02-09-2005, 20:22 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Bucharest,Romania Age: 46
Member: 5204 Status: Offline Thanks Meter: 35 | Help With Crazy 6600 I have on 6600 with 2 flash ic damaged, so i changed them. After that i flashed the phone. now the phone flashes ok and powers on in contact retailer. The only problem i have is that the phone shuts down in 30 sec. WHY?? ( I tried all solutions posted here.(really i did) PLEASE HELP !!!! BR |
02-09-2005, 21:05 | #2 (permalink) |
Insane Poster Join Date: Jul 2001 Location: bucuresti Age: 61
Member: 5356 Status: Offline Thanks Meter: 0 | i also did a flash imei repair using griffin ...it all went OK. Now i`d like to ask you is it possible that the UEM is damaged?Because shuting down in 30 sec from what i saw this far was caused by fault of the UEM. When i read imei is is ok. If i have to change UEM i can only do so with one from a nokia n-gage, and the calculate flash imei with griffin. WILL THIS WORK?? Please HELP ME ON THIS ONE |
02-09-2005, 22:58 | #4 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | Last Questions Since the only UEM I have for this ASIC is an ALREADY written, one from an N-Gage I whant to ask you if i can use this one. And so what would be the next step if i use this uem. I have to be sure because this phone has takeen a lot of time and i don`t want to waste to much time..... and BTW the last post is mine too because I used the pc of a friend But how could this UEM get damaged since before changing the damaged flash ICs the phone stayed on all the time.......What happened that damaged it?????? |
02-10-2005, 18:46 | #5 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | Final Result: I Changed The Uem I Changed The Cpu But The Problem Remains:>>>>>.....phone Shuts Down In 30 Seconds Why? For Me It Seems That It Is A Software Problem But How To Fix It?!?!? If I Try To Do "format User Area"(twister Or Griffin) Phone Will Shut Down In 30 Sec. Too. What Is The Problem???? The Uem I Replaced On This 6600 I Put It On A Ngage Phone And The Phone Never Shut Down ........ Please Help Me With Some Of Your Good Advices! Thx U All!!!! Br |
02-11-2005, 11:54 | #7 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | after changing uem i did a full esn repair.(that is flash and uem imei repair) and as i said i tested the UEM on a NGAGE after programing it on the 6600 but the ngage worked perfectly |
02-23-2005, 18:51 | #9 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | Quote:
03-19-2005, 20:14 | #10 (permalink) |
Freak Poster Join Date: Sep 2003 Location: hell
Member: 39245 Status: Offline Thanks Meter: 43 | Yeah, I got this problem too. 6600 with keypad problem causes from UPP. After UPP changed phone shut down in 30 second. Surely it is software problem, but I still can not solve it. Reprogrammed back up pmm also no help and causes CONTACT RETAILER. I think we need good pmm modified to solve this problem. Any sugestion will be welcome. BR, Djo |
help with nokia 6600 flashing problem | nasuib | WD2 & APE (Symbian Phones) | 2 | 10-26-2007 03:55 |
help with nokia 6600 | braveheat | Nokia Hardware & Hardware Repair | 1 | 08-16-2006 10:34 |
Help With Changeing 6600 uem | The Repair Shop | Nokia Hardware & Hardware Repair | 16 | 12-26-2004 11:26 |
help with crazy T191 | gsmspace | Motorola ODM | 4 | 09-07-2003 20:44 |
Need Crazy Help For Crazy Idea | SoftSkiner | GSM Programming & Reverse Engineering | 7 | 11-27-2002 20:46 |
