05-21-2007, 22:12 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 426128 Status: Offline Thanks Meter: 0 | hwk-usf 2.05 crash i HAVE uninstalled ver.2.04 first. all i get to se on screen is following message : acces violatin xxxxx. and the computor closes down. Have u any solutions ? |
05-22-2007, 00:14 | #2 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Amsterdam Age: 39
Member: 48648 Status: Offline Thanks Meter: 1 | Use the new drivers included in the package Have a look into your sarasoft folder if there are some files left delete them after that also install the new drivers, when you install the new hwk setup it checks if you got new drivers installed. i had the same problem i didnt had to format or do anything else except for update the ufs driver manually. with kind regards, ThaDevil |
06-05-2007, 18:37 | #5 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 498524 Status: Offline Thanks Meter: 19 | Very simple. Ctrl + Alt + Delete ....Go to Processes and end task on UFS instalation. Now install version. I started @ first version and installed all versions after each other with no problems. Enjoy |
Can't Install HWK Suite 2.05.007 | .:: Sepid Gsm ::. | HWK | 34 | 06-15-2008 08:37 |
Install HWK Suite 2.05.007 and upgrade ur HWK keys... HWK server is working now.. | Arif Jamil | HWK | 9 | 10-08-2007 21:17 |
i cant install hwk suite 2.05.. | LoveLess | HWK | 5 | 10-01-2007 12:09 |
install problem hwk minor 2.05.006 | kungpaoski | HWK | 16 | 08-20-2007 15:50 |
