08-26-2005, 19:33 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 47
Member: 159545 Status: Offline Thanks Meter: 2 | Hwk Cracked And Lg 8180 Unlock Problem I have hwk cracked and original ufs cable for LG i start KZF and connect whitout error KZF is started, after this i select the phone model 8180 and press GO but nothing happend just after 2-3 min "Product did not responde,Please remove and re-attach battery" can any one please explain me what is wrong? how to unlock lg 8180 whit HWK? thx in advance |
08-26-2005, 20:59 | #3 (permalink) |
Registered User Join Date: Aug 2004 Location: Hall Road Lhr Age: 43
Member: 76284 Status: Offline Sonork: 1001625595 Thanks Meter: 24 | it is 1000000% working ,i have flashed /unlock 8180 succesfuly, u need cabel,which works with ''multi read & write programe'' com+usb also flashes specific for vygis.these r avalible on ''KIMA's'' home page i dont remember where its link was. not any other flash files [renamed] works. |
08-27-2005, 06:37 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | if it not works reply Quote:
1,info 2,ini sb 3,*277634#*# 4,factory yes last and least all this not works then just take c_drive.ssw file and press flash mcu bye works 100% | |
08-27-2005, 09:44 | #7 (permalink) |
Member: 159545 Status: Offline Thanks Meter: 2 | i have original hwk cable but if i click GO after nothing doing just after 1 min "re-attach battery, i reattach battery but same nothing is happend and again "re-connect battery" |
08-27-2005, 10:08 | #8 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | use vy***s instead Quote:
08-27-2005, 10:12 | #9 (permalink) |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | no need dummy battery use this trick 1=power off phone 2=connect battery (must b charged) 3=PRESS GO 4=connect cable than it will surely work just try it |
08-29-2005, 08:40 | #11 (permalink) |
Member: 159545 Status: Offline Thanks Meter: 2 | 1=power off phone 2=connect battery (must b charged) 3=PRESS GO 4=connect cable than it will surely work just try it thx friend but this not working too just blank screen and after little time come some like "Product did not responde,Please remove and re-attach battery" Hwk is cracked but cable is original hwk |
09-04-2005, 09:49 | #12 (permalink) |
Member: 159545 Status: Offline Thanks Meter: 2 | now all is working but direct unlock 8180 is not possible whit hwk, now i need just to downgrade to 8138 buuuuuuuut the problem is Hwk need other flash files for downgrade how i find this flash file for hwk 8180 to 8138? i have tested whit kima and vigys file but dont work and original hwk i have too but whit this can just flash the model that is select, for example i select 8180 and try to flash whit original hwk file to 8138 but not work where have this 8180 to 8130 flash file? |
lg 8180 reset problem | sesime | VygisToolbox | 0 | 06-06-2009 15:38 |
LG 8180 unlock possible with Twister+HWK ? | indio68 | HWK | 2 | 11-15-2006 15:09 |
Hwk And Lg 8180 Unlock!! | Sparagna | HWK | 10 | 08-29-2005 22:37 |
Lg 8180 Unlock | gsm-decode | LG | 55 | 05-26-2005 17:13 |
LG 8180 unlock | ZAKKGSM | LG | 1 | 04-13-2005 11:09 |
