01-03-2007, 23:54 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 409467 Status: Offline Thanks Meter: 1 | Problem Running USF-3 Software Then when the files open and I try to connect it says UFS .rtp "Bad environment31. Library not found" Clean system for obsollete USB Drivesl. I know I'm new at this but before when I had the old version of Sara at least it loaded. HELP |
The Following User Says Thank You to Jasont81 For This Useful Post: |
01-04-2007, 10:34 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: InsideOut
Member: 333359 Status: Offline Thanks Meter: 91 | Uninstall UFS Suite, Remove USB Connection of UFS Box, Install UFS Suite,Restart Computer, Connect USB Cable to Box, Now Install Drivers... Check UFS SW if OK...Good Luck |
01-15-2007, 19:49 | #5 (permalink) |
Member: 409467 Status: Offline Thanks Meter: 1 | Ok, I got a brand new computer and downloaded the UFS-3 Suite. When I ran the program I get the same f**k message. "Bad envirnoment 31. Clean system from obsolute USB Drivers". I have nothing on this brand new computer and I still get this message. Somebody please HELP!!! |
unlock x660 for usf -3 cable e860 | plamen40 | Samsung Flashers, Software, Firmware. | 9 | 03-04-2006 00:07 |
Usf-3 | flmr | UFS2 + UFS3-Tornadoflasher | 1 | 11-28-2005 08:30 |
Login required for USF 3 | bbmad | UFS2 + UFS3-Tornadoflasher | 2 | 06-29-2005 13:09 |
is it possible to flash e800 with usf/3 | ringtons | UFS2 + UFS3-Tornadoflasher | 0 | 05-12-2005 04:35 |
how to unlock 3595 using usf-3 tornado | drti | UFS2 + UFS3-Tornadoflasher | 8 | 04-06-2005 05:44 |
