10-24-2004, 21:58 | #16 (permalink) |
Freak Poster Join Date: Jan 2004 Location: czech rep.
Member: 49095 Status: Offline Thanks Meter: 10 | ANYBODY OF "BOX-DEVELOPMENT" EXPERTS CAN'T SOLVE OR ADVISE??? best regards |
10-26-2004, 10:24 | #18 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Whiule U all waity for the bug to be fixed, here is how I solve this problem: I flash MCU only, Flash PPM only, Flash PM only (where applicale), then Flash CNT only. In all cases, I was successful Try it too |
10-27-2004, 17:34 | #19 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Nowhere Age: 44
Member: 25067 Status: Offline Thanks Meter: 81 | @redeyes, what u mean of jumber solution?? I always have this problem too, but when i feel tired to flash the phone the last chance is change CPU with 8310 CPU (V811) and always solve my problem |
10-27-2004, 18:50 | #20 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Jo Age: 45
Member: 36706 Status: Offline Sonork: 100.58560 Thanks Meter: 122 | Quote:
yes its happend with me also few times .. check the power incoming to RAM on a working phome .. u will find in the fuelty one 2 diods that missed power so u need to make ajumber between them .. i dont have aphoto now but i will try to make one .. | |
04-22-2006, 09:40 | #24 (permalink) |
Freak Poster Join Date: Jul 2005 Location: india Age: 44
Member: 162478 Status: Offline Thanks Meter: 13 | no solution for content extracting failed no solution yet i think itsan hardware problem in some modelss it will solve when connecting charger while flashing nijas |
01-24-2008, 01:37 | #26 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: I donot know what is the best Age: 51
Member: 581626 Status: Offline Thanks Meter: 184 | Quote:
1st Boot Ok, DCT4, UPP: 2142 Fl0: 0x01000000-0x01FFFFFF,0001007E,Amd 29BDS128J Algorithm: u_amd.fia, Ver: 4.19.0 Algorithm Ok, MSID: 8441E2DDC9EFC33343ACD8E9F3 Decoded MSID: 1C15BAE3-0081236B-AD0005BD Encoded FAID: AB3BDE78-00E0E091-95D228FA Chip SECTOR_SIZE: 64k, File FAT_SECTOR_SIZE: 64k Area1: 0x01A80000-0x01E9FFFF Erased, Time: 00:34 CNT Flashing Completed, Time: 00:11 Running: Nokia File Server CNT Extract Warning, Res: 0, CNT Area not Empty Contents Package Extracting Ok, Time: 00:07 Flashing Completed, Rebooting Mobile .................................. trotz d merkierte fehler funz. alles wieder (mindestens bei mir) vielen Dank | |
02-05-2008, 13:42 | #27 (permalink) | |
Freak Poster Join Date: Jul 2007
Member: 548443 Status: Offline Thanks Meter: 70 | Quote:
try this: just warm the inside of the phone to get the flash chips warm! DO IT THIS WAY:Remove the battery and place the back of the telephone where the battery is before some MODERATE HEAT(not too much heat,else the handset will get damaged!). While warm,connect the cable and try fast to do your job----flashing or unlocking. 100%,it should work! Some Nokia 2310 s were behaving that way and I have managed to solve the problem through this method! GOOD LUCK! JKKB | |
03-13-2009, 06:42 | #28 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | I have also this problem...but problem solved 90 percent. first flash with mcu then cnt and then ppm after this phone on but with no signals solve this signal problem and make the solution 100 persent workfull |
04-26-2009, 05:03 | #29 (permalink) |
Freak Poster Join Date: Nov 2008 Location: INDIA THE HEAVEN Age: 43
Member: 890328 Status: Offline Thanks Meter: 50 | I AM ALSO FACING THE SAME PROBLEM IN NOKIA 2310 PLEASE HELP ME SOME ONE Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
04-26-2009, 05:23 | #30 (permalink) | |
Member: 617692 Status: Offline Thanks Meter: 306 | Quote:
Problem solved..... but only with Universal Box. I often face this problem with ufs+hwk. Now I flash all my sets that have the problem with Universal Box and no extraction problem. One thing that this is not hardware prolem. this occures only with UFS box sarasoft | |
6020 Contents Package Extracting Failed | ngaia | Nokia Hardware & Hardware Repair | 28 | 05-27-2018 14:21 |
6230 contents package extracting failed? | torbay | UFS2 + UFS3-Tornadoflasher | 6 | 05-15-2008 09:29 |
Contents Package Extracting Failed for 6020 and 3220 | singapore | Nokia Digital Core Technology 4 ( DCT-4 ) | 16 | 02-16-2007 18:39 |
6101 Contents Package Extracting Failed | VinhHai | Nokia Hardware & Hardware Repair | 12 | 10-17-2005 01:27 |
Contents Package Extracting Failed | DonaldDuck69 | Twisterflasher | 0 | 02-09-2004 16:31 |
