Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > Twisterflasher
Old 05-21-2007, 22:12   #1 (permalink)
Member: 426128
hwk-usf 2.05 crash
i´ve tryed to install ver.2.05 - and computer crashes.
i HAVE uninstalled ver.2.04 first.
all i get to se on screen is following message : acces violatin xxxxx.
and the computor closes down.
Have u any solutions ?
Old 05-22-2007, 00:14   #2 (permalink)
Member: 48648
Use the new drivers included in the package
Have a look into your sarasoft folder if there are some files left delete them
after that also install the new drivers, when you install the new hwk setup it checks if you got new drivers installed. i had the same problem i didnt had to format or do anything else except for update the ufs driver manually.
with kind regards,
ThaDevil
Old 05-22-2007, 16:51   #3 (permalink)
Member: 426128
thanks -but it did not help i´we got no files left , removed all drivers,
went into reg edit ,erased all what had to do with sara/usf/hwk.
still it breaks down !
Old 06-05-2007, 17:37   #4 (permalink)
Member: 426128
formatted c:\ , reinstalled xp , newer wersion - that helped !
Old 06-05-2007, 18:37   #5 (permalink)
Member: 498524
Very simple. Ctrl + Alt + Delete ....Go to Processes and end task on UFS instalation. Now install version. I started @ first version and installed all versions after each other with no problems.
Enjoy
Can't Install HWK Suite 2.05.007 .:: Sepid Gsm ::. HWK 34 06-15-2008 08:37
Install HWK Suite 2.05.007 and upgrade ur HWK keys... HWK server is working now.. Arif Jamil HWK 9 10-08-2007 21:17
i cant install hwk suite 2.05.. LoveLess HWK 5 10-01-2007 12:09
install problem hwk minor 2.05.006 kungpaoski HWK 16 08-20-2007 15:50
Page generated in 0.26915 seconds with 11 queries
