Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 08-15-2008, 20:33   #1 (permalink)
Member: 711790
Sonork: mobileclinic.page.tl
Thanks Meter: 485
Arrow A Solution For 'bad Environment Library' In Ufs
MANY FRIENDS ARE FACE TO THIS PROBLEM WITH UFS, THAT IS "BAD ENVIRONMENT LIBRARY, CLEAN SYSTEM FROM OBSOLLETE DRIVER." I will request to all friend, please apply this simple method before get the decision to uninstalling all ufs softwares or formatting your computer. Computer formatting is the last method which lose our many needed document and time factor also. follow the process: First open my computer properties/hardware/device manager/universal serial bus controller/twister device (c) saras soft/----select driver option-----------/----------select update driver option-----/--------you will get ufs driver installation option/ install the ufs driver again with overwriting, problem solved. please dont apply this method by controll panel. Sorry for computer formatting advisers.
The Following 6 Users Say Thank You to rashedmc For This Useful Post:
Old 09-29-2013, 08:56   #2 (permalink)
Member: 1880922
UFS Panel "Bad environment library" solution
If this message is shown while the installation of UFS Panel, you should uninstall the previous Support suite setup from your computer and reinstall the UFS Panel again. It should be successfull because I did it once.
Old 10-20-2013, 08:10   #3 (permalink)
Member: 1150176
Sonork: stelecom.2009
Thanks Meter: 33
ufs new version bad envirobnment:5 system trashed 2 clen system erro aa rha ha..................
The Following User Says Thank You to stelecom.2009 For This Useful Post:
Old 11-12-2013, 13:01   #4 (permalink)
Member: 615018
go to add or remove program and remove ufs driver and re install the driver
Old 04-06-2014, 09:17   #5 (permalink)
Member: 1387967
Sonork: rameesmk
sir any solution pls.
Old 08-26-2014, 08:13   #6 (permalink)
lovezubi's Avatar
Member: 454021
Thanks Meter: 57
ufs error bad environment
dear problem solved
1- uninstall all drivers
2- use this link download new drivers or new setup
Sarunasoftware Support Area -> Help section
install and enjoy
regards
faisal
Old 08-26-2014, 08:18   #7 (permalink)
lovezubi's Avatar
Member: 454021
Thanks Meter: 57
dear problem solved
install and enjoy
regards
faisal
Old 09-07-2014, 10:44   #8 (permalink)
Member: 1862407
Sonork: india
Thanks Meter: 37
Done
Originally Posted by rashedmc View Post
many friends are face to this problem with ufs, that is "bad environment library, clean system from obsollete driver." i will request to all friend, please apply this simple method before get the decision to uninstalling all ufs softwares or formatting your computer. Computer formatting is the last method which lose our many needed document and time factor also. Follow the process: First open my computer properties/hardware/device manager/universal serial bus controller/twister device (c) saras soft/----select driver option-----------/----------select update driver option-----/--------you will get ufs driver installation option/ install the ufs driver again with overwriting, problem solved. Please dont apply this method by controll panel. Sorry for computer formatting advisers.
bro...yes,,,, u r correct...my...problem was solved..for u r guideness....thanx.
Old 09-21-2015, 09:39   #9 (permalink)
Member: 584794
Thanks Meter: 24
sucess
Originally Posted by lovezubi View Post
dear problem solved
install and enjoy
regards
faisal
problem solved thanks alot
Old 10-20-2015, 09:27   #10 (permalink)
Crazy Poster
Member: 82271
Thanks Meter: 4
dear problem solved
install and enjoy
regards
faisal
solved nice solution
Old 12-05-2015, 11:13   #11 (permalink)
-=noke23=-'s Avatar
Member: 1626732
Sonork: gsmhosting
Thanks Meter: 21
same problems my tornado UFS-3 so pls help any body brother and friends and all member this forum thanks advance
br:noke23
Old 09-18-2016, 02:15   #12 (permalink)
Member: 2420481
Sonork: none
Thanks Meter: 20
dear problem solved
install and enjoy
regards
faisal
veryyyythanks sir,,,problem solve
any solution for t616 low mic in ufs rushi UFS2 + UFS3-Tornadoflasher 0 08-24-2004 05:46
solution for illegal software loaded in t191 gmps2003 Motorola ODM 30 04-05-2004 14:52
One solution for "Ilegal software load" in T19x espinoza Motorola ODM 2 02-04-2004 21:16
Free solution for xx.14.xx in tamper alert frantelecom Motorola Old Legacy (EMMI) 21 01-29-2003 16:50
Solution for repair damaged bosch in exchange te Various 3 08-01-2001 18:19
Page generated in 0.24195 seconds with 10 queries
