10-11-2006, 08:45 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 41
Member: 139232 Status: Offline Thanks Meter: 4 | KG800 to KG90 flash success with LG GSM Toos V2.0.1 HWK patched by killer -------------------------------------------------------------------------- Boot Ok, FL_ID : 98 00 4A [TOSHIBA] BaudRate Set to: 230400 IMEI: 352637-01-325938-0 MOT Format File, Converting to BIF Region: 1, 0x01000000-0x0194DD0B, Length: 9755916 bytes Processed: 609745 record(s) Saved as AlchemyDataKG90P64-86-V11m-XXX-XX Sep 20 2006.bif Write [01000000-01001FFF] Skipped Write [01002000-01003FFF] Skipped Write [01004000-01005FFF] Skipped Write [01006000-01007FFF] Skipped Write [01000000-0194DD0B] Done, Time: 7:55 Erase [04800000-04FFFFFF] Done, Time: 0:32 MOT Format File, Converting to BIF Region: 1, 0x04010000-0x04BD081F, Length: 12322848 bytes Processed: 770178 record(s) Saved as AlchemyDataKG90P64-86-V11m-XXX-XX Sep 20 2006b.bif Write [04010000-04BD081F] Done, Time: 0:01 -------------------------------------------------------------------------- Please do: 2945#*45# then 2945#*#6 after flashed (must keep the keypad open) If you have problem when flashing please try set the baud to 230400 or lower! Step to boot the phone: 1. connect UFS 2. select KG800 3. turn off the phone, take the battery out and insert back 4. connect the cable between the phone and UFS 5. select baud to 230400 or lower 6. click Boot button and wait until UFS status shows "booting..." (dont touch the phone until UFS shows booting) 7. hold the Power button of the phone until UFS shows IMEI number Now you can do your works! Enjoy! |
10-11-2006, 22:22 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
good job , pls keep on ! BR., Denis | |
SE K608i flashed successfully with hwk but now restarting problem | Adilsultan | Sony Ericsson | 2 | 03-16-2010 14:23 |
1200 flashing with pached (cracked) v2.0.3 HWK | MaxPayne | UFS2 + UFS3-Tornadoflasher | 11 | 02-22-2008 07:08 |
DOWNLOAD DCTxBB5 v2.0.3 HWK | alvaroc | UFS2 + UFS3-Tornadoflasher | 4 | 10-25-2006 16:52 |
3250 Flashing Successfully with HWK :) | almoudamer | HWK | 44 | 07-25-2006 18:09 |
please upload v2.0 of HWK | tostefo | Twisterflasher | 4 | 09-07-2005 07:11 |
