10-18-2004, 15:12 | #1 (permalink) |
Junior Member Join Date: Sep 2004 Age: 52
Member: 83401 Status: Offline Thanks Meter: 0 | Efter Flasing GDFS...IrDa and Bluetooth..not work!! I just Flashed SE T610 GDFS...but efter rebooting...T610 IrDa and blue tooth....not work any more!!!!???? WHY????? What should i do to make it work again???? Please help!! Best Reg Shaterlo |
10-18-2004, 15:53 | #3 (permalink) | |
Member: 83401 Status: Offline Thanks Meter: 0 | Quote:
10-19-2004, 11:37 | #6 (permalink) | |
Thanx friends but it still not work!! Both IrDa and Blue tooth...when i klick IrDa ON...it not show that is it on...but only saying it on...not show on display. I just did what you told me exact... Best Reg Shaterlo | |
10-19-2004, 12:41 | #8 (permalink) | |
Becuse my T610 couldnt i use any card...only one... i tried to unlock my SE T610...but i just got this massege(PUT THE RIGHT CARD ON PHONE).... I dont know why?? Then i tried to flash GDFS...maybe it well help...it dose help but not all thinks!! i lost my IrDa and blue tooth!! Best Reg Shaterlo | |
10-19-2004, 15:16 | #9 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | HI Is your camera working or does it hang itself with saving message when taking a picture.. ? Had this error on a T630 and read somewhere that if Irda and BT did not work and camera hanged itself it was because you used the wrong Modem file.. I can confirm that this was the problem with the T630 i did it to.. Looking at the FTP i can see that there are actually also 2 different modem files for T610, they are easy to find as they are the ones that are 2.5 MB in size.. Try downloading the other one and flash that one into the phone, it might just solve your problem, it did solve mine... Twisterfan |
10-19-2004, 21:21 | #11 (permalink) | |
Hello!! Yes exactly like you said...Camera hang itself !! i tried that and yes...camera hang itself .... Thank you so much for your help my friend!! But what ''modem files for T610'' calld?? what is the name of file?? can i find it on OTP mapp?? Or where?? what is name of file?? Is that file you mean?? ((t610_125586_R7A011_Modem.bih)) 2.5 MB?? Best Reg Shaterlo | |
10-19-2004, 22:00 | #12 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Shaterlo: You need to read up more on how these phones work mate before you flash them. You have to make sure the AVR and ARM in the T6x0 series phones match. So if you flashed in a R7A011 AVR (mcu) file then yes, you'd have to flash in an R7A011 ARM (modem) file. I suggest you flash in R6C005 as the firmware version, it's the latest stable release. There are MANY different languages packs of the AVR/mcu file, depending on what language you want the phone to support. I use EU5 myself for all my customers, unless they speak a language other than english. Then flash in RC6005 ARM (modem) file. There is only one of these, it will work with any language pack. Clearer now? |
10-19-2004, 22:17 | #13 (permalink) | |
Hello!! That is wonderfull!! i really got many of help here!! that is great! But kan you tell me wich flash modem files match my T610 with swedish language?? which one match to my swedish languge phone?? Best Reg Shaterlo | |
10-20-2004, 00:15 | #14 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Shaterlo: I thought I just explained that. If you flashed R6C005 ANY LANGUAGE PACK then you have to flash T610_Standard_Modem R6C005 file. There is only one modem file for a particular software version (with R6C005 anyway, sometimes US3 has a special modem file, as do EU6/7) Anyway, some links because I don't think I'm getting through. Flash this file (That's EU4, it has the Swedish language in it) as the MCU/AVR file. Then flash this file as the Modem/ARM file. If you ask me for the login to that site, I WILL scream! |
10-20-2004, 15:38 | #15 (permalink) |
Member: 53791 Status: Offline Thanks Meter: 17 | @Shaterloo Go to the support FTP, there you need to go to : SE/Flashfiles/T610R6C005 There are 2 different files there.. t610_125562_R6C005_modem.bih t610_125596_R6C005_modem.bih I dont know which one works, i have not tried it with T610 only T630, download both and give it a try, if you choose the wrong one it will hang the camera, no sweat, just select the other one and flash again.. ALl of the above is offcourse assuming that you have downloaded the MCU file from /SE/OTP/T610/R6C005 This will work for you my friend.. PS. I use allways EU3 for Danish language and for T630 i found that the file called t630_125802_R6C005_Modem.bih is the right one, just so you know if you need to do a T630 some day... Twisterfan |
6303 new problem " camera and bluetooth not working " | ales6orah | Nokia Hardware & Hardware Repair | 5 | 12-22-2010 11:51 |
iphone 3gs 16 gb wi-fi and bluetooth not work | zablon | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 12-10-2009 03:54 |
V3xR unlock camera and bluetooth not working | zorromayor | Smart-Clip | 3 | 11-08-2007 15:16 |
V3xR unlock camera and bluetooth not working | zorromayor | Smart-Clip | 1 | 11-08-2007 09:04 |
irda in c100 not work ? | eng.hamdow | Samsung Hardware Repair | 4 | 12-02-2004 08:34 |
