reset user lock problem on 7250? im trying to reset security code on a 7250. it tells me that security code is set to 12345. then all oki. the phone work with orginal card. but ask for sec. code when i insert a new simcard ..then sec code 12345 do not work. is there any other solutions for this without out full reset? |
because Nokia close "Reset User Lock" in new Sw versions |
yes . but if i use factorydefaults i lose all setup on mobile phone. like pitcures, ring tones, games? wap setup ect?? dont i? |
Backup this with some common nokia software. PhoneBook, You can backup with Twister |
im new on twister. can you tell me how i backup using twister? |
"User Setting Items" Gro*****, will be created PHB file. To write back do this: 1. Unselect "Use Ini File Settings" (if this not specifed in INI) 2. Select "Phone Book" in "User Setting Items" Gro***** 3. Do "Write User Settings" (use previous PHB file) You can Backup only PhoneBook with Twister |
