05-22-2005, 19:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Lebanon Age: 45
Member: 53113 Status: Offline Thanks Meter: 16 | Nokia 6600 error flashing Any one now this error??? 1st Boot Ok, WD2, UPP: 1081 2nd Boot Error: Chk Platform: 6, Error Data: 00 20 00 C0 88 00 00 21 01 10 00 02 20 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 C6 00 00 EA 75 01 00 EA 78 83 72 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile Thank.. |
05-29-2005, 08:03 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: medan,indonesia Age: 43
Member: 131336 Status: Offline Thanks Meter: 7 | I had the same problem. when i check the PCB looks like RAM is broken. Then I remove it and try to flash again. now my flasher can detect the 3 left flash. it mean the ram is broken. that's right isn't it???????? |
06-06-2005, 19:31 | #5 (permalink) | |
Insane Poster Join Date: Jul 2004 Location: LA
Member: 72894 Status: Offline Thanks Meter: 23 | Quote:
1st boot ok Upp :1120 2nd boot ok Fl0 : 0x00000000 - 0x007FFFFF Fl1 : 0x02000000 - 0x027FFFFF Fl2 : 0x04000000 - 0x047FFFFF Fl3 : 0x06000000 - 0x067FFFFF But after that error says Cbus Boot error 9. error data 00000010 00000020 00000030 that means Bluetooth error, unmark th BT Flashing. But in this case, the flash chip is not detected, 2 nd boot error. that means flash chip, RAM or UPP is wrong not Bluetooth. after rehot the RAM, the flash chip can be detected. it's a right ways. Rehot or change the RAM, check the line, VIO etc | |
mx key nokia 6600 wd2 flashing error ???? | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-02-2010 20:06 |
flashing nokia 6600 errors | Lucky7Napoleon | UFS2 + UFS3-Tornadoflasher | 6 | 02-02-2007 16:41 |
What does this Nokia 6600 error means? | Spalato | Twisterflasher | 15 | 11-17-2004 06:59 |
Nokia 6600 error App closed calendar | chubby | WD2 & APE (Symbian Phones) | 0 | 06-28-2004 21:50 |
