02-20-2005, 12:30 | #1 (permalink) |
Crazy Poster Join Date: Oct 2003 Location: MX-KEY is the BEST NOKIA TOOL Age: 49
Member: 40801 Status: Offline Thanks Meter: 1 | Dead 6310i A customer came to me with his Nokia 6310i. He was using it and suddenly it turned off by itself. Now the phone wont turn on and I cant do anything with Twister. I've tryed to flash it but the phone fails to boot up. Any suggestions B.R. murerlars |
02-20-2005, 18:05 | #5 (permalink) |
Member: 40801 Status: Offline Thanks Meter: 1 | Cable and terminal are working fine. Tested with another 6310i. This is a picture of the error message. Last edited by murerlars; 02-20-2005 at 18:51. |
02-20-2005, 20:27 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | @Murerlars Have you tried unticking the "autodetect product" tab.. This does not allways work if phone is dead or has corrupted flash.. Just untick and manually select 6310i phone and press flash .. Twisterfan |
02-20-2005, 21:27 | #8 (permalink) | |
Member: 40801 Status: Offline Thanks Meter: 1 | Quote:
02-21-2005, 12:10 | #10 (permalink) | |
I'm a little new in this buisness so I dont know what you mean when you say "rehot UEM", can you explain it a little more, please??? | |
02-21-2005, 15:44 | #11 (permalink) |
Member: 53791 Status: Offline Thanks Meter: 17 | @All I suspect that Murerlars is Danish therefor a Danish answer UEM er processoren i telefonen, det de mener med rehot er at du skal genvarme den da der somme tider er en af de tinkugler der er benene på sådan en fætter der slipper, ved at genvarme kan man somme tider få den til at få forbindelse igen.. Og så siger de at hvis dette ikke virker så skal du skifte den med en anden men den løsning er kun for folk med 100.000 kr. 's BGA rework udstyr så med mindre du har det så kan du ikke gøre det de siger du skal gøre.. Twisterfan |
02-21-2005, 15:47 | #12 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: GSM Center Ro ******** Age: 44
Member: 41900 Status: Offline Thanks Meter: 2 | you must write in english to for others that are interested Quote:
02-21-2005, 16:49 | #13 (permalink) | |
Member: 53791 Status: Offline Thanks Meter: 17 | Quote:
And that if he does not have expensive equipment he cannot do what they tell him to do.. Twisterfan | |
02-21-2005, 20:51 | #14 (permalink) |
Member: 40801 Status: Offline Thanks Meter: 1 | My customer has just found out that he still have warrenty on the phone so he can get it fixed for free. Thank you for your help everyone. B.R. murerlars |
Dead 6310i | OnTheAir | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-15-2004 06:27 |
HELP NEEDED DESPERATLEY-DEAD 6310i | .:GSM International:. | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 04-24-2004 17:08 |
cheap flasher and dead 6310i & 6510 | Zloy | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-27-2003 19:05 |
dead 6310i | iulianu | Nokia Hardware & Hardware Repair | 2 | 07-20-2003 09:16 |
dead 6310i dont turn on | NNN | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 04-16-2003 06:09 |
