Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 12-05-2004, 22:57   #1 (permalink)
Member: 95864
Twister power surge on hub port
Hi, I just got twister yesterday, I install twister 1.26, everytime I press connect, I see my serial number, licence ok etc message, then my windows xp pop an usb icon beside clock. saying Power surge on hub port, saying that general hub excess the usb power limit, I tried with 2 computers, both have the same problems. Is my twister fautly or my software is faulty ? thank you for your time.
Old 12-05-2004, 23:31   #2 (permalink)
HAITEKGSM's Avatar
Member: 8966
Thanks Meter: 31
hi
i think software problem
you must install service pack2
and check usb 2.0 drivers
Old 12-05-2004, 23:52   #3 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Originally Posted by ElaBa
hi
On what exactly do you base this information??
How will Service Pack 2 affect the voltage being drawn on a USB line? What have USB2 drivers got to do with it?
@LMing
Do you have any other devices plugged into your USBs ports at all, or just Twister? If you have tried it on a different PC, was that PC a totally different sort (ie different motherboard) or the same?
It's possible you have too many devices plugged in already, which will cause the problem you've got, your USB ports aren't able to generate enough voltage or there might be a problem with your Twister box.
If you're able to get your hands on a powered USB hub (they're usually pretty cheap) then try plugging your Twister into that, it might help. Otherwise if you keep getting the problem I would return the unit to your reseller.
Old 12-06-2004, 01:17   #4 (permalink)
Member: 95864
Thank you for your reply, to muppet, first I thought I had too many usb devices on my computer, then I tried on 2 laptop, 1 desktop, it all happen the samething. therefore I am very confused about it since twister suite did dectect my twister. thank you for your time
Old 12-06-2004, 02:22   #5 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Well, I don't know the hardware of the Twister Box very well, but in all my use of it I've never encountered this problem. I suspect that you might have a faulty Twister Box. Contact your reseller and tell them about the problems you've had, they should be happy to replace it (or at least test it for you)
Old 12-06-2004, 05:12   #6 (permalink)
Member: 95864
thank you very much, i will try.
Old 12-06-2004, 08:47   #7 (permalink)
shakeelajmal's Avatar
Member: 51639
Thanks Meter: 76
The problem LMing is mentioning is when you use twister and also the port available in twister !!! or if you use USB hub without external power !! no software or twister problem !! thats all, i have same problem only and only because of these two reasons and solved by using only twister and all other devices pluged out !!
Old 12-06-2004, 14:36   #8 (permalink)
Member: 95864
Hi thanks for the reply, I treid on different computer, same thing still, it seems it's a device inside the twister since twister is also an USB hub by itself, here is the pic
Old 12-06-2004, 15:08   #9 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
i get this problem all the time with my box to, it only started to happen after i cut the tracks on the twister pcb so as i did have to use the little yellow gender changer
Old 12-06-2004, 17:47   #10 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
@LMing,
Do you only get this issue when you plug a cable into the box or all the time?
From looking at your USB output it looks like a Twister internal hub failure.
Odia.
Old 12-06-2004, 17:50   #11 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Mab'y ur' box is hawing a shortcircuit . U can try to check the voltage from usb .
Br Ionel.
Old 12-06-2004, 19:56   #12 (permalink)
Member: 95864
It's happening all the time even without pluging the cable, I will contact my dealer and see check out the problem, thank you guys so much !
Old 12-07-2004, 07:51   #13 (permalink)
Member: 16328
I also experienced this thing before on some boxes that i sold, maybe twister should look on this, I notice the problem comes when the box is using smd type cpu's and not the ordinary dip ic's, but this is only my observation, maybe you should look which ic you have and if its the smd type then perhaps im right.
Ed
Old 12-08-2004, 19:50   #14 (permalink)
cmk
Member: 10387
Thanks Meter: 3
change another good usb 2.0 cable, the bad cable will pick up much noise when use Twister
Old 12-08-2004, 21:44   #15 (permalink)
Member: 95864
Tried already, doesn't work either
Power surge on hub port youtel iPhone 4 / iPhone 4S 9 07-23-2010 18:22
EUB Power Surge on Hub Port?how to solv rana4star Easy-Unlocker 3 09-30-2008 02:49
Dead 903SH Won't TURN ON...Power surge from outlet supergk01 Sharp 0 09-13-2007 10:11
NSPRO Power Surge Cable is Available !! UnlockCellular NSPRO 14 04-30-2007 14:46
Z400 and USB Power Surge drancill UST Pro II 4 01-18-2007 04:47
Page generated in 0.20976 seconds with 10 queries
