04-07-2005, 16:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | How to change IMEI on SL55 with Freia anw Twister Box I know that is probabily a thread more present in this forum, but I very need of help to know correct procedure! Infact I want change IMei of SL55 with Freia using twister boX! I do test point but now what I do? Pls explain me step by step if possible! I'm not expert with Siemens phones! Thanks in advance! |
04-08-2005, 19:47 | #4 (permalink) | |
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
but after insert patch of SL55 with V_Klay, there are same also operations to make? Or I can use then Freia By Twister? Thanks again | |
04-08-2005, 20:02 | #5 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | After you patch your phone by V_klay, use normal Freia v15. Give Unlocking Functions -> Direct unlock also saves map -> write new imei (ex. 356785432189765) -> and click OK. That's all br. fingusio |
04-09-2005, 16:17 | #6 (permalink) | |
I've make all that you explain me! After patch Sl55 with V_Klay, I've used Freia v9 and I've select Direct Unlock no saved map, I wrote new Imei and I've click on Update flash IMEI ! Then "oK". But at the End the Original IMEI is the same and is locked!! WHY? Maybe I must select "Direct UNlock also saved map" ??? P.S. Before this procedure I've try also to click instead "OK" button, on "Use Eepromm IMEI button and so Eepromm IMEI is changed! This is a problem? If yes, how I can repair this? Thanks in advance! | |
04-09-2005, 16:59 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Of course can't you change the OTP IMEI! You can with patch only change the shown IMEI and maybe the IMEI with will send to provider too. But not more! |
04-09-2005, 18:04 | #9 (permalink) | |
I've make all procedure exactly??? But in what cases is possible to unlock Siemens phone with IMEI locked?? Thanks again! | |
04-09-2005, 20:04 | #11 (permalink) | |
Pls explain me, how I can to know if possible to unlock or not, changing IMEI, Siemens phone!?!? Thanks Bye | |
04-09-2005, 20:23 | #12 (permalink) |
Member: 41076 Status: Offline Thanks Meter: 53 | Your phone is already unlocked. There is anywhere one Block in OTP area which shows the default sate of the phone lock (locked or unlocked) If a phone was factory locked you can chnage this block but you are able to unlock your phone! Just ignore it! Your phone is already complete unlocked! |
04-09-2005, 20:52 | #14 (permalink) | |
So, I think that is locked by IMEI! Or Blacklisted! Pls explain me another solution, if exist! Thanks | |
04-09-2005, 20:59 | #15 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | Oh ***!! in 100% is blacklisted if could search network!!! or hardware problem!! If is on blacklisted you must change imei ! and when you click *#06# you must see new imei what you write in FREIA. I think you know if you have ex. SL55 v20 you must downgrade to v16 (because this patch is only fo v16 version) and after that use patch with V_klay and then change imei as we said upper. br. fingusio |
how to change imei on l7 with ubl | nimanima | Ultima Box Light | 2 | 02-22-2008 00:44 |
How To Change Imei On K600,k608,v600 With Cruiser? | KUBAT1 | Cruiser Suite | 2 | 11-28-2006 11:41 |
Can u change IMEI on A55 with Freia?? | MC Harami | Siemens-Benq RingTones and WallPapers | 11 | 03-16-2006 08:17 |
can I change imei on SL55 with "treia" | Lugo | E-Gold Based Phones | 12 | 03-07-2005 10:29 |
How to change IMEI on T180 with EMMI SP box? | Migeni | Motorola Old Legacy (EMMI) | 0 | 08-11-2002 19:28 |
