it with twister too?? I don't think so!
BTW: I don't use griffin! I use Twister!
Old 06-16-2004, 17:43   #9 (permalink)
Member: 16816
Sonork: 100.42691
then if twister has a selection option to bluetooth,
untick the auto and select the OLD BLUETOOTH hardware and flash version you wish to use,if no remedy seen,its blue tooth hardware fault that needs to be replaced,can get at 6310i if you have a junk one
Old 06-16-2004, 18:01   #10 (permalink)
Moderator
Chris02's Avatar
Member: 41076
Anyway i ativate BT flashing Twister stopps....
I have old BT hwardware. I check HW version of phone. But everytime, equal if i select Auto, new or old, it stopps!
If BT is HW damaged i should could flash it, or?
Old 06-16-2004, 18:30   #11 (permalink)
Member: 16816
Sonork: 100.42691
you can flash unit while skipping blue tooth flashing so your phone may turn on,
as you post earlier,
then concluding the tests, you really need to replace bluetooth hardware module.
it happens
good luck
Old 06-16-2004, 21:57   #12 (permalink)
Moderator
Chris02's Avatar
Member: 41076
it happens
good luck
which tests???
I asked the customer i got this phone from. He said, that he installed a BT scanner and after that BT was no longer working
Maybe after all software problem?
Old 06-16-2004, 22:56   #13 (permalink)
Member: 45682
hi
no soft proplem if your box cant flash bt
it need to to change bt ic
(griffin= twister=ufs in flash bt option)
br
Old 06-16-2004, 23:08   #14 (permalink)
vilibrook's Avatar
Member: 35101
Originally Posted by mohammadmouazen
hi
br
@Chris02
I CONFIRM ,M8.
IT'S ONLY HARDWARE PROBLEM.
WBR
Old 06-17-2004, 02:46   #15 (permalink)
Member: 16816
Sonork: 100.42691
"which tests???"
flashing auto,new,old bluetooth and skipping bluetooth and phone is alive again is enough test to confirm hardware problem
Can't flash NEC 338 angel25dz NEC 0 03-29-2010 12:25
Prodigy v 1.1010....Can't flash 7650 LogoMan Federal One 22 08-02-2004 15:50
I can't flash 7650 by prodigy pls help??? proxy_gsm Federal One 1 11-14-2003 13:31
I can't flash 7650 89007688 psych0 Federal One 0 10-06-2003 15:42
7650 can't flash pavlin WD2 & APE (Symbian Phones) 0 06-11-2003 06:52
Page generated in 0.93924 seconds with 12 queries
