09-07-2005, 18:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Egypt Age: 46
Member: 99784 Status: Offline Thanks Meter: 865 | step by Step To Repair the unexpected Exception Box_Error: 32 but this is the way to handl it with easy steps 1- install Dctx ver M then contact it with your box and press Connect(Pic 1) 2- then go to ufs2 tabe and press Update firmware ( you Ignore the Error window) you will get the message "Are you sure you want to Update box firmware will lose box Reg" click Yes(Pic 2) Note a) if the program asked for activation string there is aprogram can give you the old strings for ver M then put them and complet the steps b) if the program told you that your SN not vaild then change it to 2338 and complete the steps 3- awidow will be open to chose the REQ.FBI file chose it and press Open(Pic 3) you will get a message "Update server completed Requerd Jobes .... "(pic 4) then there is afile with your box SN ande ext. Req is genrated Now convert the Req file to Fbi file 4- open Dctx ver M again and contact it with your box and press Connect then go to ufs2 tabe and press Update firmware and chose the FBI file (the one that you converted from Req file ) Now you have solve the First problem 5- Run Dctx Ver i or K and press connect will asked about the strings Insert the New Strings this time then you will get a messgae to Update youe box chose yes(Pic 5) your box will be updated and back alife again ( you can now change your serial to any one but you must have the strings for that SN) I hope that helps you I tested with about 10 boxes an all work fine now If you need any thing I'm her br Galaxy Man |
09-07-2005, 19:22 | #2 (permalink) |
Freak Poster Join Date: May 1999 Location: spain
Member: 122 Status: Offline Thanks Meter: 18 | Hi. Good work Thx, and other solven the firs problem: - Run "DCTx12m", and upgrade "Ufs2_V2.5.fbi" select *fbi for upgrade file, Now your box Firmware Vers. V2.5 DOWNLOAD DCTx 12m AND Ufs2_V2.5.fbi *Today I did some intrucciones to upgrade firmware also, but theirs they are very good http://forum.gsmhosting.com/vbb/show...38&postcount=6 Bro. |
09-07-2005, 21:13 | #4 (permalink) | |
Member: 99784 Status: Offline Thanks Meter: 865 | Quote:
br GalaxyMan | |
09-08-2005, 09:55 | #6 (permalink) | |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 76564 Status: Offline Thanks Meter: 0 | Quote:
Best regards | |
09-08-2005, 10:38 | #8 (permalink) | |
09-08-2005, 11:40 | #10 (permalink) | |
Best regards | |
09-08-2005, 12:00 | #12 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Ukraine
Member: 117378 Status: Offline Thanks Meter: 21 | i have such problem - UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 0 Xx.x C02EC8, , S/n: xxxx Licence : False Licence update failed, try again Selected Device, not Compatible with Software can anybody help ? i think C02EC8 - it is atmega fuses. But they must be CC2EC8. How i can repair them ? |
09-08-2005, 12:56 | #13 (permalink) |
Member: 76564 Status: Offline Thanks Meter: 0 | For all kind of errors, 32, 50, 52, .... the best solution to repair the box is in this thread. I use to have those problems, after I deal with hwk cracked, but now my box is ok. Follow carefully all the steps. Like Phreackgsm wrote: http://forum.gsmhosting.com/vbb/sho...038&postcount=6 this is the easily way to make your box live again. Thanks all forum members for theier help. Best regards Last edited by ompgsm; 09-08-2005 at 13:11. |
09-09-2005, 08:28 | #14 (permalink) |
Member: 122 Status: Offline Thanks Meter: 18 | Hi. @ SubZverb - Newbie working with UFS? Using Swich or large cable? * Any USB ports on some laptops or PCs, can not supply enough current so it might be problem too Change your usb port, test any ports, and your pc to ufs cable is too long use small cable every thing will be ok, delete and reinstal drivers. Or switch compatibility to USB1.1 standard, for my NO use swich, or large cable. Or test in other computer. - Later you need upgrade firmware, your device ID is 62 CF 0 then your device requires an update, an updated device will show 62 CF 1 7. * For this cuestion, you need read all thread and to continue the steps. Bro. Last edited by Phreackgsm; 09-09-2005 at 17:41. |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
How to repair "reboot/restart/frees with SIM card" step-by-step instruction | InfinitySupport | Infinity-Box | 34 | 11-01-2007 01:10 |
How to repair a MOTOROLA phone step by step | hooi76 | Motorola P2k | 6 | 06-13-2007 03:27 |
How to repair dongle step by step done! & Clearly!!!! | computs | ARM9 BASED M62 / M62+ | 15 | 04-26-2004 23:14 |
