03-26-2006, 00:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | NOKIA 6600 SIM CARD NOT VALID after flashing Formerly it has the problem with Bluetooth. Sometimes when you ON the Bluetooth, it displays a message. Now after flashing does not accept, i un-ticked the "ENABLE THE BT FLASHING" for it to flash. Then the MCU+PPM+PM FULL, UI-NORMAL, UI-LOCAL & FORMAT USER AREA. Now the Phone is even worst. IT DOES NOT OPEN BLUETOOTH & GALLERY, but it works. Then I ERASE & FLASH AGAIN. It's now WORSe, It does not accept sim, It writes: SIM CARD NOT VALID Help |
03-28-2006, 02:02 | #4 (permalink) |
Member: 113732 Status: Offline Thanks Meter: 90 | It works. Everything was working perfectly, the Bluetooth & gallery are working. But when i off it & restart it, Again the bluetooth & gallery are not working. I don't want to change the bluetooth IC. any other way I'll try this: http://forum.gsmhosting.com/vbb/show...postcount=1646 [for 6600 galory and bloutooth problem you can make resoldring the bloutooth or bick it up and clean under it and resoldr it again or replace it by a new module all of this solve the problem by hardware or there is a solution by software by using chines erase flash] Last edited by gambitjam; 03-28-2006 at 02:18. |
Sim card not valid after flash with JAF | thedeathbringer | Nokia Base Band 5 ( BB-5 ) | 9 | 08-29-2009 17:48 |
N73 SIM card not valid! after flash. | SanjeewaG | J.A.F. Plus | 10 | 11-12-2008 09:47 |
nokia 6600 sim card not valid | rcpabari | Nokia Hardware & Hardware Repair | 3 | 07-26-2008 10:48 |
N91 sim card not valid after flash | egreen1956 | Universalbox | 11 | 01-13-2007 12:06 |
